    ZERO KELVIN HOTEND TEMP
    881
    • adalton5683undefined
      adalton5683
      sorry for yelling
      So I was struggling to get everything lined up and probe working and motors and yeah lots of struggles and finally, once I feel like I have everything done and now I can start printing test prints, when I go to tune my heaters I notice that the hot end is always showing -273 and for both active and standby. ive tried all configs on it and cant seem to get to a place to even tune it.
      heres my config.g
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Jan 25 2022 20:05:51 GMT-0600 (Central Standard Time)
      G90                                                   ; send absolute coordinates...
      M83                                                   ; ...but relative extruder moves
      M550 P"bEnder vE3D"                                   ; set printer name
      M569 P0.0  S0                                          ; physical drive 0.0 goes backwards
      M569 P0.1  S0                                          ; physical drive 0.1 goes backwards
      M569 P0.2  S1                                          ; physical drive 0.2 goes forwards
      M569 P0.3  S0                                          ; physical drive 0.3 goes backwards
      M584 X0.0  Y0.1  Z0.2   E0.3                          ; set drive mapping
      M350 X16   Y16   Z16    E16   I1                      ; configure microstepping with interpolation
      M92  X80   Y80   Z400   E397.5                 		  ; Max Inst Speed Changes - Steps/mm -
      M566 X900  Y900  Z60    E300               	   	      ; Speed - mm/min
      M203 X9000 Y9000 Z600   E3000          		          ; Max Speed - mm/min
      M201 X500  Y500  Z100   E6000                         ; Acceleration - mm/s^2
      M906 X700  Y700  Z700   E1200  I30                    ; Motor Current | mA - Idle | %
      M204 P800  T4000					                  ; Print/Travel Acceleration - mm/s^2
      M84 S30                                               ; Idle timeout
      M208 X-117 Y-117 Z0 S1                                ; set axis minima
      M208 X117 Y117 Z250 S0                                ; set axis maxima
      M574 X1 S1 P"io0.in"                                  ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in"                                  ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      M574 Z1 S2                                            ; configure Z-probe endstop for low end on Z
      M574 Z2 S1 P"io2.in"                                  ; configure active-high endstop for high end on Z
      M950 S0 C"io3.out"                                    ; create servo pin 0 for BLTouch
      M558 P9 C"io3.in" H5 F120 T6000                       ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-57 Y-7 Z2.5                                ; set Z probe trigger value, offset and trigger height
      M557 X-95:95 Y-95:95 S3                               ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T98801 B4185           ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T1                                    ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1                                         ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                               ; map heated bed to heater 0
      M143 H0 S30                                         ; set temperature limit for heater 0 to 120C
      M308 S0 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1                                         ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S300                                          ; set temperature limit for Hot End to 300C
      M143 H0 S120                                           ; set temperature limit for Bed to 300C
      M950 F0 C"out3" Q30                                   ; create fan 0 on pin out3 and set its frequency
      M106 P0 C"PartCool" S0 H-1                            ; set fan 0 name and value. Thermostatic control is turned off
      M950 F1 C"out4" Q30.                                  ; create fan 1 on pin out4 and set its frequency
      M106 P1 C"HotEnd" S1 H1                          ; set fan 1 name and value. Thermostatic control is turned on
      M950 F2 C"out5" Q30                                   ; create fan 2 on pin out5 and set its frequency
      M106 P2 C"CaseFan" S1 H-1                             ; set fan 2 name and value. Thermostatic control is turned off
      M563 P1 S"HotEnd" D0 H1 F0                            ; define tool 0
      G10 P0 X-25 Y-21 Z0                                   ; set tool 0 axis offsets
      G10 P0 R0 S0                                          ; set initial tool 0 active and standby temperatures to 0C
      ;M912 P0 S-13						                  ; CPU temperature calibration
      ;M280 P0 S160					  	                  ; Clear any alarms
      M402								                  ; retract pin just in case
      M501                                                  ; load saved parameters from non-volatile memory
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"    ; set voltage thresholds and actions to run on power loss
      T0                                                    ; select first tool
      M552 S1                                               ; enable network
      M586 P0 S1                                            ; enable HTTP
      M586 P1 S0                                            ; disable FTP
      M586 P2 S0                                            ; disable Telnet
      adalton5683undefined jay_s_ukundefined chrishammundefined 3 Replies Last reply Reply Quote 0
        adalton5683 @adalton5683
        Idk if this applies but ive yet to touch the heater and its a brand new hemera thermistor. im reading around 100kohm on the thermistor. and I originally configged everything right out of the config tool as the e3d thermistor. but through trying to figure this out I may have changed a couple P F S H and T settings throughout so any new help would be amazing if someone can figure this one out. ive read all the 307, 140, 106 143 and 950 commands and made sure not to change anything relating to voltage or board stuff thats not either mapping or control.
        adalton5683undefined 1 Reply Last reply Reply Quote 0
          This post is deleted!
          • deckingmanundefined
            deckingman
            I'm using my phone right now so haven't looked at your config, but assuming that's OK, then the usual cause of seeing a very low temperature is that the thermistor is showing a very high resistance. The usual reason for that is a bad crimp or other wiring fault although faulty thermistors are no unheard of
              jay_s_uk @adalton5683
              @adalton5683 said in ZERO KELVIN HOTEND TEMP:
              this is incorrect and should be S1
              • chrishammundefined
                chrishamm administrators @adalton5683
                @adalton5683 This doesn't look right either, you map heater 0 (bed) to sensor 1 (hotend):
                M950 H0 C"out0" T1
                it should be T0 to make sense.
