    Config for the Pinda v2 ,need help!
    449
    • lui2004
      lui2004 last edited by
      Hi
      I have bought a new Pinda V2 All is wired.
      But who can help me to create the config for the pinda v2 ?
      Thanks a lotfor help
      T3P3Tony martin7404 2 Replies Last reply Reply Quote 0
      • T3P3Tony
        T3P3Tony administrators @lui2004 last edited by
        @lui2004 how is it wired, to what duet?
        www.duet3d.com
        lui2004 1 Reply Last reply Reply Quote 0
        • martin7404
          martin7404 @lui2004 last edited by
          @lui2004 look here ```
          https://forum.duet3d.com/topic/23566/pinda2-to-duet3-toolboard?_=1633975545248
          Muldex IDEX 3d printer Duet2+Duex5+Paneldue 7i
          Custom CoreXY 600x400 Hemera , Duet3+toolboard v1.1, Paneldue 7i
          Mod Sapphire Pro with Duet2 ,Expansion Board with closed-loop motors
          voron v0.1 and cr10s both running klipper; stock Bambu lab X1CC
          • lui2004
            lui2004 @T3P3Tony last edited by lui2004
            @t3p3tony
            I have:
            Board: Duet 2 WiFi (2WiFi)
            Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
            Duet WiFi Server Version: 1.26
            Like this:
            • lui2004
              lui2004 @martin7404 last edited by
              @martin7404
              This how to is for the duet 3
              martin7404 1 Reply Last reply Reply Quote 0
              • martin7404
                @lui2004 just use the 0 and signal from the probe and 5V from expansion connector , temp to not used extruder temp
                lui2004 2 Replies Last reply Reply Quote 0
                • martin7404
                  martin7404 last edited by martin7404
                  https://forum.duet3d.com/topic/22695/pinda-2-config-duet-2-wifi
                  • lui2004
                    @martin7404
                    Are you german?
                    If yes can you explane me in german ?
                    • lui2004
                      @martin7404
                      What is the 0?
                      I use only 3 wire? The temp wire ist not in use?
                      • martin7404
                        martin7404 @lui2004 last edited by martin7404
                        @lui2004 sorry I am Bulgarian .
                        So generaly you ahve 3 wires +5V,- and Signal.
                        • and Sig are conected to - and sig on probe conector and 5V to some 5V pin on the board
                        • lui2004
                          @martin7404 like this:
                          and config:
                          ; PINDA2
                          M558 P5 C"zprobe.in" H1.5 F1000 T12000 A3 ; set Z probe to PINDA2
                          M308 S2 P"e1temp" A"Pinda V2" Y"thermistor" T100000 B3950 ; temperature of PINDA2
                          • T3P3Tony
                            @lui2004 that looks correct and the config matches the wiring. As always when you test the trigger for the first time first confirm not is triggering as expected by manually lowering the Z axis so it's not the expected trigger height and checking the z probe is shown as switching in DWC
                            www.duet3d.com
                            • lui2004
                              @t3p3tony
                              after i do a Dynamic test
                              the pinda v2 wont stop it will crash into the bed
                              • T3P3Tony
                                @lui2004 if you move the probe down manually do you see the Zprobe indication on DWC change. What is it showing?
                                www.duet3d.com
                                • lui2004
                                  @t3p3tony
                                  the pinda wont trigger because i have a pei surface.
                                  i have insert some Aluminum foil under the pei i now it will work.
                                  which surface is good without Aluminum foil under pei ?
                                  • T3P3Tony
                                    @lui2004 whats the PEI surface mounted on? I suppose most people using PINDA style probes an aluminium bed.
