    CAD Files for Rolling Magnet Monitor
    Filament Monitor
    • guitartoysundefined
      guitartoys
      I trying to design a bracket that will combine the Rolling Magnet Monitor with the filament out switch onto a bracket I have for my filament roll feeder.
      I can find the step files, but want to know if anyone has and could share with me some actual CAD files of the little enclosure, so I could get the actual dimensions, rather than trying to figure everything out from the STEP file.
      I would appreciate it tremendously, and would be happy to share my design when done.
      Thanks.
      Michael
      alankilianundefined Nurgelrotundefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @guitartoys
        @guitartoys You can try measuring from the OpenSCAD or STEP models listed in THIS thread.
        • Nurgelrotundefined
          Nurgelrot @guitartoys
          @guitartoys I just loaded the STL files into https://www.tinkercad.com/ Not as elegant as working with a full CAD program but got the job done to add a simple bracket connector.
          guitartoysundefined 1 Reply Last reply Reply Quote 0
            guitartoys @Nurgelrot
            @nurgelrot Thanks. I I loaded that SCAD file from the other thread.
            PCRundefined 1 Reply Last reply Reply Quote 0
            • guitartoysundefined guitartoys has marked this topic as solved
            • PCRundefined
              PCR @guitartoys
              @guitartoys can you link it?
                guitartoys @PCR
                @pcr https://forum.duet3d.com/topic/25696/filament-monitor-cad-model?_=1637771442922
