    Solved Random additional steps - interference?
    33
    534
    • bubblevisor
      bubblevisor last edited by bubblevisor
      My recently built i3 style machine with duet 3 mini 5+ suffers from what looks like inaccuracies/inconsistencies in the Z axis and possibly all other steppers too. Mechanically the machine is fine. Indeed I run numerous similar machines (with duet 2 boards) so I am confident it is not mechanical.
      Additionally, during bed mesh moves, I think I can hear/feel the z-motors occasionally jumping a step. Placing my hands on the z-motors during bed mesh confirms there is an occasional random shudder that feels just like a skipped step.
      The print artifacts do seem very consistent with this theory. Prints very much look like what you would expect to see if you randomly added or subtracted a single step or two every say minute or so. Even the extruder shows tiny gaps in the prints.
      I also feel it could be something relating to the duet 3 mini 5+ architecure as I believe I have this problem with another duet 3 mini machine but none of my duet 2 machines.
      I am stumped as to how to solve this. I have tried changing the microstepping method from 128 to 16 which made no difference. Interpolation of off btw.
      markz dc42 2 Replies Last reply Reply Quote 0
      • markz
        markz @bubblevisor last edited by
        @bubblevisor I know you say this isn't mechanical but I had the exact issue on a 3-z-motor printer and diagnosed it down to... the 3D printed Z motor mount was a plate with a support screw resting inside it and I had just taken off the backlash springs which everyone insists are not necessary.
        When the leadscrews would all rotate down (probably at slightly different micro-times) the bed weight wasn't enough to just force the 3 plates down on their support screws so one carriage would stick (because they are now all at tiny angles) then release when the pull increased. I ended up using 3 steel balls and magnets as supports (to allow bed leveling) and it stopped scraping.
        Does it only happen when the bed is going down? Do you use shielded motor cables? Do you have backlash springs? Maybe a photo showing the Z mechanical and the wiring?
        • bubblevisor
          The printer is an i3 style with twin z leadscrew setup. It works against gravity so should not experience the problem you are describing.
          I am not using shielded motor cables. Would this prevent potential phantom steps?
          jay_s_uk 1 Reply Last reply Reply Quote 0
          • jay_s_uk
            jay_s_uk @bubblevisor last edited by
            @bubblevisor it's z wobble, not missed steps
            • bubblevisor
              The patterns are totally random and vary from print to print. Z wobble has a pattern that corelates with the rotation of the leadscrew. There are also random extrusion gaps.
              • bot
                bot last edited by
                It looks much more like extrusion-related problems than positional problems.
                *not actually a robot
                • bubblevisor
                  I will swap out the extruder and the z motors and leadscrews and report back. Thanks for the advice so far.
                  engikeneer 1 Reply Last reply Reply Quote 0
                  • engikeneer
                    engikeneer @bubblevisor last edited by
                    @bubblevisor one other idea to throw into the mix is the heated bed. You can often get z banding like syptons from a bed who's temperature varies a bit. Could be down to using bang-bang, a poor PID, or just varying cooling on the bed/print (e.g. as it moves around on an i3).
                    To me it looks like the bands line up with the changes in the print (e.g. overhangs etc).
                    I'd also be re-looking at any x/y backlash for similar reasons.
                    i3 clone with a bunch of mods
                      Is your filament feed smooth and steady?
                      PID tuned heaters?
                      Filament quality?
                      bubblevisor 1 Reply Last reply Reply Quote 0
                        dc42 administrators @bubblevisor last edited by
                        @bubblevisor said in Random additional steps - interference?:
                        Possibly relevant is that before RRF 3.4 the drivers on the Duet 3 Mini defaulted to running in stealthChop mode. This can be problematic if the correct tuning move is not executed during homing.
                        • bubblevisor
                          I am comparing my good printer with 2 newly built bad printers. They are identical except for the board. The good printer has Duet 2 wifi and the bad printers have duet 3 mini5+ and the fystec big dipper board. Same filament same everything.
