    Easier way to test if homed?
    Gcode meta commands
    8
    29
    1.6k
    • theolodianundefined
      theolodian @OwenD
      @owend Ugh, different problem. Homing always comes back as failed when using these lower case letters for axes. 🙄
      It does work fine if everything is already homed.
      ; If the bed hasn't been homed, home it
      ; Iterative loop across all defined move axes
      while iterations < #move.axes
      	if !move.axes[iterations].homed
      			G28
      			if result != 0
      				abort "Homing failed"
      			break
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @theolodian
        @theolodian
        I don't know why the axis letters would matter.
        Are any axes hidden?
        May be a question for @dc42
        theolodianundefined 1 Reply Last reply Reply Quote 0
          theolodian @OwenD
          @owend It has never worked correctly, there are still a variety of issues with using lower case letters for axes. Thanks.
          zaptaundefined 1 Reply Last reply Reply Quote 0
            @theolodian said in Easier way to test if homed?:
            If you don't tell us what these issues are, we can't fix them.
            • zaptaundefined
              zapta @theolodian
              @theolodian, are you referring to the various scripts here that test for homing? The all seem to use axis indexes rather than axis letters.
                theolodian @zapta
                @zapta said in Easier way to test if homed?:
                No, I am using lower case axis letters and homing always returns errors even though it works.
                  theolodian @dc42
                  @dc42 Are lower case axis letters supposed to work in SBC mode now? Should I try it again? We have just been using standalone mode.
                  • chrishammundefined
                    chrishamm administrators @theolodian
                    @theolodian Lowercase letters are supported in the latest RC.
                    Duet software engineer
                      theolodian @chrishamm
                      @chrishamm I was going to say no, but I rebooted everything one more time to be sure - and yes RC2 seems to work in SBC mode! 😮 👍
                      • JoergS5undefined JoergS5 referenced this topic
