    BLtouch 3.1 on Duet 2 WiFi 1.05 does not work
    696
      Are you sure you have the yellow wire connected to exp.heater3?
      Schotteundefined 1 Reply Last reply Reply Quote 0
      • Schotteundefined
        Schotte @Phaedrux
        @phaedrux
        yes, we have already checked several times
          Can you test with a different heater pin then? exp.heater7 perhaps? Alter the M950 command accordingly.
          It may also be worthwhile testing with a fresh set of configs from the config tool.
          https://configtool.reprapfirmware.org/Start
          • Schotteundefined
            Schotte @Phaedrux
            @phaedrux
            We had already tested heater 7 and will be testing heater 5 and 7 again soon.
            I just created a new config, we will test it afterwards.
            Also, a big thank you for your help! That's great
            • JoergS5undefined
              JoergS5
              @schotte I am not sure, but
              M558 P9 C"^zprobe.in" H12 R1.0 F500:F120 T6000
              F parameter looks wrong to me, it should be F500:120 (so without second F letter).
              • Schotteundefined
                Schotte
                @Phaedrux
                Have tested heater 5 and 7, Bltouch still doesn't work.
                New SD card with new system didn't help either.
                  Can you test with the BLTouch leads connected directly to the board without any extension?
                  The M558 problem is resolved, now we just need to get the servo communicating.
                  You mentioned in your first post that the power on pin test of the bltouch moves slowly. Is the BLtouch held upright? Have you tried connecting only 5v and ground?
                  • Schotteundefined
                    Schotte @Phaedrux
                    @phaedrux
                    We can no longer connect the Bltouch directly without further.
                    If we unplug the yellow wire from the Heater5 pin, the Bltouch will do the self-test at normal speed. Once the yellow wire is reconnected, again slowly.
                    @JoergS5
                    we will test again when the BLtouch is running - thanks for the tip
                    JoergS5undefined 1 Reply Last reply Reply Quote 0
                    • JoergS5undefined
                      JoergS5 @Schotte
                      @schotte another thing to check is whether the probe pin can move correctly. The distance and freedom of moving is defined by the screw at the top which can be changed with an allen key.
                      https://www.antclabs.com/bltouch-v3
                      the picture
                      • Schotteundefined
                        Schotte @JoergS5
                        @joergs5
                        The pen is smooth, shouldn't be a problem
                        Our measurement is 0.2mm
                          If you're certain the wiring is correct and there is continuity on the wires there is still the possibility the probe itself is defective.
                          Do you have another printer to test the probe with, or another probe to test on this printer?
                          • Schotteundefined
                            Schotte @Phaedrux
                            @phaedrux
                            I'm helping a friend online through Teamviewer and he lives about 90 miles away. He's going to order a new one and then we'll see.
                            We will then report, hopefully it works with the new one.
                            • Schotteundefined
                              Schotte
                              Hello
                              We tested the direct connection with a new BL-Touch and it worked. We then found out that it was the extension cable for the BL-Touch, the internal resistance was too high.
                              Everything works now.
                              Thanks again for the help!!!!
                              • Schotteundefined
                                Schotte
                                This post is deleted!
