    Can't move the z axis in DWC more than 200
    • luka1952undefined
      luka1952
      Hi, Strangly i can't move z axis on my hypercube more than 200 in DWC. The z axis limit is 390. And before it was working ok.
      What can cause this?
      Is my board damaged?
      • luka1952undefined luka1952 marked this topic as a question
        Please share your config.g, homing files, bed.g, etc
        Also the results of M122 and M98 P"config.g"
        This will give us an idea of what is happening.
        When you say it won't move more than 200mm, what happens when it stops? What sequence of events is happening to lead up to this? Is it possible the Z axis is binding?
        luka1952undefined 1 Reply Last reply Reply Quote 0
        • luka1952undefined
          luka1952 @Phaedrux
          @phaedrux
          Thanks for reply. This are my files you asked about.
          When my print has finished I wanted to juggle the bed down to remove it easer. I hit +50 on z axis in DWC (the part I printed was 180mm high) so the bed supposed to move 50mm down. But it stops at 200 and refuse to lower further. I repeated the command seweral times. But didn't work. Then I moved up a bit and try to lower it again. But still the same. Stops at 200.
          M122:
          18/02/2022, 07:20:51 M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later
          Board ID: 0JD0M-9P6B2-NJ4S8-6JKDD-3SS6M-9B5GJ
          Used output buffers: 3 of 24 (20 max)
          Static ram: 23876
          Dynamic ram: 75636 of which 20 recycled
          Never used RAM 14884, free system stack 184 words
          Tasks: NETWORK(ready,13.7%,244) HEAT(delaying,0.1%,330) Move(notifyWait,0.1%,340) MAIN(running,85.7%,441) IDLE(ready,0.4%,29), total 100.0%
          Owned mutexes:
          Last reset 00:03:39 ago, cause: power up
          Last software reset at 2022-02-17 16:55, reason: User, GCodes spinning, available RAM 15264, slot 0
          Error status: 0x00
          Step timer max interval 0
          MCU temperature: min 25.1, current 31.4, max 31.6
          Supply voltage: min 24.1, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 5: position 0
          Driver 6: position 0
          Driver 7: position 0
          Driver 8: position 0
          Driver 9: position 0
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2022-02-18 07:20:51
          Slowest loop: 4.58ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.5ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = 0 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 21.00ms; fastest: 0.00ms
          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.26
            WiFi MAC address e0:98:06:22:81:26
            WiFi Vcc 3.31, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 21080
            WiFi IP address 192.168.178.129
            WiFi signal strength -73dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
          Bed.g
          ; bed.g
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Dec 13 2021 17:52:06 GMT+0100 (czas środkowoeuropejski standardowy)
          G28 ; home
          M401 ; deploy Z probe (omit if using bltouch)
          G30 P0 X0 Y185 Z-99999 ; probe near a leadscrew, half way along Y axis
          G30 P1 X330 Y185 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
          M402 ; retract probe (omit if using bltouch)
          config.g
          M550 P"Hypercube Evolution" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P4 S0 ; physical drive 4 goes backwards
          M584 X0 Y1 Z2:4 E3 ; set drive mapping
          M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z400.00:400.00 E693.00 ; set steps per mm
          M566 X2000.00 Y2000.00 Z50.00:50.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X20000.00 Y20000.00 Z2000.00:2000.00 E15000.00; set maximum speeds (mm/min)
          M201 X10000.00 Y10000.00 Z50.00:50.00 E10000.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800:800 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M671 X0:400 Y185:185 S1 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
          M572 D0 S0.01
          M208 X0 Y0 Z0:0 S1 ; set axis minima
          M208 X390 Y375 Z390:390 S0 ; set axis maxima
          M574 X1 S3 ; configure sensorless endstop for low end on X
          M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
          M574 Z2 S2 ; configure Z-probe endstop for high end on Z
          M915 X R0 F0
          M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F120 T12000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X-28 Y-13 Z3.14 ; set Z probe trigger value, offset and trigger height
          M557 X0:350 Y10:360 S60 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4085 ; configure sensor 0 as thermistor on pin bedtemp
          M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs1
          M143 H1 S350 ; set temperature limit for heater 1 to 350C
          M308 S2 P"e1temp" Y"thermistor" T100000 B4066 ; configure sensor 2 as thermistor on pin e1temp
          M950 H2 C"e1heat" T2 ; create chamber heater output on e1heat and map it to sensor 2
          M307 H2 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit
          M141 H2 ; map chamber to heater 2
          M143 H2 S80 ; set temperature limit for heater 2 to 80C
          M106 P0 C"Filament Cooling Fan" S0 H-1 ; set fan 0 value. Thermostatic control is turned off
          M106 P1 C"Hotend Fan" S1.0 H1 T45 ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its freqeuncy
          M106 P2 C"Filter Fan" S0 H-1 ; set fan 2 value. Thermostatic control is turned off
          M563 P0 S"Sherpa/Dragon" D0 H1 ; define tool 0
          T0
          homeall.g
          G91; relative positioning
          G1 H2 Z10 F12000 ; lift Z relative to current position
          G1 H1 Y-380 F3000 ; move quickly to Y axis endstop and stop there (first pass)
          G1 Y10 F6000 ; go back a few mm
          G1 H1 Y-380 F360 ; move slowly to Y axis endstop once more (second pass)
          M400
          M913 X60 Y70; drop motor current to 60%
          M201 X2000.00 Y2000.00
          G1 H1 X-400 F5000 ; move quickly to X axis endstop and stop there (first pass)
          G1 H2 X5 F12000 ; go back a few mm
          G1 H1 X-400 F4000 ; move slowly to X axis endstop once more (second pass)
          G1 X10
          G92 X0
          M201 X3000.00 Y3000.00
          G90 ; absolute positioning
          M400
          M913 X100 Y100 ; return current to 100%
          M400
          G1 X200 Y200 F12000 ; go to first bed probe point and home Z
          G30 ; home Z by probing the bed```
          homez.g
          G91 ; relative positioning
          G1 H2 Z5 F12000 ; lift Z relative to current position
          G1 X200 Y200 F12000 ; go to first probe point
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Error: Z axis maximum must be greater than minimum
          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 285C
          Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
          engikeneerundefined 1 Reply Last reply Reply Quote 0
          • engikeneerundefined
            engikeneer @luka1952
            @luka1952 M98 P"config.g" shows your issue:
            You have put in a double value for Z for both min and max. There should be only one value in both. My guess is that it fails to interpret this and so retains the default limits (zmax 200).
            Change it to
            M208 X390 Y375 Z390 S0 ; set axis maxima
            Same applies to all your other settings (steps, microsteps currents, accel, jerk, max speed). RRF only support one value per axis for each of these (apart from extruders)
            i3 clone with a bunch of mods
            luka1952undefined 1 Reply Last reply Reply Quote 1
            • luka1952undefined
              luka1952 @engikeneer
              @engikeneer
              I have dubbele z axis with two independent steppers/drivers.
              This make possible to adjust the two z axis screws apart from each other.
                @luka1952 but they are one axis. If they were different, it just wouldn't work. They can't have different limits, acceleration rates etc if they move together as one axis.
                I say again, RRF only supports one value per axis for each of these (apart from extruders)
                • luka1952undefined
                  @engikeneer
                  Thanks, I've changed it and it works 🙂
                  Thank you very much.
                  There is one more problem I have but that's in the other topic. Could you have a look? I can't solve it...
