sensorless homing random wrong direction
This post is deleted! -
@droftarts
"Homing issue"= going randomly to the incorrect sideS1 current 200mA issue homing
S1 current 400mA issue homing
S1 current 500mA homing ok ( have my doubts on this value being ok)
S1 current 600mA issue homingS5 current 200mA issue homing
S5 current 400mA homing ok ( have my doubts on this value being ok)
S5 current 500mA issue homingS10 current 200mA issue homing
S10 current 400mA homing ok ( have my doubts on this value being ok)
S10 current 500mA issue homingS15 current 200mA issue homing
S15 current 400mA homing ok ( have my doubts on this value being ok)
S15 current 500mA issue homings20 current 200mA issue homing
s20 current 400mA homing ok ( have my doubts on this value being ok)
s20 current 500mA issue homing
s20 current 600mA issue homings30 current 200mA issue homing
s30 current 400mA homing ok
s30 current 500mA issue homing
s30 current 1000mA homing okspent most of the Day testing values above, i still have the issue that the "emergency stop " button seems to toggle the homing direction, also tried changing Jerk to see if that would make any difference (800 and 400)
another observation if i Home X and it goes in the correct direction , then the stepper motors time out, (M84 X Y S20) and i home X again it also goes in the wrong direction. -
@moth4017 I can think of are three possible reasons why the motor may go in the wrong direction:
The driver is signalling a stall at the start of the G1 H1 X-350 homing move, so it skips that and proceeds directly to the G1 X150 move. This is the most likely explanation.
If the motor currrent is set very low and the motor is under load, it may move in the wrong direction.
If only one motor phase is connected then the motor will either vibrate or move in a random direction.
From your homex.g file:
@moth4017 said in sensorless homing random wrong direction:
M906 X600 Y600 ; Lower motor current
We recommend that you use M906 only in config.g. When you need to reduce motor current temporarily, use M913 instead to set a percentage of the current set by M906. Also, don't reduce the motor current until you want to do the stall homing. StealthChop calibration should be done at normal motor current.
G1 H1 X-0.2 F3000 ; move a little for cal of sensorless homing / not stalled G1 H1 Y-0.2 F3000 ; move a little for cal of sensorless homing / not stalled M400 ; make sure everything has stopped before we make changes
That's not a valid stealthChop tuning sequence. Use something like this instead (at normal motor current):
M17 X Y ; enable X and Y motor drivers G1 P140 ; pause to allow the drivers to characterise the motor
You can then reduce motor current (using M913) and do the stall homing move. 30% motor current is usually good.
However, there is the possibility that the motor may already be signalling a stall. So I recommend that after homing an axis, you back off a few mm and repeat the homing move. For example:
M913 X30 ; use X30 Y30 if the machine is CoreXY G91 G1 H1 X-350 ; Home X-Axis G1 H2 X10 ; back off a little (on a CoreXY machine use X10 Y10) G1 H1 X-350 ; Home X-Axis again M913 X100 ; restore motor current (use X100 Y100 is the machine is CoreXY)
HTH David
im still getting the wrong direct alternating after pressing the
"emergency stop" button.
new homex.g; homex.g echo "start" M569 P0.0 ; Check status in console M569 P0.1 ; Check status in console G91 ; relative positioning M569 P0.0 S1 D3 V10 ; set to stelth chop M569 P0.1 S1 D3 V10 ; set to stelth chop M915 P0.0:0.1 S20 F0 R1 H200 ; Configure Z-Axis Stall Detection echo "stall detection setup" M17 X ; Check status in console M17 Y ; Check status in console G1 P140 G1 H1 X-0.2 F3000 ; move a little for cal of sensorless homing / not stalled G1 H1 Y-0.2 F3000 ; move a little for cal of sensorless homing / not stalle echo "lower motor current" M913 X50 Y50 ; Lower motor current % G4 P150 ; wait 150ms M574 X1 Y2 S4 ; Configure Z-Axis stall detection homing M569 P0.0 ; Check status in console M569 P0.1 ; Check status in console echo "home x" G1 H1 X-350 F6000 ; Home Z-Axis actuators independently M569 P0.0 ; Check status in console M569 P0.1 ; Check status in console G90 ; absolute positioning G1 X150 F6000 ; move to center of bed ;revert back echo "after revert back" M913 X100 Y100 ; Reset motor current % M569 P0.0 S1 D2 ; reset motors back to spread cycle, M569 P0.1 S1 D2 ; reset motors back to spread cycle, M569 P0.0 ; Check status in console M569 P0.1 ; Check status in console
@moth4017 you haven't done the double homing move that I recommended. Assuming your machine is CoreXY, try this.