                                    www.duet3d.com
                                    • lui2004
                                      @t3p3tony
                                      aluminium bed with pei
                                      this is my heightmap:
                                      RepRapFirmware height map file v2 generated at 2021-10-12 14:59, min error -0.093, max error 0.125, mean 0.003, deviation 0.049
                                      axis0,axis1,min0,max0,min1,max1,radius,spacing0,spacing1,num0,num1
                                      X,Y,10.00,220.00,10.00,220.00,-1.00,20.00,20.00,11,11
                                            0,      0,      0,      0,      0,      0,      0,      0,      0,      0,      0
                                            0,      0,      0,  0.008, -0.000,  0.091,  0.057, -0.005,  0.050,  0.050,  0.007
                                            0,      0,      0, -0.000, -0.025,  0.082,  0.087,  0.050,  0.032,  0.091, -0.009
                                            0,      0,      0, -0.018,  0.025,  0.116,  0.125,  0.012,  0.007,  0.082, -0.025
                                            0,      0,      0, -0.025,  0.016,  0.116,  0.125, -0.018,  0.032, -0.005, -0.050
                                            0,      0,      0, -0.043, -0.025,  0.041,  0.025, -0.009, -0.018,  0.025, -0.084
                                            0,      0,      0, -0.050, -0.075, -0.034, -0.018, -0.000, -0.000, -0.000, -0.059
                                            0,      0,      0, -0.050, -0.038, -0.034, -0.021, -0.018, -0.018,  0.037, -0.059
                                            0,      0,      0, -0.055, -0.050, -0.043,  0.025, -0.018, -0.034, -0.055, -0.093
                                            0,      0,      0, -0.063, -0.034,  0.032,  0.025,  0.016, -0.009,  0.020, -0.050
                                            0,      0,      0, -0.030, -0.025,  0.007, -0.000,  0.025,  0.025,  0.050,  0.041
                                      • lui2004
                                        I bought a new surface !
                                        what is important to calibrate the pinda V2 ?
                                        • lui2004
                                          This is my actuall config.g
                                          ; generated by RepRapFirmware Configuration Tool v2 on Tue May 07 2019 23:06:50 GMT+0100 (British Summer Time)
                                          G90                                      ; Send absolute coordinates...
                                          M83                                      ; ...but relative extruder moves
                                          M550 P"Ender 5"                          ; Set machine name
                                          M552 S1                                  ; Enable network
                                          M586 P0 S1                               ; Enable HTTP
                                          M586 P1 S0                               ; Disable FTP
                                          M586 P2 S0                               ; Disable Telnet
                                          M569 P0 S1                               ; Physical drive 0 goes forwards
                                          M569 P1 S1                               ; Physical drive 1 goes forwards
                                          M569 P2 S0                               ; Physical drive 2 goes backwards
                                          M569 P3 S1                              ; Physical drive 3 goes forwards
                                          M584 X0 Y1 Z2 E3                               ; set drive mapping
                                          M350 X16 Y16 Z16 E16 I1							; configure microstepping with interpolation
                                          M92 X80.00 Y80.00 Z400.00 E288.30                     ; set steps per mm
                                          M566 X600.00 Y600.00 Z60.00 E300.00                  ; set maximum instantaneous speed changes (mm/min)
                                          M203 X9000.00 Y9000.00 Z600.00 E6000.00              ; set maximum speeds (mm/min)
                                          M201 X500.00 Y500.00 Z100.00 E5000.00                ; set accelerations (mm/s^2)
                                          M906 X800 Y800 Z800 E1400 I30                         ; set motor currents (mA) and motor idle factor in per cent
                                          M84 S30
                                          M208 X0 Y0 Z0 S1                                     ; set axis minima
                                          M208 X235 Y235 Z250 S0                               ; set axis maxima
                                          M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
                                          M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
                                          M574 Z1 S2 									   ; configure Z-probe endstop for low end on Z
                                          ;Filament Sensors
                                          M591 D0 P2 C"!e0_stop" S1   			   ;Extruder 1(0)
                                          ; PINDA2
                                          ;M558 P5 C"^zprobe.in" H1.5 F1000 T12000 A3 ; set Z probe to PINDA2
                                          M558 K0 P8 C"^zprobe.in" I1 H2 F1000 T6000 A20 S0.005 ; set Z probe type to effector and the dive height + speeds, max number of probes per point, tolerance(MM)
                                          G31 P500 X52.7 Y18 Z1.775                  ; set Z probe trigger value, offset and trigger height
                                          M557 X10:210 Y10:210 S20                       ; define mesh grid
                                          ;M557 X41.2:219 Y15:195 S20
                                          ;M671 X28.8:198.8:198:28.8 Y24:24:194:194 P0.5
                                          M557 X10:220 Y10:220 S20
                                          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                                          M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                                          M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                                          M140 H0                                        ; map heated bed to heater 0
                                          M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                                          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8; configure sensor 1 as thermistor on pin e0temp
                                          M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                                          M143 H1 S280 								   ; set temperature limit for heater 1 to 300C
                                          M307 H1 B0 S1.00
