    Hobby servo for probe shutting down duet.
    347
    • cj19944
      cj19944 last edited by
      Hi guy
      I have a setup where a hobby servo is ment to retract and deploy a probe that should work in a heated environment. Here is the link to the probe https://hightemp3d.org/shop/hightemp3d/remoteht-high-temperature-bed-level-probe-2/. I am using a duet 3 6hc, in a cartisan style of machine. When i send the command to deploy or retract the probe the machine shuts down. The z probe is working correctly i have tried play around with different combinations in my config but to no avail.config (1).g retractprobe.g deployprobe.g
      A Former User 1 Reply Last reply Reply Quote 0
        Can you send M122 after the machine has come back up after shutting down and M98 P"config.g" and share the results?
        When it "shuts down" what exactly happens? Does the board reset?
        cj19944 1 Reply Last reply Reply Quote 0
        • cj19944
          cj19944 @Phaedrux last edited by
          @phaedrux
          m122
          RepRapFirmware for Duet 3 MB6HC version 3.4.0 (2022-03-15 18:57:24) running on Duet 3 MB6HC v1.01 or later (standalone mode)
          Board ID: 08DJM-956L2-G43S8-6JTD8-3SS6K-9B1AH
          Used output buffers: 1 of 40 (13 max)
          Static ram: 151000
          Dynamic ram: 95780 of which 0 recycled
          Never used RAM 103892, free system stack 208 words
          Tasks: NETWORK(ready,26.4%,221) ETHERNET(notifyWait,0.2%,168) HEAT(notifyWait,0.0%,327) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,333) TMC(notifyWait,7.9%,92) MAIN(running,65.1%,1101) IDLE(ready,0.4%,30), total 100.0%
          Owned mutexes:
          Last reset 00:00:23 ago, cause: power up
          Last software reset at 2022-04-14 23:57, reason: User, GCodes spinning, available RAM 103860, slot 1
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          Step timer max interval 126
          MCU temperature: min 25.9, current 26.6, max 26.7
          Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.1, current 12.1, max 12.3, under voltage events: 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0, mspos 8, reads 64031, writes 14 timeouts 0
          Driver 1: standstill, SG min 0, mspos 8, reads 64031, writes 14 timeouts 0
          Driver 2: standstill, SG min 0, mspos 8, reads 64032, writes 14 timeouts 0
          Driver 3: standstill, SG min 0, mspos 8, reads 64032, writes 14 timeouts 0
          Driver 4: standstill, SG min 0, mspos 8, reads 64035, writes 11 timeouts 0
          Driver 5: standstill, SG min 0, mspos 8, reads 64035, writes 11 timeouts 0
          Date/time: 2022-04-15 12:17:32
          Slowest loop: 1.79ms; fastest: 0.05ms
          === Storage ===
          Free file entries: 10
          SD card 0 detected, interface speed: 25.0MBytes/sec
          SD card longest read time 0.9ms, write time 0.0ms, max retries 0
          DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === CAN ===
          Messages queued 210, received 0, lost 0, boc 0
          Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 118/0/0
          Tx timeouts 0,0,117,0,0,91 last cancelled message type 4514 dest 127
          === Network ===
          Slowest loop: 4.12ms; fastest: 0.02ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
          HTTP sessions: 2 of 8
          • Ethernet -
            State: active
            Error counts: 0 0 1 0 0
            Socket states: 5 2 2 2 2 0 0 0
          when i send the command to deploy or retract the small servo rotates and then the machine resets says connection lost please wait. then restarts
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          • T3P3Tony
            T3P3Tony administrators @cj19944 last edited by
            @cj19944 that servo is rated 500-900mA current draw. How are you supplying 5V to the 6HC?
            www.duet3d.com
            • A Former User
              A Former User @cj19944 last edited by
              This post is deleted!
              • cj19944
                cj19944 @T3P3Tony last edited by
                @t3p3tony
                I get it of the main board. Is this wrong sorry im not an electronics person
                Phaedrux T3P3Tony dc42 3 Replies Last reply Reply Quote 0
                • cj19944
                  cj19944 @Guest last edited by
                  @arnold_r_clark
                  What temp will it work up to, maybe I need to change
                  • A Former User
                    • cj19944
                      @arnold_r_clark
                      Do you have link please
                        Phaedrux Moderator @cj19944 last edited by
                        @cj19944 said in Hobby servo for probe shutting down duet.:
                        @t3p3tony
                        So just the 24v from the PSU then.
                        • T3P3Tony
                          @cj19944 that should be correct,
                          www.duet3d.com
                            dc42 administrators @cj19944 last edited by
                            @cj19944 drawing 900mA from the 5V rail of a 6HC is OK. But the servo may have a higher stall current. The maximum external 5V load supported by the 6HC is 3A.
                            • A Former User
                              • cj19944
                                cj19944 @dc42 last edited by
                                @dc42 i have taken it from the 5v .i05 rail should i use another pin.
                                Thanks
                                cj19944 1 Reply Last reply Reply Quote 1
                                • cj19944
                                  cj19944 @cj19944 last edited by
                                  @cj19944 Hi guys fixed this problem by switching 5v pin to my 3.3v pin on my set up must of been something to do with stall current something I obviously don't understand to much, appreciate everyone's help.
                                  cj19944 T3P3Tony 2 Replies Last reply Reply Quote 0
                                  • cj19944
                                    @cj19944
                                    All this did was just not shut the machine down.
                                    • T3P3Tony
                                      the servo you linked did not look like it would work properly run from 3.3V. can you send a picture of how it you have it wired?
                                      www.duet3d.com
                                      • cj19944
                                        This was my original setup, then i swapped 5v to the 3.3v power the machine did not shut down but the motor also did not move. I have ordered the Schottky diode and 220uF capacitor and an external 5v source for if that does not work. If you wouldn't mind if confirming i do have the wires wired up correctly that would be much appecitated thanks.
                                        • cj19944
                                          @cj19944 Just used an external 5v power supply and all is working okay thanks again.
                                          T3P3Tony 1 Reply Last reply Reply Quote 1
                                          • T3P3Tony
                                            @cj19944 thanks for confirming it. Its interesting to see that that servo has a high enough stall current to drop the 5V supply on the 6HC.
                                            www.duet3d.com
