    Cant extrude or retract
    • brianundefined
      brian
      Upgraded to v3.4 from v3.3 and now cannot extrude or retract in the DWC, menus is greyed out. Also cannot move axis unless fully homed, which is annoying. Otherwise everything seems to be working.
      infiniteloopundefined 1 Reply Last reply Reply Quote 0
      • infiniteloopundefined
        infiniteloop @brian
        @brian In DWC, extrude/retract are by default disabled if the hotend is cold and the tool is not active (i.e. not selected). If your case is different, please provide some more details.
        The axes are disabled, because the Duet does not "know" where the print head actually is as long as the axes have not been homed - this is a measure of precaution so you can’t inadvertently ram the head into the bed or override limits.
        It is however no problem to override that limitation: With M564 S0 H0, you unlimit the axes. Simply put this gCode into a macro, then you can easily access it if needed.
          You probably don't have the tool selected at startup, or don't have an extruder motor assigned to the tool. Post your config.g so we can see which it is.
          It's an attempt to keep from damaging their machines. Override it at your own risk.
          brianundefined 1 Reply Last reply Reply Quote 0
          • brianundefined
            brian @Phaedrux
            @phaedrux Heres the config. Oddly it says v 3.3 yet the DWC says v3.4
            Configuration file for Duet WiFi (firmware version 3.3)
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Feb 02 2022 14:20:11 GMT-0800 (Pacific Standard Time)
            M550 P"Brian's Build 3" ; set printer name
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M350 X32 Y32 Z32 E32 I0 ; configure microstepping without interpolation
            M92 X320.00 Y320.00 Z2560.00 E1400.00 ; set steps per mm all work except E
            M566 X800.00 Y800.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)dropping 100 at a time from 1200?
            M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
            M201 X900.00 Y900.00 Z200.00 E200.00 ; set accelerations (mm/s^2)
            M906 X800 Y800 Z1600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X430 Y410 Z650 S0 ; set axis maxima
            M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
            M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
            M574 Z2 S2 ; configure Z-probe endstop for high end on Z
            M558 P1 C"zprobe.in+!pson" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
            G31 P500 X0 Y0 Z2.48 ; set Z probe trigger value, offset and trigger height 2.1 0.4 nzzl
            M557 X15:215 Y15:195 S20 ; define mesh grid
            M143 H0 S310 ; set temperature limit for heater 0 to 120C
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin e0temp
            ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
            ;M143 H1 S310 ; set temperature limit for heater 1 to 280C
            ;M143 S300 ; Set maximum heater temperature to 300C
            M140 H-1 ; Disable heated bed
            ;M305 P1 X201 ; (board v0.4)
            ;M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
            ;M305 P2 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 2
            M307 H1 A350 C500 D50 B1; I added this line for pellet extruder C500 gives more timeout time; re-ativated as too many timeouts
            M563 P0 S"Hot End" D0 H1 F0 ; define tool 0
            M501 ; Load config-overrides.g
            ;T0
            Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
            • Rushmere3Dundefined
              Rushmere3D @brian
              @brian Uncomment T0 at the bottom.
              And the bit referring to 3.3 is what firmware the config tool was set to when creating the config.g.
              Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
              brianundefined 1 Reply Last reply Reply Quote 1
              • brianundefined
                brian @Rushmere3D
                @rushmere3d Thank you.
