    First cut success - with questions!
    Duet Web Control
    8
    66
    3.4k
    • Nightowlundefined
      Nightowl
      I've completed my first cut on the RatRig KillerBee 1075 and it was successful, so thank you to all of those who've been helping me over the last few weeks (months, really!)
      Needless to say, I have a couple of questions with, hopefully, fairly straightforward yes/no answers.
      When running the first 'air cut' test project, I checked the Pause and Resume buttons, like you do, and the Pause button moved the lifted Z by 5mm and moved to X and Y zero, which with this machine is at the front left, but it didn't turn off the spindle, either.
      I want to change this so that Pause turns the spindle off (M5) and moves the Z to 5mm below it's maximum height and then the X and Y axes to a central point of the spoil board. Is it just a simple case of editing the pause.g file to add the M5 file and edit the co-ordinates to those I want to use, and add an M3 command to the resume.g file? I'm rather hoping the spindle speed will be saved (as the X, Y and Z coordinates are) when the Pause is activated and then resumed when Resume button is activated.
      I think the existing pause.g and resume.g are a legacy from using the RRF config tool, so it certainly has lines I don't need, like M83 and retracting/extruding 10mm of filament!
      Thank you
      EDIT: I meant to add the text from the existing files, sorry:
      ; pause.g
      M83 ; relative extruder moves
      G1 E-10 F3600 ; retract 10mm of filament
      G91 ; relative positioning
      G1 Z5 F360 ; lift Z by 5mm
      G90 ; absolute positioning
      G1 X0 Y0 F6000 ; go to X=0 Y=0
      ; resume.g
      G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
      G1 R1 X0 Y0 Z0 ; go back to the last print move
      G1 E10 F3600 ; extrude 10mm of filament
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
      engikeneerundefined 1 Reply Last reply Reply Quote 0
      • engikeneerundefined
        engikeneer @Nightowl
        @nightowl999 yes it is that simple 🙂
        Just remember to turn anything on in resume that you turn off
        i3 clone with a bunch of mods
        Nightowlundefined 1 Reply Last reply Reply Quote 1
        • Nightowlundefined
          Nightowl @engikeneer
          Thanks, @engikeneer.
          So how do I do this with the spindle control? Will adding just the M3 command run the spindle at the same 'saved' speed? I'm not too clear on that!
          As it's a CNC machine I would prefer to raise the Z axis to 5mm below its maximum height on Pause, so how would I counteract that in the Resume?
          engikeneerundefined dc42undefined 2 Replies Last reply Reply Quote 0
            @nightowl999 yes it will use the last set spindle speed if no S parameter is given (according to the docs at least...). I don't have a CNC to test it on though
            • Nightowlundefined
              Thanks again, @engikeneer
              These are my proposed changes (except for the Z height, which I'll experiment with!), and I'll check if they work tomorrow.
              ; pause.g
              M5 ; stop the spindle
              G1 X0 Y0 F2400 ; go to X=0 Y=0
              ; resume.g
              G1 R1 X0 Y0 Z5 F2400 ; go to 5mm above position of the last print move
              M3 : turn the spindle on
              Thanks again 👍
                dc42 administrators @Nightowl
                @nightowl999 said in First cut success - with questions!:
                I have to admit that I hadn't given any thought to restoring spindle speeds on resume. Spindle speeds are not saved in the restore point that is created when you execute a pause. However, I think you can achieve it like this. Caution: I have not tested this!
                In config.g add this
                global savedSpindleSpeed = 0
                In pause.g after the G1 Z move (see later) add this:
                if currentTool >= 0 & tools[state.currentTool].spindle >= 0
                  set global.savedSpindleSpeed = tools[state.currentTool].spindleRpm  ; save the current spindle RPM
                  M5   ; turn spindle off
                In resume.g (before the final move to the original position, if you have one):
                  M3 S{global.savedSpindleSpeed}
                  G4 S1  ; wait 1 second to allow the spindle to spin up
                Change these lines in pause.g:
                to:
                G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5}
                In resume.g you probably want to change this line:
                to:
                G1 R1 X0 Y0 F2400 ; go to above the paused XY position, keeping the current Z
                OwenDundefined 1 Reply Last reply Reply Quote 2
                • OwenDundefined
                  OwenD @dc42
                  @Nightowl999
                  There's a closing brace for the max() function missing on this line
                  should be
                  G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5)}
                  • Nightowlundefined
                    Nightowl
                    You guys are pretty damn good at this!
                    Thank you @dc42, @OwenD and @engikeneer. I'll make the changes/updates tomorrow and let you know how I get on, as this might be of use to others!
                    Thanks again 👍 👍 👏
                    Edit: Am I correct in thinking the M5 and M3 commands are where you've put them (i.e. last and first, so the cutter in the spindle will cut the material rather than snap, as a safety precaution? Obviously it would be better not to hit anything at all, but just in case...!
