Solved Alfawise U10 conversation
Hi friends!
I have an Alfawise U10 which has been waiting for duet wifi some time. The time has come now. Suddenly the original knob got stuck indicating that it was time to change the motherboard to duet wifi. The board fits the box ok, the endstops need to be wired so that they are "on" instead being "off".
The Alfawise power supply gives 12.4 volts and the heat bed resistance is 0.6 ohms.Now the problem I faced was the heating of the bed and the nozzle:
Error: Heater 0 fault: temperature rising much more slowly than the expected 1.8°C/sec
T0
Error: Heater 1 fault: temperature rising much more slowly than the expected 1.7°C/sec
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
Duet WiFi Server Version: 1.26
I ran the pid tuning but it did not help. Any suggestions what to do next? -
If you post the PID values for both heaters it will help others help you.
@alankilian
ok, I try M303 T0 S205"Failed to get file list
Directory 0:/macros/ not found"
Is that ok?Warning: Auto tune of heater 1 failed due to bad curve fit (R=1.782, 1/C=0.0050:0.0049, D=9.8)
M303 H0 S60:
Well something is wrong.
Let's go back to the basics. Please post the following:
- config.g
- config-overrides.g
- M98 P"config.g"
THIS PAGE shows how to tune the heater models.
Also, THIS PAGE shows a step-by-step tuning process.
If you can post the console output while each step is running as shows in the example it will also help. -
@alankilian
I updated firmware 3.3-
hotend works fine now
bed doesn´t. Error: Heater 0 fault: temperature rising much more slowly than the expected 1.4°C/sec
config-overrides.g :not foundM98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
config.g:
; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Mar 07 2022 20:17:53 GMT+0200 (Itä-Euroopan normaaliaika); General preferences
M550 P"Alfawise U10" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X800 Y800 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X400 Y400 Z500 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
Since there's no file config-override.g and there's no M501 in your config.g it looks like you tuned your heaters but forgot to save the tuning parameters and forgot to add the code to load them back when rebooting.
Follow the step-by-step sequence on THIS page to tune, save and load the tuning parameters.
@alankilian
I got results after hours of tuning:
M307 H0 B0 R0.086 C686.8 D1.84 S1.00 V12.5
Bed seems to heat up now.
I have an impression that RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15) solved the problem.
Many thanks! -
dc42
dc42
Excellent.
I'm glad you got it working.
Post a picture of something you print sometime.
I'd love to see something. -
@alankilian
Now printing chain links. A terrain model for modular building modules lies in front of the printer.
BTW I have no idea what is a reasonable max speed and acceleration for this kind of configuration.
And is there something else I could implement here?
Z-Probe and 2 end stops for z axis could be nice. My custom toolchanger has end stop stall detection, why not here?