; homex.g echo "start" M569 P0.0 ; Check status in console M569 P0.1 ; Check status in console G91 ; relative positioning M569 P0.0 S1 D3 V10 ; set to stealth chop M569 P0.1 S1 D3 V10 ; set to stealth chop M915 P0.0:0.1 S20 F0 R1 H200 ; Configure Stall Detection echo "stall detection setup" M17 X Y G1 P140 echo "lower motor current" M913 X50 Y50 ; Lower motor current % M574 X1 Y2 S4 ; Configure Z-Axis stall detection homing M569 P0.0 ; Check status in console M569 P0.1 ; Check status in console echo "home x" G1 H1 X-350 F6000 G1 H2 X20 Y20 G1 H1 X-350 F6000 M569 P0.0 ; Check status in console M569 P0.1 ; Check status in console G90 ; absolute positioning G1 X150 F6000 ; move to center of bed ;revert back echo "after revert back" M913 X100 Y100 ; Reset motor current % M569 P0.0 S1 D2 ; reset motors back to spread cycle, M569 P0.1 S1 D2 ; reset motors back to spread cycle, M569 P0.0 ; Check status in console M569 P0.1 ; Check status in console
Regarding M906/913 - You recommend using 913 in the homing file. 913 is a function of 906 and 913 is not an exact number so it does not make sense to use 913 as it does not tell you what current is being used unless you pull out a calculator. Why is it bad practice to use 906 in the homing file when this is what sets the motor current and then you know what currents will work?
PS! I have the same machine as @moth and a fully working stallguard homing on all 5 axes (XYZUV) but I run a Duet wifi 2 with a Duex5 so different drivers. I have how ever experienced the same problems as @moth4017 before I started moving my printhead between homing X and Y. After I made the change of moving my printhead between homex an homey it has been working 100%
; homex.g ; called to home the X axis M400 ; make sure everything has stopped before we make changes G91 ; relative positioning M915 P0:1 S4 F0 R0 ; Configure Stall Detection M906 X750 Y750 ; Lower motor current G1 F9000 G1 H1 X350 ; Home Z-Axis independently M400 ; make sure everything has stopped before we make changes M906 X1000 Y1000 ; Reset motor current G90 ; absolute positioning G1 F12000 X155
; homey.g ; called to home the Y axis ; M400 ; make sure everything has stopped before we make changes G91 ; relative positioning M915 P0:1 S4 F0 R0 ; Configure Z-Axis Stall Detection M906 X750 Y750 ; Lower motor current by 50% G1 F9000 G1 H1 Y-350 ; Home Z-Axis actuators independently M400 ; make sure everything has stopped before we make changes M906 X1000 Y1000 ; Reset motor current G90 ; absolute positioning G1 Y160 ; move to probe position midle bed (x155 y150)
; homeall.g ; called to home all axes M400 M98 P/sys/homey.g ;P define the parameter and is not part of the name M98 P/sys/homex.g ;P define the parameter and is not part of the name M98 P/sys/homez.g ;P define the parameter and is not part of the name
hi did try double homing worked on X axis but not so good on Y , the Y axis seems to move in the x direction
x home
G1 H1 X-350 F6000
G1 H2 X10 Y10
G1 H1 X-350 F6000y home
G1 H1 Y350 F6000
G1 H2 X-10 Y-10
G1 H1 Y350 F6000 -
G1 H2 X-10 Y-10
That line in homey.g needs to be changed because as it stands it will back off in the -X direction. I think the correct combination to back off in the -Y direction is: G1 H2 X-10 Y10
did some tests tonight with the "double bump" on homing , sometimes there was only a single bump , i did see it go 10mm in the wrong direction though, so didnt do the "G1 H1 X-350 F6000" , is this now down to tuning the "S" parameter and current?echo "home x"
G1 H1 X-350 F6000
G1 H2 X10 Y10
G1 H1 X-350 F6000echo "Home Y"
G1 H1 Y350 F6000
G1 H2 X-10 Y10
G1 H1 Y350 F6000 -
So , im still getting a random wrong direction now and then but ill put that down to tuning the "S" parameter and current.
if i switch the machine on and do a home X it always goes in the wrong direction can not remember it doing this in the previous version.
solution and files here :- https://forum.duet3d.com/topic/28653/3-4-1-rc2-g30-turns-off-z-motors/14?_=1653704200634
