    Duet 3 6hc
    240
    • Nino Nobileundefined
      Nino Nobile
      Hello dears,
      I'm having a problem with my Duet 3 MB6HC, I'm just finishing setting everything up. I am using a son z probe printer, and when it is about to start printing for some reason the z axis is raised approximately 5mm.
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.5 on Thu Nov 04 2021 00:44:43 GMT-0300 (hora estándar de Argentina)
      M550 P"CTDA" ; set printer name
      M551 P"12345678" ; set password
      M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.4 S1 ; physical drive 0.4 goes forwards
      M569 P0.2 S0 ; physical drive 0.2 goes backwards
      M569 P0.3 S0 ; physical drive 0.3 goes forwards
      M584 X0.1 Y0.4 Z0.2 E0.3 ; set drive mapping
      M350 X32 Y132 Z128 E32 I1 ; configure microstepping with interpolation
      M92 X168.65 Y168 Z550.00 E1674.00 ; set steps per mm
      M566 X900.00 Y400.00 Z250.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y2000.00 Z500.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X3000 Y4000 Z3000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X1200 Y1000 Z1000 S0 ; set axis maxima
      M574 X1 S1 P"!io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !io1.in
      M574 Y1 S1 P"!io3.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !io3.in
      M574 Z1 S1 P"!io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !io2.in
      M558 P0 H0 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
      M557 X100:1100 Y100:1100 S100 ; define mesh grid
      M308 S0 P"temp0" Y"pt1000" R2200 ; configure sensor 0 as PT1000 on pin temp0
      M308 S1 P"temp1" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
      M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0:1 ; define tool 0
      T0 ; select first tool
      ; homeall.g
      ; called to home all axes
      G91 ; relative positioning
      G1 H1 X-1005 Y-905 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-1005 Y-905 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G1 H1 Z-905 F360 ; move Z down stopping at the endstop
      G90 ; absolute positioning
      G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
      ; homex.g
      ; called to home the X axis
      G1 H1 X-1005 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X5 F6000 ; go back a few mm
      G1 H1 X-1005 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-5 F6000 ; lower Z again
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y-905 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 H2 Y5 F6000 ; go back a few mm
      G1 H1 Y-905 F360 ; move slowly to Y axis endstop once more (second pass)
      ; homez.g
      ; called to home the Z axis
      G1 H1 Z-905 F1800 ; move Z down until the endstop is triggered
      alankilianundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @Nino Nobile
        This post is deleted!
        • fcwiltundefined
          fcwilt @Nino Nobile
          @nino-nobile
          Well since you have no Z probe you are relying on the Z endstop switch to set Z=0.
          But does the endstop switch actually trigger at Z=0? Your Z homing code assumes it does.
          Nino Nobileundefined 1 Reply Last reply Reply Quote 0
          • rjenkinsgbundefined
            rjenkinsgb
            Presumably when it homes Z, that puts the tool some way above the bed / build surface?
            To compensate for that, set the height of the tool over the bed as a negative Z value in the tool G10 offsets line.
            You can move Z manually to just touch the bed and read the Z position off the display or web console.
            (Just built a machine with a 6HC and toolboards, so I've been through all the same stuff recently).
            Robert J.
            Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
              Nino Nobile @fcwilt
              @fcwilt Hello, thank you very much for your answer, I understand what you say but it is not that.
              There is a difference of several millimeters when my endstop is very close to z = 0, it seems that the z axis goes up after home.
              Delete from homeall and home z a line that said G92 Z0, that seemed to work during one print but the next the same problem started again.
              • fcwiltundefined
                fcwilt @Nino Nobile
                @nino-nobile said in Duet 3 6hc:
                The up movement may be caused by the G1 H2 Z5 commands. Since you have a Z endstop you don't need those commands.
                Try the following:
                • remove them from homeZ.g and homeALL.g
                • move the commands that home Z before the commands that home X and Y
                • to be sure that nozzle isn't dragging on the bed when homing X and Y include a command to move Z away from the bed just a bit before the X and Y homing code.
                Then let us know what happens.
                Thanks.
                  Nino Nobile @fcwilt
                  @fcwilt
                  Second failed attempt hahaha
                  This is how my settings have been
                  ; homeall.g
                  G91
                  G1 H1 Z-905 F360 ; move Z down stopping at the endstop; relative positioning
                  ;G1 H2 Z5 F6000 ; lift Z relative to current position
                  ;G91 ; relative positioning
                  ;G1 Z5 F100 ; lift Z relative to current position
                  ;G90 ; absolute positioning
                  ; homez.g
                  • fcwiltundefined
                    fcwilt @Nino Nobile
                    @nino-nobile
                    OK.
                    Did you notice if the Z homing actually took place? Was there Z movement?
                      Nino Nobile @rjenkinsgb
                      @rjenkinsgb I've tried this but it hasn't worked either
