    Duet3 mini voron gantry level problem
    voron2.4 gantry level problem
    1.7k
    • jumpedwithbothfeetundefined
      jumpedwithbothfeet @jamaicarasta
      @jamaicarasta only if you want to print something! you could always ensure the heater is disconnected to be as safe as possible
      6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
      jamaicarastaundefined 1 Reply Last reply Reply Quote 0
        Phaedrux Moderator @jamaicarasta
        @jamaicarasta said in Duet3 mini voron gantry level problem:
        ; mesh.g
        ; called to perform automatic bedmesh via G29
        M561 ; clear any bed...
        G29 ; bed mesh
        G1 X175 Y175 Z50 F20000 ; go to bed middle
        The overflow is likely because you have G29 inside of mesh.g. G29 calls mesh.g. Inside of mesh.g you must use G29 S0 to initiate the probing routine.
        jamaicarastaundefined 3 Replies Last reply Reply Quote 1
        • jamaicarastaundefined
          jamaicarasta @jumpedwithbothfeet
          @jumpedwithbothfeet
          I'm still waiting for my new mosquito Magnum with heating cartridge and temperature sensor. There is no extruder in it 👍
            jamaicarasta @Phaedrux
            @phaedrux
            Thanks man 🙌🏼
            I will Try it tomorrow morning.
            I'll let you know tomorrow if it worked 👍
            Thanks in advance
              @phaedrux
              Hey the Printer Starts the bed mesh But now he write "No valid grid defined for bed probing"…
              Barracuda72undefined 1 Reply Last reply Reply Quote 0
                @phaedrux
                ok was my mistake. too many measuring points. now it works 👍
                • Barracuda72undefined
                  Barracuda72 @jamaicarasta
                  @jamaicarasta thats mostly because your probe have an Offset..and as i had to learn...if you define your probe area it takes the coordinates from the probe and not from the nozzle...so if you define x10 y10 and probing start and your probe have an offset of x0 y25 ( Voron) then if it want to probe the point the nozzle would be at x10 y-15 so its off the valid area. so meshare start have to be at least at x0 y25 to work
                  have to learn so much from my change from a duet Delta to the duet Voron 😉
                    jamaicarasta @Barracuda72
                    @barracuda72
                    yes exactly 😂 I puzzled for 2 days why my Y and X did not correspond to what I tell him. Then I set the offset X0/Y20 and now it fits. I already had the Voron but with a clipper.... It's a little different. But I love the duet 👍
                      jay_s_uk @jamaicarasta
                      @jamaicarasta you can't just set random offsets in G31 to make it fit. it has to be the physical measurements from the nozzle
                        Measure your offsets: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
                        Alter your grid size to take into consideration the physical offsets. Skipping points it can't reach isn't necessarily a problem, but it does mean you could have a more efficient usage of points. Though if you're not using the maximum 441 points, does it really matter?
