    3.4.0 Stable breaks Nozz Heater[1LC ]Error:M307:Response timeout
    Using Duet Controllers
    751
    • SputnikOC3dundefined
      SputnikOC3d
      EDIT 4/3/2022 10:55 PM PST - After several trial and error tests and actually adding a new spare 1LC fresh from factory 3.3 fw version [ 1LC v1.2 ] it seems that upgrading to the 3.4.0 stable release is breaking my systems heater. See all points below.
      Error: M307: Response timeout: CAN addr 121, req type 6049, RID=14
      Error: M307: Response timeout: CAN addr 121, req type 6049, RID=8
      Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 214C
      FW: 3.4. Latest STABLE
      SBC Mode / Pi 4
      Duet3 Mini 5+
      Voron 2.4
      1LC Toolboard v1.2
      ; Nozzle Heater
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4138		; configure sensor 1 as Thermistor on pin 121.temp0
      M950 H1 C"121.out0" T1                       			; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                             			; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S285                                 			; set temperature limit for heater 1 to 285C
      SputnikOC3dundefined 1 Reply Last reply Reply Quote 0
        SputnikOC3d @SputnikOC3d
        @sputnikoc3d
        This is new ... Also cant turn heater1 On Off or Standby in DWC
          @sputnikoc3d ```
          M122 B121
          Diagnostics for board 121:
          Duet TOOL1LC rev 1.1 or later firmware version 3.4.0 (2022-03-15 09:00:04)
          Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
          All averaging filters OK
          Never used RAM 2624, free system stack 88 words
          Tasks: Move(notifyWait,0.0%,153) HEAT(notifyWait,0.2%,101) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.0%,76) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,3.0%,57) MAIN(running,91.8%,349) IDLE(ready,0.0%,26) AIN(delaying,4.9%,142), total 100.0%
          Last reset 00:15:24 ago, cause: software
          Last software reset data not available
          Driver 0: pos 0, 415.0 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 26, reads 3640, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
          Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
          Peak sync jitter -5/8, peak Rx sync delay 213, resyncs 0/0, no step interrupt scheduled
          VIN voltage: min 24.2, current 24.3, max 24.3
          MCU temperature: min 38.2C, current 38.2C, max 42.0C
          Last sensors broadcast 0x00000002 found 1 96 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 18229, send timeouts 14, received 8167, lost 0, free buffers 37, min 37, error reg 110000
          Last cancelled message type 4525 dest 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
          Accelerometer: LIS3DH, status: 00
          I2C bus errors 0, naks 3, other errors 0
            SputnikOC3d
            everything else on the toolboard is working except the H1 nozzle heater .... therm / probe / fans . Heater was working before on the old toolboard that had the bad mosfet/blown mosfet - replaced the 1LC to a ver 1.2 - flashed all the fw up to 3.4.0 and started installing Klicky - klicky is working - all else is - but the Heater.
              SputnikOC3d
              This is my 2nd 1LC tooboard ... I do have another spare. [3rd ]
              Not sure whats going on here. All other crimps and wiring on the 1LC works or worked before 3.4.0
                SputnikOC3d
                Put on a spare v1.2 1LC toolboard.
                FW ver 3.3 atm - and all works as intended - even the heater.
                Will flash the board to 3.4.0
                  SputnikOC3d
                  Ok well flashing the 1LC FW to 3.4.0 using M997 B121 ... updated the firmware.
                  It hung on updating - please wait like it did the very first time I upgraded to 3.4.0 Stable.
                  1LC worked fine on 3.3 from the factory. Now on 3.4.0 Stable - the above errors have returned, and no heater control. Its as if it is DEAD.
                  • SputnikOC3dundefined SputnikOC3d referenced this topic
                    jay_s_uk @SputnikOC3d
                    @sputnikoc3d i suggest check your wiring
                      SputnikOC3d @jay_s_uk
                      @jay_s_uk said in 3.4.0 Stable breaks Nozz Heater[1LC ]Error:M307:Response timeout:
                      I have multiple times and it works great. Everything works on 1LC ver 3.3 fw. Everything on the toolboard except the heater works on 3.4.0
                        @sputnikoc3d what type of wiring are you using?
                          @jay_s_uk
                          Cat 5 twisted pair for CAN
                            dc42 administrators @SputnikOC3d
                            @sputnikoc3d the M307 errors are why the heater won't turn on. Have you used M115 or M122 to check that the main board is running firmware 3.4 ?
                            You may need to rerun heater 1 tuning to generate a new M307 H1 command.