                          • jens55
                            jens55 last edited by
                            I am experiencing something similar with a Duet3 6HC .... since I am running very high speeds, my thought was an occasional loss or gain in the x or y direction that curiously seems to self correct. I am currently doing a print at substantially reduced speed to verify that theory.
                            I call my issue 'banding' because a whole bunch of layers (a band) can be displaced to one side before the system switches back to the right position. The band appears to be positive on one side of the model and negative on the other side which supports the theory of everything shifting over by a few micro steps.
                            • jens55
                              This is what my print looks like:banding.jpg
                              If you magnify the image, you also see random bumps in the layers which is probably an unrelated issue.
                                Doing a vase mode print of a flat walled cylinder could be useful here.
                                @jens55 Do those bands happen to correspond with direction changes? As in, those layers are going left to right, rather than right to left? Meaning perhaps backlash.
                                jens55 1 Reply Last reply Reply Quote 0
                                • bubblevisor
                                  I have swapped out the extruder, the z motors/leadscrews - no change.
                                  • bubblevisor
                                    Photos showing my good printer vs bad
                                      What layer height is that?
                                        Phaedrux Moderator @bubblevisor last edited by
                                        What are the differences between the two machines?
                                        • bubblevisor
                                          0.2mm layer height ESUN ABS with enclosure at 60degrees C.
                                          • bubblevisor
                                            Only difference is the board. Good printer is Duet 2 wifi bad is duet 3 mini 5+ and other bad printer is big dipper. Both bad printers' prints look exactly the same.
                                            • bubblevisor
                                              bubblevisor @Phaedrux last edited by bubblevisor
                                              @phaedrux The stealth chop point seems potentially likely as the good printer is running RRF3.3 on Duet 2 spreadcycle and bad printer is 3.4 on big dipper TMC2209 defaulting to stealthchop with a weird speed threshold that switches to spreadcycle. This sounds like it can give rise to inconsistencies.
                                              I'll change the M569 to enforce spreadcycle and report back. Fingers crossed.
                                              • jens55
                                                jens55 @Phaedrux last edited by
                                                @phaedrux, I don't think direction of travel has any bearing here but I will check that motor pulleys are tight once the current print is finished (tonight). I am pretty sure I loctited them last time I had an issue .... which btw also was intermittent in a way as the pulley could move a bit but not easily so sometimes it moved and other times it didn't.
                                                Great suggestion !!!
                                                As far as 'normal' backlash, I would have expected the artifacts to be very repeatable as every layer in this model is identical to the previous layer ..... but as I said, a pulley has caused something like that before.
                                                • jens55
                                                  I had a chance to check the motor pulley on x and y and they are tight. The same model as printed before but with considerable speed reduction (300 mm/s to 200 mm/s) produces a much better surface finish and only two small position shifts in only one axis. I left the acceleration at 15000 but am now printing again with a reduced acceleration of 10000. I still have infill and inner wall speed set at 300 mm/sec.
                                                  The only other issue I have are the zits that appear randomly. There are two kinds of zits - some are sitting on the outside of the wall and these can be scraped off with only a finger nail. There are however little bumps that are completely enclosed and I am thinking these might be caused by issues with the faster infill speed. These last bumps are not really a problem but more of an annoyance.
                                                  Anyway, I was just printing too fast. This is with a Jubilee printer and quite honestly it's a bit disappointing that I can't go faster.
                                                  • bubblevisor
                                                    BINGO! I turned off the default stealthchop and enabled spreadcycle via M569. Completeley solved the problem.
                                                    Default Stealthchop switches back and forth between spreadcycle and stealthchop when the speed is low. This seems to create a print blemish when this happens. My advice is STICK TO SPREADCYCLE!Main Lathe Clamp-01.jpg
                                                    droftarts 1 Reply Last reply Reply Quote 1
                                                    • bubblevisor
                                                      bubblevisor @dc42 last edited by
                                                      @dc42 THanks for your help. You were spot on!
                                                      • Topic has been marked as a question  dc42 dc42
                                                      • Topic has been marked as solved  dc42 dc42
