    Toolboard 1lc v1.2 will support 2×65w heaters?
    toolboard e3d heater slice engineering
    • SilviuZundefined
      SilviuZ
      Hello everyone.
      I have a mosquito magnum+ and I am wondering if it is possible to change the heaters ( slice engineering 2 × 50w) with 2× 65w E3D high temperature heaters.
      I know that I will be just over 5A.
      There is any margin up to 5.5A?
      Ps. I am running 30v
      PCRundefined T3P3Tonyundefined elmoretundefined 3 Replies Last reply Reply Quote 0
      • Phaedruxundefined Phaedrux moved this topic from General Discussion
      • PCRundefined
        PCR @SilviuZ
        @silviuz just use a external MOSFET?
        SilviuZundefined 1 Reply Last reply Reply Quote 0
        • SilviuZundefined
          SilviuZ @PCR
          @pcr yes it's a option... but I was wondering about the limitations of the toolboard
          • T3P3Tonyundefined
            T3P3Tony administrators @SilviuZ
            @silviuz said in Toolboard 1lc v1.2 will support 2×65w heaters?:
            AFAIK the 65W heaters are rated at 65W at 24V so draw 2.71A at 24V and are nominally 8.85Ohms. If you run them at 30V you will draw 3.39A each and so they will be 102W heaters, each. That's probably not a good idea for those heater cartridges, let alone way more than we have rated the input for the toolboard.
            www.duet3d.com
            SilviuZundefined 1 Reply Last reply Reply Quote 2
            • elmoretundefined
              elmoret @SilviuZ
              Hello everyone.
              There is no way you need 204 watts in a Mosquito Magnum+. I doubt you could use even 80 watts, and that’s if you were printing PEEK at 80mm^3/sec.
              It takes very little heat to melt polymer, on the order of 1 watt per cubic mm/sec.
              • SilviuZundefined
                SilviuZ @T3P3Tony
                @t3p3tony thank you for your reply. I will use a mofset
