    PanelDue White screen after firmware update
    PanelDue
    512
    • Kris75undefined
      Kris75
      I have an issue with my PanelDue 5i integrated board v1.0. The problem is that, after firmware update it displays nothing but a white screen.
      1). I am uploading the version 1.24, the PanelDue-v2-5.0.bin file, after the reset, there is a white screen and no response to touch
      2). I am loading version 1.24, the PanelDue-5.0i-7.0i.bin file, after the reset, there is a white screen, the screen makes a sound when I touch in places where the screen calibration points should be, after clicking on the last point the screen displays gray stripes, reacts with a sound when touching random places on the screen.
      3). I am loading version 1.24, the file PanelDue-v3-5.0.bin - the reaction is the same as in point 2.
      I was loading various versions from 1.17 to 3.4.0 with v2 and v3 files for PanelDue5i - screen is still white.
      I am using Boss 1.9.1, when flashing I select Erase All, Boot to Flash and Lock
      Can someone tell me what might be causing the problems and how to solve them?20220118_173820.jpg 20220118_134747.jpg
      Nurgelrotundefined 1 Reply Last reply Reply Quote 0
      • Nurgelrotundefined
        Nurgelrot @Kris75
        @kris75 When mine did this it was because I flashed it with the wrong firmware file. In my case I confused the 7i with the 7 v3. Erasing and reflashing corrected it.
        Kris75undefined 1 Reply Last reply Reply Quote 0
        • Kris75undefined
          Kris75 @Nurgelrot
          @nurgelrot said in PanelDue White screen after firmware update:
          I was uploading all files from different versions available on github, all on a white screen.
            I believe this should be the correct file
            https://github.com/Duet3D/PanelDueFirmware/releases/download/3.4.0/PanelDueFirmware-3.4.0-5.0i.bin
            The screen doesn't look white though in your photo, it looks like there are stripes as if the LCD is failing.
            Was the Paneldue working previously?
            • Kris75undefined
              Kris75
              @phaedrux said in PanelDue White screen after firmware update:
              yes, it worked before. The bars appear when I load the PanelDue-5.0i-7.0i.bin file, e.g. since version 1.24
              • Kris75undefined
                Kris75 @Phaedrux
                Unfortunately, PanelDueFirmware-3.4.0-5.0i.bin is not working.
                after the reset there is a white screen, the screen makes a sound when I touch in places where the screen calibration points should be, after clicking on the last point the screen displays gray stripes, it reacts with a sound when you touch random places on the screen.
                  Phaedrux Moderator @Kris75
                  @kris75 said in PanelDue White screen after firmware update:
                  Are you saying firmware before 1.24 still work correctly?
                  • Kris75undefined
                    Kris75 @Phaedrux
                    No. Now no software works.
                    I was uploading versions from 1.17 to 3.4 - it does not work
                      Can you show a screen shot of your Bossa window so we can verify the settings?
                      • Kris75undefined
                        Kris75 @Phaedrux
                        ok. This is a sample file from version 1.24
                        • Kris75undefined
                          Kris75
                          Can anyone help? Is the paneldue to be thrown into the garbage?
                            Can you post a better photo of the screen? It looks more like the screen is damaged than a firmware problem.
