Surfacing Macro
With 3.3 you should still be able to pass a parameter in the macro call. You’ll just have to modify the macro (hopefully only once!) to assign that parameter to the DOC variable (e.g. var DepthOfCut= {param.y} )
It’ll still be a manual process of entering the parameter each time you start the macro, but it should save you the trouble of having to change the DOC variable within the macro each time.See the macro parameter section at this link:
https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands
@HebigT @HebigT I'm not sure I understand what you are saying here.
Is there an actual command (and presumably through a screen interaction) in v3. 3 which allows a user to type in and enter a value, and to then assign this value to an existing variable?I still cannot find any means of entering an external value. I am still having to resort to having multiple versions of this macro, each wirh different values for doc.
I'm not sure if I'm being a bit too simplistic here, but this is what I do, after producing the GCode toolpath for surfacing, usually with a 0.15mm depth of cut, or sometimes more...
Run the toolpath. Once complete, if there are still low spots, lower the spindle/motor to Z0, then lower it again to the toolpath's cut depth (0.15mm), reset Z0 and rerun the toolpath.
Continue as necessary, but as you get closer to 'flat', you could reduce the 0.15mm accordingly.
@OwenD
Isn't there a way to start the macro by doubleclicking and ask for the DOC-value from within the macro? -
@o_lampe
Not unless you update to RRF version 3.5.0b1
Then you can ask for input use M291 as mentioned above -
Thank for all your ideas, guys. I does seem that I can't achieve what I want whilst on v3.3.
So I am in the hands of Ooznest and will have to wait to see when / if they decide to release a later version of their firmware.
Of course, this macro would make a great plug-in, and so getting around this data input issue!
So I am working on a new version of this Macro that will prompt for user input with the M291 command. It will make the Macro far more interactive for things like DepthOfCut, RPM, FeedRate, etc. One of the prompts I want to add is to ask if it should work in Pass mode or Depth mode.
In pass mode it will prompt you for the number of passes to take. It will then do that many passes before prompting you whether to surface another layer. Default will obviously be 1.
In Depth mode it will prompt you for how much material to remove. So if your DepthOfCut is say 0.3mm and you enter a depth of 1mm the Macro will do three passes at 0.3mm and then a fourth pass at 0.1mm for a total of 1mm.
undefined CthulhuLabs referenced this topic
