    Just for fun why did I buy this?
    My Duet controlled machine
    526
    • fcwilt
      fcwilt last edited by
      There was a recent topic here the got my attention.
      It led me to try an experiment to change the way one of my printers does something common.
      The item shown uses a NEMA 11 stepper and has 100mm of travel. The one I am actually using has just 50mm of travel.
      Before I finish my work and post pictures anyone care to speculate on what I have been up to?
      Just for fun.
      The first person with the correct answer wins...
      (make a drum roll sound in your mind)
      ...the right to say they were the first person with the correct answer. 😉
      zapta fcwilt 2 Replies Last reply Reply Quote 0
      • zapta
        zapta @fcwilt last edited by zapta
        @fcwilt, give us an hint, how will it be oriented?
        I would use it to turn off the main switch when the print completes.
        fcwilt 1 Reply Last reply Reply Quote 0
        • fcwilt
          fcwilt @zapta last edited by
          @zapta
          A hint?
          OK, it is used to move something out of the way so when printing no print area is lost but still allows the something to perform it's intended purpose.
          bot zapta 2 Replies Last reply Reply Quote 0
          • bot
            bot @fcwilt last edited by
            Probing, tool alignment with a camera coming in and out, or purge bucket moving in and out of print area are my guesses.
            *not actually a robot
            • fcwilt
              fcwilt @bot last edited by
              @bot said in Just for fun why did I buy this?:
              Well one of the words in your post is exactly what this experiment is about.
              bot 1 Reply Last reply Reply Quote 0
              • bot
                @fcwilt the first word?
                • fcwilt
                  Yes
                  • bot
                    @fcwilt sounds like fun. I have been manually aligning my tools on the idex with a cheap USB microscope. so magnificent. You could use your little doo-dad to move the camera into the exact same position every time!
                    Or, a CNC-style tool pre-setter to measure tool Z offsets.
                    Or, a 3D-Taster style multi-axis touch probe to do Z and X/Y offsets.
                    • fcwilt
                      Well your first word was "probing" unless I read it wrong.
                      • bot
                        bot @fcwilt last edited by bot
                        @fcwilt hmmmm. probing is a vague term. I hope you're not thinking of placing anything in any dark places.
                        • fcwilt
                          Nope - nothing like that - but was not your first word "probing"? The second item mentioned as tool alignment using a camera.
                          Did I misunderstand your post?
                          • zapta
                            @fcwilt said in Just for fun why did I buy this?:
                            My answer below, encrypted with Google translate
                            Brosse de nettoyage de buse
                            • jens55
                              jens55 last edited by
                              Pebble wiper setup
                              • fcwilt
                                @zapta said in Just for fun why did I buy this?:
                                I like that I idea - I may just try that as well.
                                • fcwilt
                                  fcwilt @jens55 last edited by
                                  @jens55 said in Just for fun why did I buy this?:
                                  Pebble wiper setup
                                  What is a "pebble wiper"?
                                  jens55 1 Reply Last reply Reply Quote 0
                                  • jens55
                                    jens55 @fcwilt last edited by
                                    @fcwilt, a device for cleaning printing nozzles. The purged filament is formed into a pebble for easy separation from the nozzle (no curling around of loose filament), disconnected from the nozzle and then wiped away to ready for the next purge operation. In the context of a tool changing printer, the height of the wiper assembly is adjusted based on the tool being purged which is why you have a very short reach adjustable stage.
                                    • fcwilt
                                      Interesting.
                                      How is the filament formed into a "pebble"?
                                      jens55 Yveske 2 Replies Last reply Reply Quote 0
                                      • jens55
                                        @fcwilt, it is extruded onto a flat surface just underneath the extruder
                                        https://lukeslabonline.com/products/pebble-wiper?variant=41218627371193
                                        fcwilt 1 Reply Last reply Reply Quote 1
                                        • fcwilt
                                          Well the link is interesting because it is also a clue to what I am experimenting with.
                                          • Yveske
                                            Yveske @fcwilt last edited by
                                            @fcwilt A cheaper, mechanical way of doing things
                                            https://www.bigbrain3d.com/product/retractable-purge-mechanism/
                                            • fcwilt
                                              fcwilt @Yveske last edited by
                                              @yveske said in Just for fun why did I buy this?:
                                              That is rather neat.
                                              • fcwilt
                                                fcwilt @fcwilt last edited by
                                                Well I finished the first experimental setup and it is working, although with a limitation I believe is related to the 12 volt power supplies I used on this printer.
                                                I will make a quick video Wednesday and post a link to it here.
                                                • fcwilt
                                                  @fcwilt
                                                  Here is a link to a quick-and-dirty video showing the mini linear guide at work.
                                                  Mini Linear Guide At Work
                                                  It was hard to get a good view - sorry.
