    Solved Replace the wire with Bluetooth Module HC-05
    PanelDue
    • Laiwxn
      Laiwxn last edited by
      I have two HC-05 Buletooth module,I want to use them to replace the wire between the PanelDUE and the main board.Wow,It works very well.😊
      But when I shutdown the mainboard,the paneldue still in standby mode,not the connecting mode.There is no heartbeat between The paneldue and the mainboard? Thanks.
      PCR 1 Reply Last reply Reply Quote 0
      • PCR
        PCR @Laiwxn last edited by
        @laiwxn can you Share the wiring and the Code.
        You could try Resetting the paneldue with M999
        Laiwxn 1 Reply Last reply Reply Quote 0
        • Laiwxn
          Laiwxn @PCR last edited by
          @pcr the paneldue doesn't refresh the status automatically?
          • mfs12
            mfs12 last edited by
            @Laiwxn, the connection times out and some point and get's back into connecting state. In standby tab although, the polling is interrupted.
            Does this also happen in any other tab than setup screen?
            Visit me on github at https://github.com/mfs12/
            • Topic has been marked as a question  mfs12 mfs12
            • mfs12
              mfs12 last edited by mfs12
              Marking as solved due to inactivity. if the issue still persist feel free to reopen the thread.
              • Topic has been marked as solved  mfs12 mfs12
              • Referenced by  JoergS5 JoergS5
