    BlTouch Issues
    313
    • peirofundefined
      peirof
      Until yesterday, BlTouch v3 worked correctly, I had it connected to a Duet 3 Mini, to socket io0...
      But I have decided to install a screen + Due panel, looking at the documentation, it indicated that if it is connected with the 4-wire cable, you MUST connect it to Io0, if not it does not work.
      So I have moved the BlTouch to Io4, changing config.g... but now it doesn't work, it does the selftest, but when you do a Home, it doesn't deplaoy
      My previous configuration that DID work:
      ; BLTouch
      M950 S0 C"io0.out"                     ; Create a servo pin on io7
      M558 P9 C"io0.in" H5 F240 T10800 A5    ; set Z probe type to unmodulated and the dive height + speeds
      G31 P25 X-28.00 Y-13.00 Z0.90          ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed
      ; deployprobe.g
      ; Called to deploy a physical Z probe
      M280 P0 S10															; Deploy the BLTouch pin
      ; Called to retract a physical Z probe
      M280 P0 S90													; Retract the BLTouch pin
      My current configuration that does NOT go:
      ; BLTouch
      M950 S0 C"io4.out"                     ; Create a servo pin on io7
      M558 P9 C"io4.in" H5 F240 T10800 A5    ; set Z probe type to unmodulated and the dive height + speeds
      ; deployprobe.g
        jay_s_uk @peirof
        @peirof did you upgrade to 3.4RC1? if so, this is a known issue.
        use the build from here https://forum.duet3d.com/topic/27139/rrf-3-4-0beta7-5-sbc-servo-only-responding-once-after-reset/10?_=1644995776018
        peirofundefined 1 Reply Last reply Reply Quote 0
        • peirofundefined
          peirof @jay_s_uk
          @jay_s_uk in this moments, not sure, but i think remenber i have 3.4.0 Beta XX??? i check after
            jay_s_uk @peirof
            @peirof there was an issue with beta 7 too
            • peirofundefined
              peirof @jay_s_uk
              @jay_s_uk no... the lottery didn't win me, no... but this... let's hope it's this, it was driving me crazy
              peirofundefined 1 Reply Last reply Reply Quote 1
              • peirofundefined
                peirof @peirof
                @peirof
                In the post you have linked... direct to Drobox folder...
                Firmware Duet v3 Mini 3.4 BlTouch
                this is supposed to be the firmware, with which I have to update my Duet 3 Mini... but I have two doubts:
                A- It is not in the usual format. Correct?
                B- It is updated in the same way. With the DWC?
                  jay_s_uk @peirof
                  @peirof use the .uf2 and yes through DWC
                  • peirofundefined
                    peirof @jay_s_uk
                    @jay_s_uk
                    Tomorrow more..., but dont works after apply firmware...
                    Panel Due... only works in Io0?
                      droftarts administrators @peirof
                      @peirof See https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_connecting#wiring-the-bltouch
                      For Duet 3 Mini 5+, use IO_1, IO_2 or IO_3.
                      Don't use IO_4 (okay for MB6HC, but not for Mini 5+), use one of the above. It's because of pin capability, only IO_1, IO_2 and IO_3 are PWM capable. See https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview#io-port-pin-capabilities
                      peirofundefined 2 Replies Last reply Reply Quote 0
                      • peirofundefined
                        peirof @droftarts
                        @droftarts mmm...
                        The tests that I was going to do tomorrow, were in that sense, try other shockets ...
                        Thanks for the conformation...
                        Bltouch, does it work with the latest Firmware release?
                          Phaedrux Moderator @peirof
                          @peirof said in BlTouch Issues:
                          Yes
                          • peirofundefined
                            peirof @droftarts
                            @droftarts solved, now works ok...!!! I have connected to io1.
                            Thanks
