Circuit, PCB analysis tools
@JoergS5 I use a domestic electric hotplate for reflow soldering small prototype boards. No need for a reflow oven unless you are going into production.
Thank you all for your feedback, so a reflow oven would be exaggerated. I'll look into your proposals.
@dc42 said in Circuit, PCB analysis tools:
that's intersting, maybe I can solder with this my solar modules (I bought raw cells) with tab wire as well. I can buy a cheap one for 260 °C. Is this sufficient, or do I need one with variable temperature, there is one for 50 to 350 °C.
The cheap one is https://www.amazon.co.uk/POHOVE-Heating-Soldering-Heating-Soldering-Laboratory/dp/B08XJGJN59 and the 50..350 is https://www.amazon.co.uk/Microcomputer-Electric-Heating-Preheating-Soldering/dp/B07WJ4THGP
@joergs5 , you may want to look also for hot plates that are intended for PCB reflow. There are many on Aliexpress and amazon and typically they come with good temperature display and control.
E.g.
https://www.aliexpress.com/item/1005002103189787.html
Make sure to pick a hot plate that gets hot enough to reflow the solder you use. Some plates are used for 'preheating' which requires lower temperatures, below solder melting point.
https://www.youtube.com/watch?v=bz6OONg5hmg
You may want to look also on youtube for PCB paste/stencil techniques.
@zapta thanks a lot for your hints! I am used to look for videos first, but in this case I forgot to search for it.
There are big differences of prices...
I saw the video now, I am really surprised to learn something new, that avoiding temperature shock is an important reason.
@joergs5, when I was still using the reflow oven I looked for way to simplify the paste and part placement process. Some of my attempts included 3D printed parts like the ones below but eventually gave up on solder paste all together. YMMV
https://www.thingiverse.com/thing:1119914
https://www.thingiverse.com/thing:675336
the last hour I'm thinking about how
- to place the paste onto the PCB with the robot arm
- fix the PCB on the heating plate
- control the quality of paste and SMB elements with camera and OpenCV
Similar to what you've done with your thingiverse objects.
@joergs5 said in Circuit, PCB analysis tools:
Now having a few days for learning something new, I would be interested in analysing circuits and learning electronics. Maybe buying a reflow oven and experimenting.
control the quality of paste and SMB elements with camera and OpenCVI would very seriously suggest you get past the basics of designing and building / programming conventional circuits, using prototyping boards or stripboard etc., before even considering anything to do with surface mount assembly!
Surface mount is great for mass production, once designs are proven - but it is definitely not a good way of learning basic electronics or prototyping general circuits.
Even commercial designs that will eventually be surface mount construction often have the first prototypes built with conventional components - it's far easier to change parts or modify things, than on a fixed-layout surface mount PCB.
@rjenkinsgb said in Circuit, PCB analysis tools:
Sorry if you got a wrong impression of my knowledge. I learned electronic basics 43 years ago, when I made my ham radio exam. I have gaps in my knowledge like IGBT and which software to use, but I have electronic knowledge. And I love soldering. Currently I use breadboards for trying out new ideas, but they are unstable for normal usage.
I learned electronic basics 40 years ago, when I made my ham radio exam.
OK, sorry for the misunderstanding; I got the impression from your initial post that you were a complete beginner.
[Also a radio ham for 40+ years - G8TBF / G0WTK]
control the quality of paste and SMB elements with camera and OpenCVYou may want to look also at prior art in the area of makers' SMD assembly techniques and tools. There are all kind of attempt to make the process less painful and more efficient.
For example, this for automated pick and place https://openpnp.org or this for reflow temperature stabilization using vapor phase https://www.youtube.com/watch?v=czwRntpEzgg . DIY SMD technology can be an interesting hobby on its own.
@joergs5 I doubt that you will be able to achieve accurate solder paste placement for fine pitch components using a robot arm. When I was building SMD prototypes, I used to buy a cheap Mylar solder stencil. Hobbytronics does them in the UK, and Pololu in the US. JLCPCB now sells inexpensive stainless steel ones too.
@zapta the OpenPnP is very interesting!
For Colophonium application I thought, a peristaltic pump may be a possible solution.
I ordered the 946C plate now, I am looking forward to experiment.
@joergs5, les us know how it works for you.
If you plan to get into paste dispensing, you can find ideas on youtube https://www.youtube.com/results?search_query=solder+paste+dispenser and aliexpress https://www.aliexpress.com/af/solder-paste-dispensing.html
One approach that may be promising, which I never tried, is compressed air based dispensing like this one https://www.aliexpress.com/item/4000785130294.html
@zapta said in Circuit, PCB analysis tools:
https://www.youtube.com/watch?v=AC5BB0ae2Hg shows the internals...
Thanks for all you hints. The idea to combine SMD mounting with robot arm is a low priority project, however. Main topic is to finish the 6 axis robot.
This post is deleted!
