    Poor surface finish
    27
    1.2k
    • jens55undefined
      jens55 @mrehorstdmd
      @mrehorstdmd, the speed limiting happened because of layer time. Once that was reduced from 3 sec to 1 sec, the speed was back up to what it was set to in Cura.
      In the past I had set jerk to 25 but as it turns out, I had turned off jerk control for some reason or another.
      • infiniteloopundefined
        infiniteloop
        @jens55 said in Poor surface finish:
        Apparently as of RRF 31. speed factor does not affect extrusion speed.
        I'm still at 3.3b4, but up to that version, I can assure that extrusion follows the speed factor precisely. Apparently, with your apparatus, other factors play a role 🙄
        jens55undefined 1 Reply Last reply Reply Quote 0
        • jens55undefined
          jens55 @infiniteloop
          @infiniteloop, well that is quite possible since making assumptions and jumping to conclusions is one of my fav past-times 😞
          It just seemed to fit - proper extrusion at the original speed, increase 'speed factor' and see under extrusion. While it is possible that I was pushing the extruder too much, in this case I was going relatively slow and would not have thought that I was anywhere near the hot end limit.
          • rjenkinsgbundefined
            rjenkinsgb @jens55
            @jens55 From the way the defects occur at similar locations in different consecutive layers, I suspect something mechanically sticking - eg a bit of grit in a bearing or a dry bearing.
            That could explain the blob or melting effect, if the nozzle momentarily pauses them jumps past that spot once the drive system has wound up enough??
            Robert J.
            Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
            mrehorstdmdundefined 1 Reply Last reply Reply Quote 0
              dc42 administrators @jens55
              Apparently as of RRF 31. speed factor does not affect extrusion speed. I am not sure why this was changed from the earlier versions of RRF where speed factor modified all speed settings including extruder speed.
              Speed factor is not applied to extruder-only moves, i.e. retraction, reprime, filament loading and unloading.
              • jens55undefined
                jens55 @dc42
                @dc42, thanks for the clarification !
                • mrehorstdmdundefined
                  mrehorstdmd @rjenkinsgb
                  @rjenkinsgb I had an extruder motor cable failure several years ago when I used a too small bend radius in a drag chain. It would cause the extruder to cut out momentarily at specific XY locations in the prints. It took a while to figure out what was happening. The wires had fractured inside their own insulation, the result of being bent too many times.
