    Printer stops mid print
    135
    • Woheho
      Woheho last edited by
      Hello Duet3d,
      i have the problem that my printer is stoping randomly in mid print. Usually i start longer prints for 4 to 5 days and its sad to see it stopping after 3 days or so. The printer aborts the job and the nozzle stops right over the print.
      I am using a Duet 3 MB 6HC with a RPI and 3.3 Firmware in a E3D Toolchanger.
      This is the M122 log: M122 Log.txt
      RepRapFirmware for Duet 3 MB6HC version 3.3 (2021-06-15 21:45:47) running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-9P63L-DJ3T8-6JKD8-3SC6N-TV439
      Used output buffers: 1 of 40 (16 max)
      Static ram: 150904
      Dynamic ram: 65264 of which 0 recycled
      Never used RAM 133112, free system stack 114 words
      Tasks: SBC(ready,168.0%,312) HEAT(delaying,1.5%,325) Move(notifyWait,19.2%,245) CanReceiv(notifyWait,4.4%,774) CanSender(notifyWait,1.1%,362) CanClock(delaying,0.7%,339) TMC(notifyWait,9.5%,59) MAIN(running,83.7%,922) IDLE(ready,0.0%,29), total 288.2%
      Owned mutexes: HTTP(MAIN)
      Last reset 96:17:19 ago, cause: software
      Last software reset at 2022-04-04 14:03, reason: User, GCodes spinning, available RAM 135632, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 295
      MCU temperature: min 34.2, current 40.5, max 43.0
      Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
      Heap OK, handles allocated/used 99/72, heap memory allocated/used/recyclable 4096/1540/256, gc cycles 147232
      Driver 0: position 24891, standstill, reads 38302, writes 43 timeouts 0, SG min/max 0/1023
      Driver 1: position -7440, standstill, reads 38302, writes 43 timeouts 0, SG min/max 0/1023
      Driver 2: position 194196, standstill, reads 38302, writes 43 timeouts 0, SG min/max 0/1023
      Driver 3: position 0, standstill, reads 38334, writes 11 timeouts 0, SG min/max 0/0
      Driver 4: position 0, standstill, reads 38334, writes 11 timeouts 0, SG min/max 0/0
      Driver 5: position 0, standstill, reads 38303, writes 43 timeouts 0, SG min/max 0/1023
      Date/time: 2022-04-08 14:21:14
      Slowest loop: 160.40ms; fastest: 0.03ms
      === Storage ===
      Free file entries: 10
      DMs created 125, maxWait 670924ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 4063605, completed moves 4063605, hiccups 0, stepErrors 0, LaErrors 7740, Underruns [20, 2, 149], CDDA state -1
      === AuxDDARing ===
      Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 0 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File* is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC* is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === CAN ===
      Messages queued 6645108, received 11100711, lost 0, longest wait 2ms for reply type 6049, peak Tx sync delay 402, free buffers 49 (min 31), ts 1733200/1733199/0
      Tx timeouts 0,0,0,0,0,0
      === SBC interface ===
      State: 4, failed transfers: 4, checksum errors: 9999
      Last transfer: 1ms ago
      RX/TX seq numbers: 55816/31862
      SPI underruns 9999, overruns 9999
      Disconnects: 3, timeouts: 2, IAP RAM available 0x2c83c
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.3.0
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz
      Full transfers per second: 46.43, max wait times: 547.6ms/0.0ms
      Codes per second: 13.08
      Maximum length of RX/TX data transfers: 3988/1792
      On the Pi I found this error message: Syslog.txt
      see uploaded txt file otherwise post is too long
      Is it a problem with the SPI cable or is the duet crashing ? How can i stop these ghost stops ?
      jay_s_uk chrishamm 2 Replies Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk @Woheho last edited by
        @woheho i would suggest upgrading to 3.4 and seeing if the issue occurs
        Woheho 2 Replies Last reply Reply Quote 0
        • Woheho
          Woheho @jay_s_uk last edited by
          @jay_s_uk Ok i will give it a try.
          • Woheho
            @jay_s_uk So i tried with 3.4 and it stopped again.
            Here is the log file:
            Syslog2.txt
            jay_s_uk 1 Reply Last reply Reply Quote 0
            • jay_s_uk
              @woheho looks like you lost connection between the SBC and the duet.
              Can you post a photo of the wiring between the two?
              I would also suggest trying to reseat the cable
              Woheho 1 Reply Last reply Reply Quote 0
              • chrishamm
                chrishamm administrators @Woheho last edited by
                @woheho Please flash your SBC's microSD card again with our latest DuetPi/DuetPi lite image. We've had a report that the Bullseye-based DuetPi image could cause unexpected lags/disconnects and that image was the default for a few days before we replaced it again with the previous image. The older Buster-based image is not affected by the mentioned bug. We're still investigating why it occurs (perhaps a Linux kernel issue) but I have not yet figured out why it occurs on the newer image.
                Duet software engineer
                Woheho 1 Reply Last reply Reply Quote 1
                • Woheho
                  Woheho @chrishamm last edited by
                  @chrishamm I am a little bit confused about the versions. When i was at 3.3 i had the 5.10.17-v7l+ kernel with buster 10. Then i updated via sudo apt-get upgrade and i am now on 5.10.103-v7l+, which is also Debian 10 (buster). So i never had the bullseye-based image on my pi right ?
                  • Woheho
                    @jay_s_uk I skrewed everything down in the beginning of my built and never touched it again. So i dont think that the cable is sitting loose or something. Could i shield the cable with tin foil or something ?70ad0929-9351-4a21-8dce-d0efc9384479.jpg
                    jay_s_uk Tidofelder 3 Replies Last reply Reply Quote 0
                    • jay_s_uk
                      @woheho no issues I can see there that I can comment on
                      • Tidofelder
                        Tidofelder @Woheho last edited by
                        This post is deleted!
                        • Tidofelder
                          • Woheho
                            Woheho @Tidofelder last edited by
                            @tidofelder Yeah, should not be an issue. This line is not used any more.
                              What kind of SD card is in use in the Pi?
                              • Woheho
                                Woheho @Phaedrux last edited by
                                @phaedrux Its a Sandisk Ultra 64GB Class 10 (1) Red-Grey.
                                  Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
