    SBC on a separate 5v supply and using M80/M81commands.
    273
    • Nuramori
      Nuramori last edited by Nuramori
      I have two meanwell PSUs on my printer, one that supplies 5v/12v primarily for the SBC, and a 24v that also has the ability to remotely turn on using the pson function on my duet3. Since the 24v powers the duet3, am I to assume that once I turn off the 24v psu via a M81 command, the fact the SBC can still operate doesn’t matter, and I can’t issue a M80 to turn it back on until I power cycle the entire machine? Perhaps there’s still some functionality that allows some pass through so that issuing a M80 will trigger that pin even with the duet3 not receiving power from the 24v supply?
      @dc42?
      • rjenkinsgb
        rjenkinsgb last edited by
        I use a similar setup in one of my machines.
        Just set the Duet board for external 5V and also feed that from the 5V supply.
        That keeps all the logic "alive" but with minimal power use, and allows M80 / M81 to control the 24V power to the high current side of things.
        Robert J.
        Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
        Nuramori 1 Reply Last reply Reply Quote 0
        • Nuramori
          Nuramori @rjenkinsgb last edited by
          @rjenkinsgb can you share your jumper settings? Are you supplying the 5v via the three pin that also has the pson pin as part of the array?
          rjenkinsgb 1 Reply Last reply Reply Quote 0
          • rjenkinsgb
            rjenkinsgb @Nuramori last edited by
            @nuramori said in SBC on a separate 5v supply and using M80/M81commands.:
            Yes; that and remove the 5V jumper in the middle of the middle of the board completely, so the Duet 5V has no other interconnection.
            The SSR input connects between PSON and the positive 5V supply.
            Robert J.
            • zapta
              zapta last edited by
              What Duet board are you using?
              rjenkinsgb Nuramori 2 Replies Last reply Reply Quote 0
              • rjenkinsgb
                rjenkinsgb @zapta last edited by
                @zapta Duet 3 6HC
                Robert J.
                • Nuramori
                  Nuramori @zapta last edited by
                  @zapta I'm using the duet3 6hc, v1.0
                  • rjenkinsgb
                    @nuramori Mine's a V1.1, but they have the same connections and jumpers etc.
                    The 5V jumpers I mentioned are the three positions in the block with the orange header in the middle of the connections diagram; all three should be open if the external 5V feeds both the Pi and the Duet directly.
                    https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
                    Robert J.
                    • Nuramori
                      @rjenkinsgb Yep, all good. I had previously been feeding it off of the duet3, but I suspect some random mid print stalls are/were related to under voltage to the pi4, and wanted to finally clear some to-do's off my list.
                      all reconfigured and working as intended. thanks.
                      dhusolo 1 Reply Last reply Reply Quote 0
                      • dhusolo
                        dhusolo @Nuramori last edited by
                        @nuramori I have 5v and 24v on my Duet 3 and 5v, 24v and 48v on my fysetc spider. Each are connected to the same SSR and triggered by PSON
