    Solved Is there a terminal like YAT for RPI?
    Using Duet Controllers
    410
    • tecno
      tecno last edited by
      Having issues with WiFi on my Mini 5+ and would like to have the board connected to RPI that I normally use as as web interface.
      YAT I have in a laptop but then I need to find that one so it would be easier to use the RPI.
      So what serial terminal to install?
      Rushmere3D chrishamm 2 Replies Last reply Reply Quote 0
      • Rushmere3D
        Rushmere3D @tecno last edited by
        @tecno Putty, is what I use to run commands on the Pi
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
          You would want to use SSH (secure shell)
          In MacOS it's already there and you can use the terminal with the SSH command.
          In windows, you'd want to use a program like Putty
          tecno 1 Reply Last reply Reply Quote 0
          • tecno
            tecno @Phaedrux last edited by
            @Phaedrux
            In win I use YAT and plugin the USB cable - connect and do what I need to do.
            This is not anything I can do with Putty? If so how is Putty setup in RPI ?
              To access the pi terminal you would do so over the network.
              https://www.raspberrypi.com/documentation/computers/remote-access.html#ssh
              • tecno
                @phaedrux
                I want to access my Duet Mini5 via USB so I can get Wifi working as this drops out now and then.
                  Ok. So you want to access the Duet terminal from the Pi? Now I understand.
                  You can follow this guide and use the instructions for Linux
                  https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
                  • oliof
                    oliof last edited by
                    the screen command in Linux can be used as a serial terminal.
                    <>Creality CR-20 IDEX Duet3 mini 5+<>RatRig V-Minion SKR RRF 1.1<>
                    • tecno
                      tecno @oliof last edited by
                      @oliof
                      There is no screen i Raspberry OS
                      oliof 1 Reply Last reply Reply Quote 0
                      • oliof
                        oliof @tecno last edited by
                        @tecno you can install it, using the normal package installation system, i.e. sudo apt-get update; sudo apt install screen
                        • tecno
                          @oliof
                          How on earth do you get screen to connect to Duet board?
                          • tecno
                            @phaedrux said in Is there a terminal like YAT for RPI?:
                            Sorry but not one word on how to with Pi
                            • oliof
                              @tecno I am not close to my printers right now, but it's just the serial device as an argument to screen, so something like screen /dev/ttyUSB0 (the latter could be something else, check dmesg). Read the screen man page for other options like connection speed.
                              • tecno
                                @oliof
                                OK ls /dev/ttyACM0 is there
                                screen /dev/ttyACM0
                                screen terminating
                                Sorry but this kind of terminal is real PITA
                                • tecno
                                  tecno @tecno last edited by
                                  Managed to get CuteCom installed but no response on M115, only response I get is Error : VIN undervoltage when I power down.
                                  Short.. Printer has been working for +48hours and I needed to change filament so I decided to take a brake for dinner and shut off the printer. After that I have no connection with the Duet board other than above Undervoltage message, no other commands work. USB terminal feels a bit wonky/loose.
                                    VIN undervoltage may just mean that VIN power has been removed but the duet is still powered by 5v via usb.
                                    Where are you seeing the undervoltage event message?
                                    • tecno
                                      In CuteCom when unplugged power.
                                      Anyhow this morning I get response to commands, have not touched anything from last night so go figure what was going on yesterday evening. Config.g empty 'again'.
                                      • chrishamm
                                        chrishamm administrators @tecno last edited by
                                        @tecno minicom should work, too. It comes preconfigured for the Duet on DuetPi.
                                        Duet software engineer
                                        tecno 1 Reply Last reply Reply Quote 1
                                        • tecno
                                          tecno @chrishamm last edited by
                                          @chrishamm
                                          OK, satisfied with Cutecom.
                                            Phaedrux Moderator @tecno last edited by
                                            @tecno said in Is there a terminal like YAT for RPI?:
                                            Was this the original problem here or that it had happened previously?
                                            • tecno
                                              @phaedrux
                                              Both
                                                Had you edited config.g before it had gone empty?
                                                Was config.g missing completely, or just blank?
                                                Was config.g.bak present and complete?
                                                • tecno
                                                  @phaedrux
                                                  No
                                                  Blank
                                                  Present
                                                    Thanks. Had we replaced this board for you already when it first happened?
                                                    • tecno
                                                      @phaedrux
                                                      No config this morning, printer been offline for 2 days.
                                                      Today no config.g and no config.g.bak
                                                      re. board To be honest I do not remember. M552 S1 keeps me running
