How i crimp those terminals?
In Duet v3 mini package comes with 4 terminals like this:
I suppose that are for POWER IN and OUPUT 0
If I plan conect bed heater with a relay... OUPUT 0 for nozzle heater cartridge? (think remember 50w)
What are his name?
I can crimp without specofoc tool? -
@fcwilt now .... the problem is that I already have two crimpers, and buy one more for 4 connectors ... well ... I don't feel like it ....
Sell them all and buy one with interchangeable jaws.
@phaedrux I'll check tomorrow, but I think 1 of the two can crimp those terminals, sounds like it has those notches on the bottom
Yes these terminals require a fairly simple crush.
The connector for power in and Vout is a 4 way barrier strip, so you could simply not use the connector and clamp the wires in the terminal block. Arguably that might give a better connection than a poorly crimped fork connector.
@peirof said in How i crimp those terminals?:
Check local electrical suppliers, you should be able to get just a tool similar to the one in that kit very cheaply - eg.
https://www.toolstation.com/minotaur-ratchet-crimping-tool/p46714Or anyone you know who is an electrician or works on vehicle electrics probably has one you could borrow to do those terminals.
And as deckingman says, there is nothing wrong with just using wires in the screw terminals; the crimps just make it easier to re-connect if you ever need to and avoid stray strands that could short something.
Well the one I listed has interchangeable dies - perhaps it does what you have and you could get rid of one or two of your existing tools.
I'm not going to say how many crimpers I own. I will say I buy the tools the manufactures suggest.
Good luck.
@peirof standard red/blue/yellow automotive crimp tools will crimp these terminals. There are ratchet tool to crimp these as well as low-cost non-ratchet tools that are included in generic tool kits, similar to https://www.amazon.co.uk/Rolson-Multi-Purpose-Crimping-Tool/dp/B004V9AROU (this is not a recommendation).
For this kind of connector I like this Wirefy crimper. It has flat jaws that doesn't damange the insulation.
https://www.amazon.es/Wirefy-Herramienta-conectores-eléctricos-herramienta/dp/B07GFXHH91
If it's just 4 of them, and I didn't have the proper crimper, I'd cut off the insulation, slip a piece of heat shrink tubing over the wire, solder the lug to the wire, then slide the heat shrink up and shrink it. Done.
Slightly off-topic, but still about wiring... I'm a big fan of Wago lever nuts to hold bare wires without lugs. Now if we could just talk power supply and SSR makers into using lever nut type terminals... I used a bunch of the 5 position Wagos in my printer's wiring to set up buses for 24VDC, line power, ground, etc. Want to add an LED strip to light up the print area? Just route the wires, strip the ends, snap them down. Very easy and reliable, they accommodate any wire size you're likely to use.
@mrehorstdmd, Wago are very popular in the Voron world and there are various 3D models for mounts for them.
On my printer I am using jumpered Dinkle Din rail posts with ferrules on the wire ends.
@mrehorstdmd I discovered last week that there are wago for connecting wires:
221-2411 and adapters "inline splicing connector" and there is a new things repository for wago https://wago-creators.com/I will probably use them to extend stepper wiring instead of Microfit (I still don't like crimping....).
@joergs5 That's a great link! I'll post my wire twister and maybe some of my printed mounts to it. Thanks!
Wago lever nuts are a great way to connect the wires to the bed heater and thermistor...
@joergs5, Wago are very popular in the Voron world but I think they are typically used for power connections. E.g. (not my printer):
Microfit has the advantage that they are compact, easier to connect/disconnect and reduce the chance of reconnecting incorrectly.
@zapta said in How i crimp those terminals?:
those are valid arguments. I'll stay with wago however, because I still search connectors which can be assembled automated and Wago allow connecting without decision about the crimp system.
I'm trying Microfit now, does someone know how to crimp them? I would like to use PA-09/20/21, is this a suitable tool and which widths do I need?
I often destroy the crimp when I press it together, it bends very much or the wires "escape". Does someone have a hint for me?