                    Also, is indenting of line of code important?
                    It's late, but this is how I've interpreted your suggestions (without the description text but including the original, obsolete lines REM's out):
                    ; pause.g
                    ; M5
                    ; G91
                    ; G1 Z5 F360
                    ; G90
                    ; G1 X0 Y0 F2400
                    M5
                    ; resume.g
                    ; G1 R1 X0 Y0 Z5 F2400
                    G4 S1
                    G1 R1 X0 Y0 F2400
                    ; G1 R1 X0 Y0 Z0
                    ; M3
                    o_lampeundefined Nightowlundefined 2 Replies Last reply Reply Quote 0
                    • o_lampeundefined
                      o_lampe @Nightowl
                      To me it looks like there is a little problem with this line...what if the userPosition is already higher than (max-5)? Would it try to move +5 anyways and hit the upper limit or stop automatically at max?
                      Either way, it would be best to test this scenario to see if it returns to the right hight after resume
                      //sidenote: for further reference it would be best to move this thread to either Meta commands or CNC section (IMHO)
                      Nightowlundefined dc42undefined JoergS5undefined 3 Replies Last reply Reply Quote 0
                      • Nightowlundefined
                        Nightowl @o_lampe
                        That's a bit worrying, @o_lampe, but I'm no code writer.
                        @o_lampe said in First cut success - with questions!:
                        My logical mind makes me think that line moves the Z axis up 5mm from it's current position, then moves to the maximum Z height less 5mm. I'm assuming the [2] refers to the "3rd" axis (e.g. X would be [0], Y [1] and Z [2])?
                        If that is the case, would only the following be needed to move the Z axis 5mm below the Z max:
                        G1 Z{max(move.axes[2].max-5)}
                        Could I enter that as a command line to test it?
                        Thank you
                          dc42 administrators @o_lampe
                          The move would be limited to max Z.
                          Nightowlundefined 1 Reply Last reply Reply Quote 0
                          • Nightowlundefined
                            Nightowl @dc42
                            I guess you've answered my question, thank you @dc42!
                            • Nightowlundefined
                              Nightowl
                              Implementing those changes has caused a different problem, I can't run any g-code files.
                              The console is reporting the following error:
                              M32 "0:/gcodes/Initial Test Cut.nc"
                              File 0:/gcodes/Initial Test Cut.nc selected for printing
                              Cancelled printing file 0:/gcodes/Initial Test Cut.nc, print time was 0h 0m
                              Error: G0/G1: target position outside machine limits
                              I've REM'd out the global variable in config.g, but that didn't make any difference. Does it matter where this is located within the config.g file? I've put it after General Preferences.
                              I can't get far enough to test the pause.g or resume.g files.
                                @nightowl999 which firmware version are you using? If you are using recent firmware that supports the 'global' command then I think you must have made another change at the same time. The position of that command in config.g is not critical, but I suggest near the end.
                                • Nightowlundefined
                                  Nightowl
                                  This has become rather perplexing...
                                  Yesterday I could run a couple of test cuts without any problem. In fact, I was really pleased!
                                  After implementing the changes above (although I didn't check the machine before I made those changes today!) the files won't run, reporting the error:
                                  So I reverted to the original pause.g and resume.g files and REM'd out the global command, but I still get the same issue.
                                  I have had the outside machine limits error before, when trying to sort the axes and limit switches out, but that got resolved.
                                  • Nightowlundefined
                                    Nightowl @dc42
                                    Board: Duet 3 MB6HC (MB6HC)
                                    Firmware: RepRapFirmware for Duet 3 MB6HC 3.3 (2021-06-15)
                                    Which is a bit weird, because I keep copies of the version upgrades (in case I need to go back) and the version I have in storage is 3.4
                                    • Nightowlundefined
                                      Nightowl @dc42
                                      Just updated the firmware, but there's no difference.
                                      I guess I'll start from scratch and go through the RRF config tool again.
                                      Ho hum 😢 😢
                                        jay_s_uk
                                        @nightowl999 why? its obvious whats going on. you're trying to run a job outside the axis limits. redoing the config won't change that
                                        • fcwiltundefined
                                          fcwilt @Nightowl
                                          IMHO the RRF config tool is a barrier to learning the g-code that controls your machine.
                                          The issue of trying to move past the axis limits is simple. However you generated the code it was using axis limits that did not match your machine.
                                          How do you generate code for a CNC machine?
                                          Thanks.
                                          Nightowlundefined 2 Replies Last reply Reply Quote 1
                                          • Nightowlundefined
                                            Nightowl @fcwilt
                                            @jay_s_uk
                                            @jay_s_uk said in First cut success - with questions!:
                                            I guess I must be, but redoing the config (or at least looking at my original config to compare with the existing one) was the only place I felt I could reliably start from, but there is little difference between the two files.