                            SputnikOC3dundefined 2 Replies Last reply Reply Quote 0
                              SputnikOC3d @dc42
                              @dc42 - TY for your reply.
                              Fresh reboot and power cycle of the SBC / Duet generates No M307 error code - that only happens on estop of the duet.
                              1st op after fresh reboot of entire machine and no reporting of errors, I try M303 H1 S240. I get :
                              M303 H1 S240
                              Auto tuning heater 1 using target temperature 240.0°C and PWM 1.00 - do not leave printer unattended
                              Auto tune starting phase 2, heating up
                              Auto tune cancelled because temperature is not increasing
                                SputnikOC3d @dc42
                                @dc42 well there it is ... looks like the FW upgrade from the previous post using the USB stick didnt actually work as planned ...
                                M122
                                RepRapFirmware for Duet 3 Mini 5+ version 3.4.0beta3 (2021-08-24 14:08:24) running on Duet 3 Mini5plus Ethernet (SBC mode)
                                Board ID: 1JDTH-UA67A-G65J0-40TFU-22D0Z-R2KLQ
                                Used output buffers: 1 of 40 (11 max)
                                Static ram: 102756
                                Dynamic ram: 93644 of which 0 recycled
                                Never used RAM 42456, free system stack 200 words
                                Tasks: SBC(ready,2.3%,312) HEAT(notifyWait,0.0%,269) Move(notifyWait,0.0%,338) CanReceiv(notifyWait,0.0%,772) CanSender(notifyWait,0.0%,372) CanClock(delaying,0.0%,346) TMC(notifyWait,1.1%,106) MAIN(running,95.1%,536) IDLE(ready,0.7%,29) AIN(delaying,0.8%,264), total 100.0%
                                Owned mutexes: HTTP(MAIN)
                                Last reset 00:05:55 ago, cause: power up
                                Last software reset at 2021-10-30 23:33, reason: User, GCodes spinning, available RAM 42456, slot 0
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a
                                Error status: 0x00
                                MCU revision 3, ADC conversions started 355962, completed 355961, timed out 0, errs 0
                                Step timer max interval 1474
                                MCU temperature: min 21.7, current 29.9, max 29.9
                                Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                Heap OK, handles allocated/used 99/5, heap memory allocated/used/recyclable 2048/224/158, gc cycles 0
                                Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32297, writes 11, timeouts 0, DMA errors 0
                                Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0
                                Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0
                                Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0
                                Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 32299, writes 9, timeouts 0, DMA errors 0
                                Driver 5: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0
                                Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 32296, writes 11, timeouts 0, DMA errors 0
                                Date/time: 2021-10-31 00:02:40
                                Cache data hit count 836168537
                                Slowest loop: 9.15ms; fastest: 0.07ms
                                === Storage ===
                                Free file entries: 10
                                SD card 0 not detected, interface speed: 0.0MBytes/sec
                                DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                === MainDDARing ===
                                === AuxDDARing ===
                                Bed heaters = 0 -1, chamberHeaters = -1 -1
                                Segments left: 0
                                Movement lock held by null
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Aux2 is idle in state(s) 0
                                Code queue is empty
                                === CAN ===
                                Messages queued 3111, received 6801, lost 0, longest wait 2ms for reply type 6026, peak Tx sync delay 3, free buffers 16 (min 15), ts 1778/1777/0
                                Tx timeouts 0,0,0,0,0,0
                                === SBC interface ===
                                State: 4, failed transfers: 1, checksum errors: 0
                                Last transfer: 4ms ago
                                RX/TX seq numbers: 13281/13281
                                SPI underruns 0, overruns 0
                                Disconnects: 0, timeouts: 0, IAP RAM available 0x10810
                                Buffer RX/TX: 0/0-0
                                === Duet Control Server ===
                                Duet Control Server v3.4.0
                                Code buffer space: 4096
                                Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                                Full transfers per second: 39.80, max time between full transfers: 87.9ms, max pin wait times: 51.1ms/11.5ms
                                Codes per second: 0.22
                                Maximum length of RX/TX data transfers: 3464/796
                                  SputnikOC3d
                                  Please mark this issue as resolved - it was due to m failure to notice mismatched firmware.
                                  Got the right FW on the Duet Mainboard via M997 S0
                                    @sputnikoc3d - well the rasp pi is not updated to 3.4.0 stable though
                                    grep of the isntalled duet versions indicates all are still on 3.4beta3 on the Pi
                                    Ideas to correct this ?
                                      I think you got your answer in your other thread.
