    Pausing during printing
    500
    • terencemuscatundefined
      terencemuscat
      I just finished my toolchanger using duet 3 with hemera toolboards. I installed superslicer (latest stable version) and am facing an issue, pausing during printing. I'm trying to print a benchy and im having blops constantly on one side from all the pausing being done during the print. I decreased the processing limit (g1 per second)from 1000 to 150, and the minimum extrusion length up to 0.05 but results remained the same. It's not minimum layer time as I noticed that sometimes it stops multiple times per layer.
      Do you know what maybe is the cause?
      Thanks,
      Terence
      terencemuscatundefined Qdeathstarundefined 2 Replies Last reply Reply Quote 0
        terencemuscat @terencemuscat
        @terencemuscat In addition, I also reduced the speed and the problem is still there. Pausing points are almost in the same place but not exactly, meaning not a problem from the Gcode.
        • terencemuscatundefined terencemuscat marked this topic as a question
        • Qdeathstarundefined
          Qdeathstar @terencemuscat
          @terencemuscat do you have a filament runout sensor installed?
          terencemuscatundefined 1 Reply Last reply Reply Quote 0
          • Phaedruxundefined Phaedrux moved this topic from My Duet controlled machine
            Please try another browser. I've actually noticed some issues with Super slicer lately where certain combinations of settings will produce movement sequences with basically 0 movement speed which makes it seem to pause randomly.
            Inspect the gcode preview in the speed view and see if there are any oddly slow sections.
            engikeneerundefined 1 Reply Last reply Reply Quote 0
            • engikeneerundefined
              engikeneer @Phaedrux
              @phaedrux do you mean a different slicer?
              i3 clone with a bunch of mods
                Phaedrux Moderator @engikeneer
                @engikeneer yes. 🤦🏻
                terencemuscatundefined 1 Reply Last reply Reply Quote 1
                  terencemuscat @Phaedrux
                  @phaedrux same problem with simplify 3D. I noticed it only happens in complicated surfaces, such as rounds.
                    terencemuscat @Qdeathstar
                    @qdeathstar no
                      We'd need to see some more detailed information to help further.
                      Can you share the results of M122 and M98 P"config.g"?
                      Also share your config.g and homing files. A sample sliced gcode file that has the problem would be helpful as well.
