DUet 2 FIREDAMAGE by heat bed burning out connectors
HI every one I had accident ,wile my bord had bed connection with hbed soccet and was damaged by lack of connection , I try to repair it but I Mount SSR 40A to push my bed 500x500 but I realy don know what to do because I connect ssr to bed heater on bord and after this accident I have 27volts in ewery position by Hbed on DWC (off ,stanby ,active ) and this setup heat the bed but for maximum ,and is lack of driving hot bed. What to do ??
Do i can connect somewhere in another place the driving cables for SSR 3-30volts??
Plese Help
sorry form my english
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.3 on Mon Oct 04 2021 22:39:47 GMT+0200 (czas środkowoeuropejski letni); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes forwards
M350 Z16 E16 I0 ; configure microstepping without interpolation
M350 X16 Y16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 E650.00 ; set steps per mm
M566 X700.00 Y700.00 Z30.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z200.00 E600.00 ; set maximum speeds (mm/min)
M201 X5000.00 Y5000.00 Z30.00 E200.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E700 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X500 Y500 Z600 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"zstop" ; configure active-high endstop for high end on Z via pin ^zstop; Z-Probe
M950 S0 C"exp.heater3"
M558 P9 C"^zprobe.in" H5 F100 T2000
G31 P500 X30 Y60 Z8 ; set Z probe trigger value, offset and trigger height
M557 X15:315 Y15:315 S20 ; define mesh grid; Heaters
M307 H0 R0.3 B1 D90 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M308 S1 R4700 P"e0temp" Y"thermistor" T100000 B4267 C0 ; define E0 temperature sensor
M307 H1 B0 R5.133 C253.3 D8.83 S1.00 V16.5 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
T0 ; select first tool -
@bartekp have you solderd the wires to the bed directly??????
@pcr I thing yes I connected one to the ground and seccond to the hbed fuse
@bartekp its looking up the mosfet is death what to do ?
can I avoid hotbed mosfet ad connect signal to the ssr for heat bed? -
@bartekp use a fan output for the SSR if you have a spare one
@jay_s_uk ok how to use should I made some code to config g?
to
M950 H0 C"fan2" T0 ; create bed heater output on bedheat and map it to sensor 0
or, as you're using fan2, use e1heat
M950 H0 C"e1heat" T0 ; create bed heater output on bedheat and map it to sensor 0
@jay_s_uk I have one normally open fan add two controlable
@bartekp this fans I have free , wich i should connect to ssr?
@bartekp B or C.
You'll have to comment out the corresponding line in your config.g though as you currently have fan1 and fan2 assigned to fans
@jay_s_uk Works fine Thanks problem solved
