    4010 vs 4020 Fan what is better?
    4.4k
    • A Former User?
      A Former User
      Good morning, In order to have a better piece cooling what fan is best between 4010 and 4020 (24VDC)?
      I suppose 4020 can produce more static pressure so it could be better but it requires more effort designing the support because it's bigger.
      Will this effort repay in terms of better part cooling?
      Thanks
      Andrea
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @A Former User
        @thedragonlord your two fans seem to be different, axial and radial, an article about it is eg https://paulsfans.com/blog/difference-axial-radial-fan
        I happened to have to make the same decision yesterday between 40 mm Noctua fans. I decided by lower noise, how many space I have, air flow and price (for my preferences in this order). For noise level, a difference of + 6 dB means doubling of the noise.
        • A Former User?
          A Former User @JoergS5
          @joergs5 said in 4010 vs 4020 Fan what is better?:
          they are both radial
          • JoergS5undefined
            @thedragonlord according to Noctua, the 20 has more air pressure than the 10. I decided for the 10 because of space, however.
            • A Former User?
              ok, thanks
              • oliofundefined
                oliof
                if this is for part cooling you'll find way more designs using 5015 blowers than 4020.
                • A Former User?
                  A Former User @oliof
                  @oliof said in 4010 vs 4020 Fan what is better?:
                  I have enough space for two 5015 so I can use a 4020 as the "biggest"... is there a great difference in term of efficency between them?
                  • achrnundefined
                    achrn
                    Which 4010? Which 4020? Which 5015?
                    As far as I know, Noctua do not make any radial fans - only axial.
                    • A Former User?
                      A Former User @achrn
                      @achrn said in 4010 vs 4020 Fan what is better?:
                      I have never talked about Noctua.. in my opinion they are totally unuseful for part cooling...
                      engikeneerundefined achrnundefined 2 Replies Last reply Reply Quote 0
                      • engikeneerundefined
                        engikeneer @A Former User
                        @thedragonlord my general finding is that bigger means more air flow which is what you want for part cooling.
                        However, there are also massive differences between different makes of fans for the same size. I had a 4010 radial fan on my delta that I got cheap from ebay which barely did anything. I then bought one of the GDSTime 4010 radial ones, similar to what E3D use on the hemera tool, which is pretty decent. Ideally I'd still like more cooling though in some cases...
                        i3 clone with a bunch of mods
                        • achrnundefined
                          achrn @A Former User
                          @thedragonlord said in 4010 vs 4020 Fan what is better?:
                          Fourth post in the thread does, though.
                          I'd still be interested in seeing what 4010 / 4020 / 5015, 24V, centrifugal blowers you are considering - 24V centrifugal fans seem to be relatively rare beasts, so a source of a good one would be useful to know.
                          • A Former User?
                            https://www.amazon.it/gp/product/B07HRH15R1/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
                            • A Former User?
                              A Former User @engikeneer
                              @engikeneer said in 4010 vs 4020 Fan what is better?:
                              Doesn't Hemera use a radial 4020 for part cooling? Like this https://www.amazon.it/gp/product/B07HRH15R1/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
                              engikeneerundefined 1 Reply Last reply Reply Quote 0
                                @thedragonlord nope, it's a 4010 radial:
                                https://e3d-online.com/products/hemera-tool-upgrade-kit
                                Admittedly they dont make that very clear on the product pages...
                                • A Former User?
                                  no, they don't...
