    Solved panel due 5i not connecting
    PanelDue
    151
    • adhanabal
      adhanabal last edited by
      i have paneldue 5i version3.0, firmware version 3.3, duet3 6hc firmware version 3.3, when i connect to io-0.in pin for panel due it just says connecting but nothing happens, no controls.
      i have 8nos of panel due in stock with me, none of them are connecting,
      i tried to plug the same in duet2 wifi board with firmware version 1.23, it working perfectly, i also attached my config.g file , please check.
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.5 on Tue Nov 02 2021 12:17:38 GMT+0530 (India Standard Time)
      M550 P"fabforge-PDS" ; set printer name
      M669 K1 ; select CoreXY mode
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      M551 P"--------" ; set password
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.0 S0 ; physical drive 0.0 goes forwards
      M569 P0.1 S0 ; physical drive 0.1 goes forwards
      M569 P0.2 S0 ; physical drive 0.2 goes forwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M569 P0.4 S1 ; physical drive 0.4 goes forwards
      M569 P0.5 S1 ; physical drive 0.5 goes forwards
      M569 P1.0 S1 ; physical drive 1.0 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3:0.4:0.5:1.0 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16:16 I1 ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z400.00 E420.00:420.00:420.00:420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z300.00 E120.00:120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z900.00 E1200.00:1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E250.00:250.00:250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E300:300:300:300 I0 ; set motor currents (mA) and motor idle factor in per cent
      M84 S0
      M208 X240 Y150 Z200 S0 ; set axis maxima
      M574 X1 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      M574 Z2 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io2.in
      M308 S0 P"temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 0
      M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
      M143 H1 S120 ; set temperature limit for heater 1 to 120C ; set temperature limit for heater 1 to 120C
                                                     ; set initial tool 3 active and standby temperatures to 0C
      M563 P0 D0 H0 F0 ; define tool 0
      M563 P1 D1 H1 F0 ; define tool 1
      G10 P1 X33 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      M563 P2 D2 H1 F0 ; define tool 2
      G10 P2 X66 Y0 Z0 ; set tool 2 axis offsets
      G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C
      M563 P3 D3 H1 F0 ; define tool 3
      G10 P3 X99 Y0 Z0 ; set tool 3 axis offsets
      G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C
      M302 P1
      M911 S20 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      • Topic has been marked as a question  mfs12 mfs12
      • mfs12
        mfs12 last edited by
        Hey @adhanabal,
        which versions are running on your devices? I am interested in
        • paneldue firmware version
        • duet3 board firmware version
        When the versions are compatible and the baudrates of duet3 board and paneldue are configured right everything should work smoothly.
        Visit me on github at https://github.com/mfs12/
        adhanabal 1 Reply Last reply Reply Quote 0
        • adhanabal
          adhanabal @mfs12 last edited by
          @mfs12 i have paneldue 5i version3.0, firmware version 3.3, duet3 6hc firmware version 3.3,
          Baud rate are same as in the config.g 56700.
          • mfs12
            @adhanabal said in panel due 5i not connecting:
            You said same paneldue is working with your duet2 wifi board with firmware version 1.23? Are you sure that paneldue is having the running version 3.3? I don't think RRF-1.23 and PanelDue-3.3 are compatible.
            • adhanabal
              @mfs12 I reflashed the fimware to 1.23 for checking with duet wifi 2
              • mfs12
                @adhanabal, and what happened? 😉
                • adhanabal
                  @mfs12 the panel due worked with duet2wifi board
                  • mfs12
                    so you tested:
                    • connected firmware paneldue-5.0i with firmware 3.3
                    • with Duet2 Wifi with 1.23 firmware
                    • and this was successful.
                    If not, please provide a detailed step-by-step procedure.
                    • mfs12
                      your paneldue has probably old version. Check the top in the setup tab.
                      • adhanabal
                        @mfs12 I will post photos tmw,
                        And I said I use panel due version 3.0
                        I will provide complete details tmw with photos
                        • mfs12
                          mfs12 last edited by mfs12
                          then please upgrade to paneldue's to firmware version 3.3.
                          I think paneldue-3.0 is incompatible with newer RRF versions. Sorry, for the inconvenience.
                          https://github.com/Duet3D/PanelDueFirmware/releases/3.3.0
                          adhanabal 2 Replies Last reply Reply Quote 0
                          • adhanabal
                            @mfs12 hi i have attached images for your reference, pls check , and also let me know i have wired it correctly.duet3 6hcmb.jpg duet2 wifi.jpg
                            • adhanabal
                              @mfs12 hello all
                              it was my mistake my wiring was wrong i did not properly look at instructions page, thank you for helping me out,
                              please close this issue.
                              mfs12 1 Reply Last reply Reply Quote 0
                              • Topic has been marked as solved  adhanabal adhanabal
                              • mfs12
                                mfs12 @adhanabal last edited by
                                @adhanabal thanks for feedback. Enjoy printing...
