    Torque Calculation as Percentage of Rated Current
    966
    • ctilley79undefined
      ctilley79
      I didn't really find a solid answer when searching. Is there a way to calculate torque at a given current? If I have a 2 amp motor with a torque rating of 53Ncm, what's the torque if I'm running at 60% of max rated current? Is there a formula for that?
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @ctilley79
        @ctilley79 If you're talking about zero-speed holding torque then it's linearish so 60% rated current gets you 60% rated torque.
        Most torque curves are related to speed-vs-torque and that's not linear at all.
        Does the speed vs torque curve move linearly up and down as percentage maximum current changes? I'm not sure 100% but I think it does for reasonable fractions of maximum current.
        ctilley79undefined 1 Reply Last reply Reply Quote 0
          ctilley79 @alankilian
          @alankilian Gotcha. I'm trying to find the best balance between current and torque. Lower current allow me to achieve faster speeds before back emf becomes the limiting factor. Too low then there's not enough available torque so acceleration has to be drastically reduced or I get layer shifts.
          So I'm trying to find a method where I can determine the best balance between torque and speed.
            @ctilley79 said in Torque Calculation as Percentage of Rated Current:
            Lowering the current is going to LOWER your torque, so I'm confused.
            You should also look at the torque-vs-speed curve for your motor.
            I think that's going to have a much greater influence on your maximum speed than back EMF. (Unless you have a low-voltage power supply.)
              @alankilian said in Torque Calculation as Percentage of Rated Current:
              Exactly. lowering current will lower torque, but you get less back emf, so you can achieve higher speeds. However as you lower current, torque can drop to a point where you don't have enough power for fast acceleration moves. Here's output from Duets EMF calculator that shows what I'm talking about. Hence why I'm trying to find a reasonable tradeoff of both.
              At 800ma current
              At 1400ma current
                @ctilley79 Yes, that's the back EMF calculator, but what about the speed-vs-torque curve of the motor? I'm interested in knowing if there's a calculator that takes into account this curve also or if they all ignore it.
                Here's one that says at 32,000 (16x) steps-per-second, you'll get only 65% of the maximum torque out of your motor.
                Are you factoring in that curve also?
                  dc42 administrators @alankilian
                  @alankilian a torque vs. speed curve is generally meaningless without the driver supply voltage being specified, because the ability of the driver to supply the requested current depends on the speed and supply voltage.
                    alankilian @dc42
                    @dc42 Sure that's true and important, but also see in the curve I posted that the torque drops even when the drivers are supplying the appropriate amount of current, so I think it's not the drivers, but rather the physics of the motor that cause the drop in torque IN THIS SITUATION..
                    So they BOTH matter, and if you've got a driver that can supply the required current at the speed you are moving, the torque-vs-speed curve is the ONLY one that matters.
                    So I agree and don't agree. 🙂
                      That's not entirely clear, because the graph shows only the driver input current, not the output current. If the motor is being loaded with the indicated torque, then the fact that the driver input current remains steady indicates that the output current is not remaining constant.
                        alankilian @dc42
                        @dc42 Hmmmmm.
                        If speed didn't matter, why do they all produce a chart like this?
                        This is the inductance-caused reduction in torque and you are talking about the voltage-caused reduction in torque (I think)
                        Maybe you're saying this chart represents the back-EMF-induced reduction in torque?
                          They are almost the same thing. Inductance causes back emf, and that back emf is proportional to the full step rate and the motor current. Motion also causes back emf, and that back emf is also proportional to step rate (but not to motor current). If the driver supply voltage is insufficient to overcome the combined back emf, then the current must drop.
                          A complication is that when the motor is lightly loaded and the lag angle is low, the two sources of back emf are in phase; but when the load is high and the motor is on the point of skipping steps, they are 90deg out of phase.
                          ctilley79undefined 1 Reply Last reply Reply Quote 1
                            ctilley79 @dc42
                            @dc42 So back to the topic at hand. What's a good way to set current to achieve the highest speeds without losing running torque?
                              dc42 administrators @ctilley79
                              At speeds above the point of torque dropoff due to insufficient voltage, the current setting doesn't make any difference. Higher current will give more torque at lower speeds, but the point at which torque starts reducing and the motor becomes noisy will be reached at a lower speed.
