    Mini5 no terminal via USB
    232
    • tecnoundefined
      tecno
      Hi guys,
      Once again my Mini 5 will not work with me. Printer was up and running a few days ago. got a clogged hotend so a bit of maintanence has to be done. Now I can not get any WiFi working as I have no connection via YAT USB terminal. Been searching for answers on how to but can not find.
      So help would be much appreciated.
        Does the mini show up on USB as a device at all?
        Can you try going through the usb firmware update for the mini?
        https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_Ethernet
        Do any lights turn on? You can work through this guide.
        https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @Phaedrux
          @phaedrux said in Mini5 no terminal via USB:
          Hi there, long time no see 😉
          Nothing in YAT
          https://youtu.be/EghtPNOAKw0
            I'd pull it from the case and disconnect everything and go through the what to do if it won't respond guide.
            • tecnoundefined
              tecno @Phaedrux
              Did the reset button and yes I get files showing up in windows
              • tecnoundefined
                tecno @tecno
                @tecno said in Mini5 no terminal via USB:
                A reset did the trick, so my Mini 5 is working again.
                o_lampeundefined 1 Reply Last reply Reply Quote 1
                • o_lampeundefined
                  o_lampe @tecno
                  @tecno
                  Still wondering how a simple nozzle change can cause such a behaviour? Static discharge or what else will you avoid next time?
                  • tecnoundefined
                    tecno @o_lampe
                    @o_lampe
                    Well, it is getting colder and low humidity so static discharge might be a candidate to this.
