    Rounded Corners config.g acceleration parameters
    491
    • j.pickensundefined
      j.pickens
      Trying to reduce my rounded corners. On a 20mm test cube, I get symmetrical bulging in the corners at around 0.1-0.2mm. Not awful, but I'd like suggestions as to changes in my config.g file. I have a Tronxy X5SA-400 Pro modified with an E3D Hemera.
      I get about the same corner overshoot with both a 0.4 and 0.6 nozzle, both with a 60mm/sec print speed and a 45mm/sec outer perimeter speed.
      Not sure if I should look at max. instantaneous speed change, acceleration, or Pressure Advance. Thanks for any feedback.
      Here is the relevant section of my config.g file:
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E430              ; set steps per mm
      M566 X600.00 Y600.00 Z200.00 E8000            ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z2000.00 E20000.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E100.00            ; set accelerations (mm/s^2)
      M204 P1000 T4000                                 ; Set printing and travel accelerations
      M906 X950 Y950 Z950 E950 I30                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M572 D0 S0.001 ; Presure Advanced
      M207 S0.75 R-0.000 F3200 T3200 Z0.0 ; Firmware Retraction
      I have a Duet 2 Maestro.
      Here is the test cube printed at 0.3mm layer height, 0.6mm nozzle:
        Are the bulges only on layer changes where the seam is?
        Your Z axis has a very high top speed, but very low jerk and acceleration. Same for the low accel on the extruder.
        Your pressure advance is also very low. Like by an order of magnitude below what I'd expect for a minimal amount.
        What kind of z axis and extruder do you have?
        j.pickensundefined 1 Reply Last reply Reply Quote 1
          j.pickens @Phaedrux
          @phaedrux The Extruder is a direct drive E3D Hemera
          The Z axis is a dual leadscrew, dual stepper in a coreXY machine.
          The bulges are symmetrical on all 4 corners.
          bubblevisorundefined 1 Reply Last reply Reply Quote 0
            Based on that I would suggest the following changes
            M566 P1
            M203 Z600
            M201 Z120 E4000
            M572 D0 S0.025
            j.pickensundefined A Former User? 2 Replies Last reply Reply Quote 0
            • bubblevisorundefined
              bubblevisor @j.pickens
              @j-pickens Very long 6mm belts often cause rounded corners. I have a saphire plus with the same problem. I am exploring 9 or10mm belts as an upgrade for this very reason.
              Additionally, increasing the moving mass exacerbates this problem.
              j.pickensundefined 1 Reply Last reply Reply Quote 0
                j.pickens @Phaedrux
                @phaedrux Thanks so much!
                I believe the M566 P1 was the trick.
                I put all your suggestions into the config file.
                Here are the vernier caliper measurements of the 20mm test box before and after the changes (Same Gcode used for both):
                Center across X measured along Z axis Before: 19.95mm After: 20.12mm
                X axis measured along X side (includes corners) Before: 20.36 After: 20.11
                Center across Y measured along Z axis Before: 20.09mm After: 20.15mm
                Y axis measured along Y side (includes corners) Before: 20.45 After: 20.15
                So the bulging has gone from approx. 0.4 mm (0.2mm per corner) to ZERO!
                Yay!
                  j.pickens @bubblevisor
                  @bubblevisor I'm sure you are correct about the 6mm belts. The CoreXY design can minimize the effect to some extent due to the pulling from both directions in the design.
                  However, what I was hoping to achieve was to correct the cornering problem as much as possible with the config file settings.
                  With the help of @Phaedrux, I am very happy with the results!
                  • A Former User?
                    A Former User @Phaedrux
                    @phaedrux said in Rounded Corners config.g acceleration parameters:
                    M566 P1
                    M203 Z600
                    M201 Z120 E4000
                    M572 D0 S0.025
                    4000 mm/min2 for the extruder as acceleration? Isn't it too much?
                    engikeneerundefined 1 Reply Last reply Reply Quote 0
                    • engikeneerundefined
                      engikeneer @A Former User
                      @thedragonlord 4000mm/s^2 is reasonably high, but should be no problem unless you have a low power extruder motor (like a pancake motor). A hemera should be able to do 4000mm/s^2 easy.
                      I run my little 25mm pancake extruders at 1600mm/s^2, no sweat and could probably go higher
                      OP had his set at 20mm/s^2 which would be way too low and start impacting xy motion as the extruder wouldn't be able to keep up
                      i3 clone with a bunch of mods
                      • A Former User?
                        A Former User @engikeneer
                        @engikeneer said in Rounded Corners config.g acceleration parameters:
                        It's not for the stepper but for the extruder...I'm afraid that after few hour at 4000 you'll find the BMG pieces on the bed....
                        engikeneerundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                          @thedragonlord OP has a Hemera, not a BMG, so no plastic gears 😉
                          Given how long I've been running my BMGs at this level (plus I previously had them as bowden with big motors, high accelerations and big PA), I doubt they'd fail at 4000mm/s^2! They're more sturdy than you think 🙂
                            Phaedrux Moderator @A Former User
                            @thedragonlord There's very little angular momentum on an extruder motor. The distances moved for direct drive extrusion and retraction are very small. You may hear more clicking as it goes back and forth rapidly, but I don't think there's much more wear and tear. I run 6000 on a titan aero without issue. I thought 4000 was a safe compromise.
