    No connection - need WAC
    955
    • gabitundefined
      gabit
      my duet 2 ethernet lost the connection after printing.
      this was often for a few seconds so that the browser said no connection but it comes again. In this time i could handle the printer with the display.
      Now there was no reaction via display
      i tryed many things and remove it from the machine.
      I can get any connection wia pc or mac.
      I think it is out of order.
      My reseller in Berlin "filafarm" tell me to fill out the form
      what can i do, i need the machine.
      Please help me or send me a vat
      Stefan
      • chrishammundefined
        chrishamm administrators @gabit
        @gabit What firmware are you using? It may be outdated, so consider upgrading. If the network connection is lost in regular intervals, consider assigning a fixed IP address.
        Duet software engineer
        • gabitundefined
          gabit
          i tryed also a fix ip Adress, nothing changed in the past.
          my start of the actual config.g
          M550 P"cnc" ; set printer name
          M551 P"******" ; set password
          M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
          M586 P0 S1 ; enable HTTP
          M586 P1 S1 ; enable FTP
          M586 P2 S0 ; disable Telnet
          How can i get the firmware version of a not running system?
          • gabitundefined
            gabit
            i can get a serial connection to the board, it does not apear
              @gabit Please share the output of M122 from the serial console so we can see what firmware version you are using.
              gabitundefined 1 Reply Last reply Reply Quote 0
              • oliofundefined
                oliof
                is this a standalone or SBC (Raspberry Pi) setup?
                  chrishamm administrators @oliof
                  @oliof He's using a Duet 2 Ethernet so standalone mode.
                  gabitundefined 1 Reply Last reply Reply Quote 1
                  • gabitundefined
                    gabit @chrishamm
                    @chrishamm i can get a serial connection, it is not listed via ls tty.*
                    also on pc, i tryed also 3 diffrent usb cables
                    • gabitundefined
                      gabit
                      i tryed via a raspberry connection.
                      there i see the ttyAMA0 device
                      When i connect i get no prompt and can not send any command
                      i think the board is out of order
                      • gabitundefined
                        gabit
                        And now??
                        Who to get a WAC??
                        • gabitundefined
                          gabit @chrishamm
                          @chrishamm
                          Hi, what are the next steps?
                          I need my printer and i´m looking for a resulution
                          alankilianundefined 1 Reply Last reply Reply Quote 0
                          • alankilianundefined
                            alankilian @gabit
                            @gabit
                            Have you followed the process described on THIS page?
                            Step 1, disconnect EVERYTHING and plug in just a USB cable between the board and a computer and tell us what lights are lit.
                            • gabitundefined
                              gabit
                              Yes I did
                              2 red led
                              Power and 5v
                              Nothing at Ethernet plug also cable connect
                              The same with removed sd card
                              • gabitundefined
                                gabit
                                the red power cable is not connected
                                  alankilian @gabit
                                  @gabit
                                  If the red LEDs are lit but not the green 3.3V LED then most likely there is a short
                                  between the 3.3V power rail and ground.
                                  Since you have everything disconnected, you should not have a short, so I think your 3.3 Volt regulator has failed.
                                  Several people have had this happen when trying to connect endstops or BLTouch sensors and they accidentally connect the 3.3 Volt supply to ground.
                                  • gabitundefined
                                    gabit @alankilian
                                    @alankilian said in No connection - need WAC:
                                    we could this happen, the board disconnected in a printing pause. Nothing can be create short on the board.
                                      alankilian @gabit
                                      @gabit
                                      Do you have a volt meter?
                                      You could check the 5 Volt input on U2 and the 3.3 Volt output on the same chip and see if it has failed.
                                      I can provide a diagram if you need it.
                                        When and where did you purchase the Duet?
                                        • gabitundefined
                                          gabit @Phaedrux
                                          @phaedrux
                                          19.04.2021 by filafarm (berlin/germany)
                                          • gabitundefined
                                            gabit @alankilian
                                            @alankilian
                                            yes i have a multimeter, but dont undersoot where to messure
                                            at the expansion connector
                                            between 1-2 -> 4.5V
                                            between 3-2 -> 0,2V
                                            alankilianundefined dc42undefined 2 Replies Last reply Reply Quote 0
