    Z axis not homing
    1.7k
    • PRIOR123undefined
      PRIOR123 @PRIOR123
      @prior123
      if i put my finger in to make the printer think its homed the Z axis (on home all) im still getting this error too
      G28
      Error: in file macro line 5: M280: parameter 'P' too high
        jay_s_uk @PRIOR123
        @prior123 can your printer even reach X-38 Y-10?
        Post your config.g
        PRIOR123undefined 1 Reply Last reply Reply Quote 0
          jay_s_uk @PRIOR123
          @prior123 you may also want to check your retractprobe.g as well
          • PRIOR123undefined
            PRIOR123 @jay_s_uk
            @jay_s_uk
            ; generated by RepRapFirmware Configuration Tool v3.2.3 on Tue Mar 16 2021 15:54:40 GMT+0000 (Greenwich Mean Time)
            M550 P"" ; set printer name
            ;M551 P"" ; set password
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S1 ; physical drive 0 goes backwards
            M569 P1 S1 ; physical drive 1 goes backwards
            M569 P3 S0 ; physical drive 3 goes forwards
            M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
            M906 X600 Y600 Z600 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X-5.5 Y-10 Z0 S1 ; set axis minima
            M208 X220 Y220 Z250 S0 ; set axis maxima
            M574 Z1 S2 ; configure Z-probe endstop for low end on Z
            G31 P500 X-49 Y9 Z1.597 ; set Z probe trigger value, offset and trigger height
            M557 X-15:165 Y20:230 S20 ; define mesh grid
            ;M557 X5:205 Y5:165 S20 ; Define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
            M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
            M106 P0 C"Part Cooling" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
            M106 P1 C"Heatsink/Hotend" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
            M106 P2 C"PartCooling" S1 H1 T45 ; set fan 2 name and value. Thermostatic control is turned on
            M563 P0 S"PrintHead01" D0 H1 F0 ; define tool 0
            T0 ; select first tool
            • PRIOR123undefined
              PRIOR123 @jay_s_uk
              @jay_s_uk This has stopped the warning sign! thank you
                jay_s_uk @PRIOR123
                @prior123 all sorted now?
                • PRIOR123undefined
                  PRIOR123 @jay_s_uk
                  @jay_s_uk
                  the homing error is fixed but the x and y positioning when homing the Z via home all isnt working
                    jay_s_uk @PRIOR123
                    @prior123 because you're in absolute mode. Surely X-38 Y-10 is off your bed or even outside your axis limits
                    • PRIOR123undefined
                      PRIOR123 @jay_s_uk
                      @jay_s_uk so should i comment out that line then? sorry im pretty unknown when it comes to programming
                        jay_s_uk @PRIOR123
                        @prior123 well where do you want the nozzle to move to when you do the G30?
                        • PRIOR123undefined
                          PRIOR123 @jay_s_uk
                          @jay_s_uk probably X-60 and Y-10
                          But i just changed that in the homeall.g and it doesnt seem to be doing anything
                            jay_s_uk @PRIOR123
                            @prior123 how? That's way outside your bed limits set in M208 in your config
                            • PRIOR123undefined
                              PRIOR123 @jay_s_uk
                              @jay_s_uk this has helpe massively! thank you.
                              How can i work out the true measurements essentially ive defined it all no with
                              M208 X60 Y-10 Z0 S1 ; set axis minima
                              M208 X235 Y235 Z260 S0 ; set axis maxima
                              however im not trying to define the mesh coordinates and i am continuously getting this
                              Warning: Skipping grid point X=200.0, Y=180.0 because Z probe cannot reach it
                              Warning: Skipping grid point X=220.0, Y=180.0 because Z probe cannot reach it
                              Warning: Skipping grid point X=220.0, Y=200.0 because Z probe cannot reach it
                              Warning: Skipping grid point X=200.0, Y=200.0 because Z probe cannot reach it
                              • PRIOR123undefined
                                PRIOR123 @PRIOR123
                                @prior123 the Z probe can go further im just really confused why it thinks it cant
                                  jay_s_uk @PRIOR123
                                  @prior123 your z probe has an offset of x-49. That means it can probe any further than 49mm before your x maximum. So with a maximum of 235, you can only probe up to X186 (otherwise the nozzle will have to go outside the machine limits)
                                  • PRIOR123undefined
                                    PRIOR123 @jay_s_uk
                                    @jay_s_uk said in Z axis not homing:
                                    235
                                    sooo close now
                                    ive recalibrated the Z probe, and redefined both the bed size and mesh size.
                                    I have just one last issue it still wont hit the last point on the bed and throws out an error before continuing the rest of the G32 code
                                    G31 P500 X-43 Y10 Z3.79 ; set Z probe trigger value, offset and trigger height
                                    M557 X60:260 Y30:245 S20 ; define mesh grid
                                    i thought it may have been the S value but that doesnt seem to make sense as 20 goes into 260
                                    any more ideas?
                                      jay_s_uk @PRIOR123
                                      @prior123 what error does it throw
                                      • PRIOR123undefined
                                        PRIOR123 @jay_s_uk
                                        @jay_s_uk
                                        G32
                                        Warning: Skipping grid point X=240.0, Y=30.0 because Z probe cannot reach it
                                        Warning: Skipping grid point X=260.0, Y=30.0 because Z probe cannot reach it
                                        Warning: Skipping grid point X=260.0, Y=50.0 because Z probe cannot reach it
                                        Warning: Skipping grid point X=240.0, Y=50.0 because Z probe cannot reach it
                                        jay_s_ukundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                          jay_s_uk @PRIOR123
                                          @prior123 again, you cant probe those points because your nozzle will go outside your axis limits. Based on 260, the closest you can go is X217
                                          • fcwiltundefined
                                            fcwilt @PRIOR123
                                            @prior123 said in Z axis not homing:
                                            @jay_s_uk
                                            G32
                                            If the warnings are in response to G32 we need to see your bed.g file.
                                            Do you understand how the probe X and Y offsets limit where the probe can reach?
                                            And, just FYI, I find it easier to use the P parameter for M557 rather than the S parameter. I care more about the number of grid points rather than the actual spacing of the grid points.
