    BED height map problem
    575
    • matej1006undefined
      matej1006
      Hello
      i have bed size 315 x430 mm with 8mm aluminium,
      and i have i still get this height map!
      What you guys think, maybe is too big space between 3 point for auto bed leveling with 3 independent z motor.
      Thanks for any idea where could i have problem.
      fcwiltundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @matej1006
        @matej1006
        What kind of aluminum is it?
        matej1006undefined 1 Reply Last reply Reply Quote 0
          jay_s_uk @matej1006
          @matej1006 my guess would be a sagging gantry
          matej1006undefined 1 Reply Last reply Reply Quote 1
            matej1006 @fcwilt
            @fcwilt
            i order form one German site which have special aluminuim which won't bend as basic aluminium
            i paid much more for it
            • fcwiltundefined
              fcwilt @matej1006
              @matej1006 said in BED height map problem:
              @fcwilt
              Can you provide a link to the site?
              Thanks.
                matej1006 @jay_s_uk
                @jay_s_uk Hello Jay
                maybe you will remember my problem hehe.
                i will add some picture of my gantry and whole core-xy
                  matej1006 @fcwilt
                  @fcwilt i will try to find it long time pass from when i ordered.
                  i think is like 18 month's
                  CanDo415undefined 1 Reply Last reply Reply Quote 1
                  • CanDo415undefined
                    CanDo415 @matej1006
                    @matej1006
                    Do you use a magnetic bed?
                    I have the same problems with a 355x355 bed.
                      matej1006 @CanDo415
                      @cando415
                      yeah from ziflex, realy and also like almost 1mm deviation
                      CanDo415undefined 1 Reply Last reply Reply Quote 0
                      • CanDo415undefined
                        CanDo415 @matej1006
                        @matej1006
                        tyr the mapping cold and compare with a hot mapping. I think the differences are a problem of the magnethight
                          matej1006 @CanDo415
                          @cando415 i did and there was not a lot of difference
                          • CanDo415undefined
                            CanDo415 @matej1006
                            @matej1006 so the temperature is not the problem
                            • T3P3Tonyundefined
                              T3P3Tony administrators @CanDo415
                              @cando415 if you have a straight edge you will be able to confirm quickly that its not the bed that is that warped. I think @jay_s_uk was right with the gantry.
                              www.duet3d.com
                                matej1006 @T3P3Tony
                                @t3p3tony yeah i will just unscrew a little all screw in linear rail and then try.
                                Maybe i have ma linear rails in back more closer than in the front of printer.
                                i hope is that 😉
                                Matej
