    homing error, even all endstops hit
    134
    • adhanabal
      adhanabal last edited by
      hi all,
      im using duet3 6hc and duet3hc board, my endstops are correctly wired, if i give home all, my nozzle moves to the endstop location and endstops status becoming triggered,
      but the homing did not change from orange to blue in web interface, if i try moving any axis it says insufficient axis homed,
      firmware version;3.3
      config.g
      M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      M574 Z2 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io2.in
      homeall.g
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.3.5 on Tue Nov 02 2021 17:39:59 GMT+0530 (India Standard Time)
      G91 ; relative positioning
      G1 H2 Z0 F6000 ; lift Z relative to current position
      G1 H1 X-235 Y-155 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-235 ; home X axis
      G1 H1 Y-155 ; home Y axis
      G1 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-235 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-155 ; then move slowly to Y axis endstop
      G1 H1 Z175 F360 ; move Z up stopping at the endstop
      G90 ; absolute positioning
      G92 Z170 ; set Z position to axis maximum (you may want to adjust this)
      jay_s_uk 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @adhanabal last edited by
        @adhanabal post your complete config
        adhanabal 1 Reply Last reply Reply Quote 0
        • adhanabal
          adhanabal @jay_s_uk last edited by
          @jay_s_uk
          ; Configuration file for Duet 3 (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.5 on Tue Nov 02 2021 12:17:38 GMT+0530 (India Standard Time)
          M550 P"fabforge-PDS" ; set printer name
          M669 K1 ; select CoreXY mode
          ; Wait a moment for the CAN expansion boards to start
          G4 S2
          M551 P"fabforge" ; set password
          M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0.0 S0 ; physical drive 0.0 goes forwards
          M569 P0.1 S0 ; physical drive 0.1 goes forwards
          M569 P0.2 S0 ; physical drive 0.2 goes forwards
          M569 P0.3 S1 ; physical drive 0.3 goes forwards
          M569 P0.4 S1 ; physical drive 0.4 goes forwards
          M569 P0.5 S1 ; physical drive 0.5 goes forwards
          M569 P1.0 S1 ; physical drive 1.0 goes forwards
          M584 X0.0 Y0.1 Z0.2 E0.3:0.4:0.5:1.0 ; set drive mapping
          M350 X16 Y16 Z16 E16:16:16:16 I1 ; configure microstepping with interpolation
          M92 X100.00 Y100.00 Z400.00 E420.00:420.00:420.00:420.00 ; set steps per mm
          M566 X900.00 Y900.00 Z300.00 E120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z900.00 E1200.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z100.00 E250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E300:300:300:300 I0 ; set motor currents (mA) and motor idle factor in per cent
          M84 S0 ; Set idle timeout
          M208 X230 Y150 Z170 S0 ; set axis maxima
          M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 0
          M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
          M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
          M143 H1 S120 ; set temperature limit for heater 1 to 120C ; set temperature limit for heater 1 to 120C
          M563 P0 D0 H0 F0 ; define tool 0
          M563 P1 D1 H1 F0 ; define tool 1
          G10 P1 X33 Y0 Z0 ; set tool 1 axis offsets
          G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
          M563 P2 D2 F0 ; define tool 2
          G10 P2 X66 Y0 Z0 ; set tool 2 axis offsets
          G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
          M563 P3 D3 F0 ; define tool 3
          G10 P3 X99 Y0 Z0 ; set tool 3 axis offsets
          G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C
          M911 S20 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
          please check
          • jay_s_uk
            @adhanabal said in homing error, even all endstops hit:
            this is your issue. you're turning your motors off after 0 seconds.
            Change the I back to 30 and the S back to 30
            adhanabal 2 Replies Last reply Reply Quote 0
            • adhanabal
              @jay_s_uk
              okay i will check this and update you now
              • adhanabal
                @jay_s_uk
                yes it worked, thank you, but in duet 2 wifi i did not face this issue..
                is there any way that i can make extruder motor current to zero immediately if it is not in use
                • T3P3Tony
                  T3P3Tony administrators @adhanabal last edited by
                  @adhanabal You can send M84 E to turn of the extruder motor however there is not a separate idle hold timer for each motor.
                  www.duet3d.com
                  • adhanabal
                    adhanabal @T3P3Tony last edited by
                    @t3p3tony thanks alot for your inputs brother..
