    Bed level speed?
    • Chrissundefined
      Chriss
      Hi *,
      I have a question regarding the ravel speed at "G30 P?". The head moves very slow between the points I address with "G30", is there a way to speed that up?
      Speed settings:
      M566 X900 Y900 Z20 E3600        ; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 Z3000 E5000  ; Set maximum speeds (mm/min)
      M201 X2000 Y2000 Z100 E800      ; Set maximum accelerations (mm/s^2)
      M204 P500 T2000                 ; Set printing acceleration and travel accelerations
      bed.g
      M564 S0 ; Disable protection
      while iterations <=1            ; Perform 2 passes.
      	G30 P0 X50 Y0 Z-9999		; probe left leadscrew
      	G30 P1 X400 Y0 Z-9999		; probe right leadscrew
      	G30 P2 X200 Y330 Z-9999 S3 ; probe leadscrew at the end
      	G1 H2 Z8 F2600              ; raise head 4mm to ensure it is above the Z probe trigger height
      	M400                        ; finish move, clear buffer
      while move.calibration.initial.deviation >= 0.003 ; Perform additional leveling if previous deviation was over 0.01mm.
      echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained."
      M564 S1 ; Enable protection
      G1 X200 Y200    ; Back to the middle
      Cheers, Chriss
        jay_s_uk @Chriss
        @chriss the travel speed is determined by the T value in M558
        Chrissundefined 1 Reply Last reply Reply Quote 0
        • Chrissundefined
          Chriss @jay_s_uk
          @jay_s_uk
          Thanks..... what a shame... 😉
          M558 P9 C"121.io0.in" H5 F120 T6000		; set Z probe type to bltouch and the dive height + speeds
          Cheers, Chriss
          engikeneerundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • engikeneerundefined
            engikeneer @Chriss
            @chriss you can always add a G1 move between each of the points at a faster rate. Maybe only part way, so the last 10mm are at a slower speed incase your probe needs any recovery time?
            i3 clone with a bunch of mods
            • Chrissundefined
              Chriss @engikeneer
              @engikeneer I tried that, to be honest, but the G1 was not really faster surprisingly. Anyway, that did it for me. I have other open flanks with that build. 😉
              Cheers, Chriss
                dc42 administrators @Chriss
                @chriss said in Bed level speed?:
                Why is it a shame? Why don't you increase the M558 T parameter to 18000?
                • Chrissundefined
                  Chriss @dc42
                  @dc42 The shame was for my comment of "M558", I noted already "speeds" and did not see it so I asked here. 😞
                  Cheers, Chriss
