    Smert effector tilting during bed leveling and print
    • lildannyosoundefined
      lildannyoso
      I am experiencing some pretty intense tilting during printing and bed leveling seen here. Ignore the fan sticking up, I have to print another duct for it. I am using an Anycubic Predator with a Duet 2 Ethernet board and a Duet Smart Effector. Here is my config.g file:
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 20 2020 19:57:06 GMT-0500 (Central Daylight Time)
      M550 P"Anycubic Predator" ; set printer name
      M665 R227 L440.45 B185 H410 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 P192.168.86.37 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S0 ; physical drive 2 goes forwards
      M569 P3 S0 ; physical drive 3 goes forwards
      M92 X80.00 Y80.00 Z80.00 E415.00 ; set steps per mm
      M566 X1500.00 Y1500.00 Z1500.00 E1500.00 P1 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E10000.00 ; set maximum speeds (mm/min)
      M201 X1500.00 Y1500.00 Z1500.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; Retraction
      M207 S1.9 F3000 Z0.388 ; Firmware retraction
      M208 Z0 S1 ; set minimum Z
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
      M591 D0 P7 C"e0stop" L7 R50:200 E15 S1 ; filament sensor connected to e0_stop
      M558 P8 R0.4 C"zprobe.in+zprobe.mod" H10 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z.1 ; set Z probe trigger value, offset and trigger height
      M557 R180 S20 ; define mesh grid
      M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"pt1000" R4700 ; configure sensor 1 as PT1000 on pin e0temp
      M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
      M563 P0 S"Hotend" D0 H1 F1 ; define tool 0
      M572 D0 S0.2 ; pressure advance
      M501 ; set the active parameters to those stored in sys/config-override.g
      and my bed.g file:
      ; bed.g
      ; called to perform automatic delta calibration via G32
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 20 2020 19:57:05 GMT-0500 (Central Daylight Time)
      G28 ; home all towers
      G1 E-1.9 F300 ; retract a little
      ; Probe the bed at 6 peripheral and 6 halfway points, and perform 6-factor auto compensation
      ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
      G30 P0 X0 Y179.9 H0 Z-99999
      G30 P1 X155.8 Y89.95 H0 Z-99999
      G30 P2 X155.8 Y-89.95 H0 Z-99999
      G30 P3 X0 Y-179.9 H0 Z-99999
      G30 P4 X-155.8 Y-89.95 H0 Z-99999
      G30 P5 X-155.8 Y89.95 H0 Z-99999
      G30 P6 X0 Y89.9 H0 Z-99999
      G30 P7 X77.86 Y44.95 H0 Z-99999
      G30 P8 X77.86 Y-44.95 H0 Z-99999
      G30 P9 X0 Y-89.9 H0 Z-99999
      G30 P10 X-77.86 Y-44.95 H0 Z-99999
      G30 P11 X-77.86 Y44.95 H0 Z-99999
      G30 P12 X0 Y0 H0 Z-99999 S6
      ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
      ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
      G29 ; grid map
      and finally my config-overide.g file:
      ; config-override.g file generated in response to M500 at 2020-07-24 15:47
      ; Delta parameters
      ;M665 L440.000:440.000:440.000 R226.608 H421.396 B185.0 X-0.123 Y0.106 Z0.000
      ;M666 X0.742 Y-0.494 Z-0.248 A0.00 B0.00
      ; Heater model parameters
      M307 H0 A122.6 C715.7 D0.6 S1.00 V24.0 B0
      M307 H1 A315.0 C177.6 D3.4 S1.00 V24.2 B0
      ; Workplace coordinates
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
      o_lampeundefined jay_s_ukundefined rjenkinsgbundefined 3 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @lildannyoso
        @lildannyoso
        A tilting effector is always a hardware/mechanical thing.
        Beginning with equal rod length and tower angles/frame geometry.
          jay_s_uk @lildannyoso
          @lildannyoso I recognize that cooling arrangement 😊
          As @o_lampe says, it's always mechanical.
          What rods do you have?
          It's always worth giving everything a once over. Check where your rods attach, check the rollers, check that you haven't got belt stretch. Also make sure the nut on your hotend hasn't come loose.
          • Leavundefined
            Leav
            The distance between the rods must be the same at the top and the bottom of the rod (carriage side and effector side) for the parallelogram to be created.
            Either the smart effector needs to be rotated 60 degrees, or your carriages are incompatible with the smart effector and you need to make an adaptor.
            Does that help?
            • rjenkinsgbundefined
              rjenkinsgb @lildannyoso
              @lildannyoso
              Looking at the video, you don't appear to be using the Smart Effector PCB adapters on the vertical rail carriages?
              A delta printer mechanism relies on each pair of rods always being absolutely parallel.
              If there is even the slightest difference, a fraction of a millimetre, in joint spacing between the two ends of the link arms/rods, the overall geometry of the machine will be wrong and the effector will tilt.
              That's why you get the adapters in the kit, to guarantee correct spacing at both ends of the arms.
              They can be on top of or sandwiched in a printed carriage, but those need to be what define the rod spacing.
              Robert J.
              Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                lildannyoso
                Solved: One of my rods had come loose.