                                          M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                                          M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                                          M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                                          M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                                          M563 P0 D0 H1                            ; Define tool 0 S3D
                                          G10 P0 X0 Y0 Z0                          ; Set tool 0 axis offsets
                                          G10 P0 R0 S0                             ; Set initial tool 0 active and standby temperatures to 0C
                                          M572 D0 S0.05 ; Pressure Advance PLA
                                          ;M572 D0 S0.08 ; Pressure Advance PLA
                                          M207 S1.50 R0 F2100 T2100 Z0 ; Firmware Retraction P0 S0.45 R0 F2100 T2100 Z0 ; Firmware Retraction
                                          M204 P500 T2000
                                          T0 ; Sets Tool0 as default
                                          M501
                                          homeall.g
                                          ; homeall.g
                                          ; called to home all axes
                                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 28 2020 08:52:12 GMT+0200 (Mitteleuropäische Sommerzeit)
                                          G91 ; relative mode
                                          G1 H2 Z4 F200 ; raise head 4mm
                                          G1 H1 X-240 Y-240 F3000 ; move up to 240mm in the -X and -Y directions until the homing switches are triggered
                                          G1 H2 X4 Y4 F600; move slowly 6mm in +X and +Y directions
                                          G1 H1 X-10 Y-10 ; move up to 10mm in the -X and -Y directions until the homing switches are triggered
                                          G90 ; back to absolute mode
                                          G1 X57.3 Y92 F2000 ; put head over the centre of the bed, or wherever you want to probe
                                          G30 ; lower head, stop when probe triggered and set Z to trigger height
                                          ; homex.g
                                          ; homex.g
                                          ; called to home the X axis
                                          G91 ; relative mode
                                          G1 H2 Z4 F200 ; raise head to avoid dragging nozzle over the bed
                                          G1 H1 X-240 F3000 ; move up to 240mm in the +X direction, stopping if the homing switch is triggered
                                          G1 X-4 F600 ; move slowly 4mm in the -X direction
                                          G1 H1 X10 ; move slowly 10mm in the +X direction, stopping at the homing switch
                                          G1 H2 Z-4 F200 ; lower the head again
                                          homey.g
                                          ; homey.g
                                          ; called to home the Y axis
                                          G91 ; relative mode
                                          G1 H1 Y-240 F3000 ; move up to 240mm in the -X direction, stopping if the homing switch is triggered
                                          G1 X4 F600 ; move slowly 4mm in the +X direction
                                          G1 H1 X-10 ; move slowly 10mm in the -X direction, stopping at the homing switch
                                          homez.g
                                          ; homez.g
                                          ; called to home the Z axis
                                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 28 2020 08:52:37 GMT+0200 (Mitteleuropäische Sommerzeit)
                                          G91               ; relative positioning
                                          G1 H2 Z5 F6000    ; lift Z relative to current position
                                          G90               ; absolute positioning
                                          G1 X57.3 Y92 F6000 ; go to first probe point
                                          G30               ; home Z by probing the bed
                                          thanks for help
                                          • lui2004
                                            lui2004 last edited by lui2004
                                            Hi
                                            Is there a how to ,to set z offset on different temperature? Like in marlin?
                                            • T3P3Tony
                                              @lui2004 there is not the option of using a table like i think Marlin has. You configure the S and C parameters within G31 to compensate:
                                              https://duet3d.dozuki.com/Wiki/G31
                                              Based on this thread:
                                              https://forum.duet3d.com/topic/16972/pinda-2-probe-with-temperature-compensation/5?_=1593546022132
                                              It appears the non linearity of the measurements at different temperatures could be a problem.
                                              The poster in that post shows a conditional gcode way to get around the problem. Before you do that it would be worth testing you can get a good z probe performance with everything (including the PINDA temperature) at a steady temperature.
                                              Once thats working then non linear temperature compensation can be looked at,
                                              www.duet3d.com
                                              • lui2004
                                                @t3p3tony
                                                Thanks ,i will give it a try!
                                                Other question when print is finished my z axis at 0 what i can do that the z-axis goes u after print?
                                                • T3P3Tony
                                                  T3P3Tony administrators @lui2004 last edited by T3P3Tony
                                                  @lui2004 in the end gcode you can add a move to lift slightly and move the tool out the way.
                                                  E,g,
                                                  G91 ; set to relative positioning
                                                  G1 Z5 ; raise Z 5 mm
                                                  G90 ; set to absolute positioning
                                                  G1 X0 Y0 ; park at X0 Y0
                                                  www.duet3d.com