                Duet software engineer
                  adalton5683 @jay_s_uk
                  @jay_s_uk @chrishamm
                  made both changes
                  M308 S1 P"temp0" Y"thermistor" A"Bed" T98801 B4185 ; configure sensor 0 as thermistor on pin temp0
                  M308 S1 P"temp1" Y"thermistor" A"HotEnd" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                  M950 H1 C"out1" T1
                    this should be S0 not S1
                    The S value is the sensor number. You can't have 2 S1's!
                    https://duet3d.dozuki.com/Wiki/M308
                      @jay_s_uk seems like you just told me to change it to S1 lol
                        @adalton5683 the other one! you have 2 M308's and I highlighted the second one, but instead you changed them both
                        adalton5683undefined 1 Reply Last reply Reply Quote 1
                          @jay_s_uk ok I made that change
                          I think I moved my config around after the original post and I think I made that change so it was the only one that was like that to change. anywhoo heres the current c.g
                          M308 S0 P"temp0" Y"thermistor" A"Bed" T98801 B4185           ; configure sensor 0 as thermistor on pin temp0
                          Phaedruxundefined 1 Reply Last reply Reply Quote 1
                            Phaedrux Moderator @adalton5683
                            Does your hotend temp still show -273?
                            This should be P0 for tool0. P1 would be for tool1, which I assume you don't have two tools.
                            Are you assembling this by hand or are you starting with a config from the online generator? https://configtool.reprapfirmware.org/Start
                            Can you send M98 P"config.g" in the gcode console and report back what it returns? That will check the config for any syntax errors that may get missed during startup.
                              adalton5683 @Phaedrux
                              @phaedrux
                              Ran M98 P"config.g:
                              heres everything from the console and then a pic of what the status is still.
                              1/28/2022, 5:56:23 AM	Error: Temperature reading fault on heater 1: sensor open circuit
                              1/28/2022, 5:56:22 AM	M98 P"config.g"
                              HTTP is enabled on port 80
                              FTP is disabled
                              TELNET is disabled
                              Error: bad grid definition: Too many grid points; suggest increase spacing to 11.8mm
                              1/28/2022, 5:55:48 AM	Connected to 192.168.0.27
                              Heres the config.g
                              ive even redone the config tool a couple times and since my paneldue arrived I now have that but hoopefully that shouldnt effect this already happening problem.
                              ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Jan 27 2022 23:10:21 GMT-0600 (Central Standard Time)
                              M575 P1 S1 B115200                                   ; enable support for PanelDue
                              M550 P"Enduet 3VED"                                   ; set printer name
                              M92 X80.00 Y80.00 Z397.50 E409.00                     ; set steps per mm
                              M566 X900.00 Y900.00 Z60.00 E300.00                   ; set maximum instantaneous speed changes (mm/min)
                              M203 X9000.00 Y9000.00 Z300.00 E6000.00               ; set maximum speeds (mm/min)
                              M201 X500.00 Y500.00 Z100.00 E6000.00                 ; set accelerations (mm/s^2)
                              M906 X700 Y700 Z700 E1200 I30                         ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30                                               ; Set idle timeout
                              M208 X-115:115 Y-115:115                                     ; set axis minima
                              ;M208 X235 Y235 Z250 S0                                ; set axis maxima
                              M558 P9 C"io3.in" H5 F600 T6000                       ; set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X-64 Y-10 Z2.5                                ; set Z probe trigger value, offset and trigger height
                              M557 X0:235 Y0:235 S5                                 ; define mesh grid
                              M307 H0 B0 S1.00                                      ; disable bang-bang mode for the bed heater and set PWM limit
                              M143 H0 S110                                          ; set temperature limit for heater 0 to 110C
                              M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                              M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
                              M143 H1 S300                                          ; set temperature limit for heater 1 to 300C
                              M950 F0 C"out3" Q50                                   ; create fan 0 on pin out3 and set its frequency
                              M950 F1 C"out4" Q500                                  ; create fan 1 on pin out4 and set its frequency
                              M106 P1 C"HotEnd" S1 H1 T60                           ; set fan 1 name and value. Thermostatic control is turned on
                              M950 F2 C"out5" Q500                                  ; create fan 2 on pin out5 and set its frequency
                              M106 P2 C"CaseFan" S1 H1:0 T60                        ; set fan 2 name and value. Thermostatic control is turned on
                              M563 P0 S"HotEnd" D0 H1 F0                            ; define tool 0
                              G10 P0 X0 Y-13 Z0                                     ; set tool 0 axis offsets
                                dc42 administrators @adalton5683
                                @adalton5683 your heater and sensor config looks OK to me now. However, your bed heater has faulted. This is probably because it is a slow bed heater and you tried to heat it without tuning it first. I suggest you restart it and see whether the bed heater displays a valid current temperature before you try to heat it.
                                  adalton5683 @dc42
                                  @dc42 so ive restated it many times and its not shown the correct temp. ive tried deleting everything in config-overrid.g and anything that has to do with tunig if it appeared in config.g
                                  so essentially im starting with a fresh install and its showing -273 still
                                    deckingman @adalton5683
                                    @adalton5683 If you are sure that everything is configured correctly but you are still seeing-273, then did you read my post above (27th Jan @ 07:41) ?
                                      adalton5683 @deckingman
                                      @deckingman I think our timezones are off so I cant find a post at that time. so can you specify what post.
                                        The first post after your opening posts.
                                          @deckingman
                                          Ok yeah I’ve already check that. The meter is giving me correct resistances on the therm. I did however order a new thermistor anyway just incase. Also checked and rechecked the crimps even checking their resistance.
                                            @adalton5683 try sending M308 S0 from the console with no other parameters. It will report the current parameters for sensor 0 and the last error recorded.
