    Solved PanelDue does not connect to Duet2
    PanelDue
    166
    • spirit.robotics
      spirit.robotics last edited by mfs12
      Hello, Im new to DuetWifi, the best motherboard I found and sorry for any mistake in my english. I have and issue with my LCD screen, it not show the right screen, it is totally different to the screen in the DWC. I will appreciatte your help
      I have a DuetWifi, paneldue V3.0 and a separate LCD 7 inch.
      The screen was working fine until I did a new configuration zip file from the web tool, then the LCD start to show the diferent screen. I update the PanelDue firmware (PanelDue-v3-7.0.bin) It look like my firmware is ok.
      My config
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
      Duet WiFi Server Version: 1.26
      Duet Web Control 3.3.0
      Thanks in advance for any help. Best
      weed2all spirit.robotics 2 Replies Last reply Reply Quote 0
      • spirit.robotics
        spirit.robotics @mfs12 last edited by
        @mfs12 Thank everyone for the support, at the end was a firmware issue. I was using the panel due firmware for the V2 version, but my panel is V3. Not it is ok. Thanks again
        • weed2all
          weed2all @spirit.robotics last edited by
          @spirit-robotics seams just about right to me...
          https://www.thingiverse.com/weed2all/designs
          • spirit.robotics
            spirit.robotics @spirit.robotics last edited by spirit.robotics
            @spirit-robotics Yes, It look fine to me too, but still dont show the right screen. I dont thibk could be a hardware issue because it was working ok until yesterday.
            alankilian weed2all 3 Replies Last reply Reply Quote 0
            • alankilian
              alankilian @spirit.robotics last edited by
              @spirit-robotics
              Your Duet is performing the same as mine does.
              Do you expect something different on the LCD screen or do you expect something different in the web browser?
              • weed2all
                @spirit-robotics what do you mean by right screen?it is not supposed to look exactly like DWC!
                • weed2all
                  @spirit-robotics https://duet3d.dozuki.com/Wiki/PanelDue
                  Take a look at dozuki for paneldue...
                  • rjenkinsgb
                    rjenkinsgb last edited by
                    From the paneldue info:
                    Firmware configuration
                    RepRapFirmware 3.x and later: Using a PanelDue with Duet 3 and Duet 2 and RRF3 will require M575 P1 S1 B57600 being present in config.g.
                    RepRapFirmware 2.x and earlier: In RRF2 the command above was assumed as the default, so no additional configuration is required.
                    I'm guessing you have updated the Duet from 2.x to 3.x, so it needs the extra line in config.g to enable the Paneldue communications:
                    M575 P1 S1 B57600
                    Robert J.
                    Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                    • mfs12
                      mfs12 last edited by mfs12
                      @spirit-robotics said in LCD show different screen that DWC:
                      Please update your PanelDue Firmware to version 3.3.0.
                      PanelDue-3.0 and RRF-3.3.0 are incompatible.
                      https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.3.0
                      Visit me on github at https://github.com/mfs12/
                      spirit.robotics 1 Reply Last reply Reply Quote 0
                      • Topic has been marked as a question  mfs12 mfs12
                      • spirit.robotics
                        • Topic has been marked as solved  spirit.robotics spirit.robotics
