Looking for pictures of the 1LC with hotend
Hey everyone, Im looking for ideas for for mounting my 1LC and Hemera Revo hot end. I will be designing a bracket/mount in fusion360 to attached to a 2020 + MGN9 linear rail as my X-Axis. But that is for me to figure out.
I'd really just like to see some pictures of the 1LC mounted, wired, you know...the sexy stuff. Haha.
@ryanp Not the revo, but check this out https://miscsolutions.wordpress.com/2020/03/02/converting-the-e3d-tool-changer-to-duet-3-with-hemera-tools-part-1/
This is my mount for a Hemera on a CoreXY with toolboard and part cooling.
I have a PTFE tube sticking out through the bracket, guiding the filament..I have threaded brass inserts for mounting the toolboars end the fan shroud.
There is just enough room for my index finger to operate the lever on the hemera.
The fan shroud can be adjusted up/down by oval mounting holes in the shroud.
Lastly my BL-Touch bracket, mounted on the opposite side with the hemera bolts. The long part is a cable guide.
I have some makeshift wiring in place since my toolboard partly gave up on me.
I hope you will find some inspiration by this.
This post is deleted!
