    Only probe where printed. Solution here!
    27
    5.9k
      dc42 administrators @Exerqtor
      @exerqtor each GCode input channel has its own set of local variables. So a local variable created by a print file will not be visible from the console.
      Exerqtorundefined 1 Reply Last reply Reply Quote 1
      • supernovaeundefined
        supernovae @PCR
        @pcr said in Only probe where printed. Solution here!:
        @supernovae
        easier solution
        • (Cura slicer plugin) To make the macro to work in Cura slicer, you need to install the post process plugin by frankbags - In cura menu Help -> Show configuration folder. - Copy the python script from the above link in to plugins folder. - Restart Cura - In cura menu Extensions -> Post processing -> Modify G-Code and select Mesh Print Size (PLUGIN)
        the
        M557 X%MINX%:%MAXX% Y%MINY%:%MAXY% S8
        Not sure if you can help, but running the python plugin and enabling the M557 in start gcode I always get a huge max X
        For example:
        looking at the gcode output:
        M557 X131.900:1500.000 Y131.900:168.100 S35.000 ; Leveling mesh defined by LevelingMeshOptimizer
        Not sure where 1500 comes from.. any idea where to look for in fixing/address that? Or anyone getting this in latest cura?
        supernovaeundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @dc42
          @dc42 said in Only probe where printed. Solution here!:
          Well in that case I have no idea what to do except declare them as global instead of local, and reset them to the default in the end of each probing session.
            @exerqtor yes that should work.
              supernovae @supernovae
              @supernovae
              Found the issue, I have some commands to set speed on layers and it shows up as X1500 which the regex catches... maybe i'll try and see if i can limit/exclude it lol
              • Dogma2kundefined
                Dogma2k
                I'm trying to do this on my printer right now, but somehow I can't get S3D to output the min/max XY for the file to be printed.
                Anyone have a tip on how to do this with S3D?
                • engikeneerundefined engikeneer referenced this topic
                • Proschi3Dundefined
                  Proschi3D @PCR
                  This post is deleted!
