    Lines on LCD
    200
    • Modix2021
      Modix2021 last edited by
      Has anybody seen this before? When turned on, the LCD goes through a series of vertical lines. When I touch the screen randomly it sometimes beeps and changes patterns. Left alone it will go blank. This continues when the LCD is removed from it Modix Big 60 mounting. LCD 1.JPG LCD 2.JPG LCD 3.JPG LCD 4.JPG LCD 5.JPG
      • T3P3Tony
        T3P3Tony administrators @Modix2021 last edited by
        @modix2021 yes the LCD screen is faulty and needs replacing.
        www.duet3d.com
        Modix2021 1 Reply Last reply Reply Quote 0
        • Modix2021
          Modix2021 @T3P3Tony last edited by
          @t3p3tony
          Modix is sending one. Any idea why my wifi and LCD would mess up at the same time? Then wifi came back whether or not the faulty LCD was connected. Hoping to learn how to keep this from happening again. Will have been down for a month sorting this out.
          You have been most helpful when I post.
          L
          dc42 elmoret 2 Replies Last reply Reply Quote 0
            dc42 administrators @Modix2021 last edited by dc42
            @modix2021 I have also seen lines like that when the voltage on the 5V rail is too low.
            • Modix2021
              Modix2021 @dc42 last edited by Modix2021
              @dc42 Thank you. Would that happen spontaneously after months and months of intermittent use or soon after installation? We've been good for quite a while then wham.
                @modix2021 said in Lines on LCD:
                No, unless something else in the system has caused the 5V rail voltage to drop.
                If the problem is caused by the 5V rail being low, then pressing the reset button on the PanelDue sometimes gets the display working. The reset button is behind the hole to the right of the screen that is not close to the USB port. Don't push the button near to the USB port - that erases the PanelDue firmware!
                Modix2021 2 Replies Last reply Reply Quote 0
                • Modix2021
                  Thank you. I'll try that.
                  L
                  • Modix2021
                    I see what looks like a button with Reset above it. Is that it? I also see a button with Erase above it.
                    Obviously that is not the correct button. I can post a picture of the front of the unmounted PanelDue
                    is that helps.
                    L
                    jay_s_uk 1 Reply Last reply Reply Quote 0
                    • jay_s_uk
                      jay_s_uk @Modix2021 last edited by
                      @modix2021 the one with reset
                      • Modix2021
                        Modix2021 @jay_s_uk last edited by
                        @jay_s_uk
                        Thank you!
                        L
                        • Modix2021
                          @jay_s_uk
                          Well, same result. Vertical line patterns as before.
                          So I guess this LCD is toast.
                          Thank you for that information. Could come in handy in the future.
                          L
                          • elmoret
                            elmoret @Modix2021 last edited by elmoret
                            @t3p3tony
                            L
                            Likely that the Duet and PanelDue were damaged at the same time from shorting 24v to 3.3v or 5v.
