    3.4.1 rc2 G30 turns off Z motors
    Firmware installation
    682
    • moth4017undefined
      moth4017
      Board: Duet 3 Mini 5+ (Mini5plus)
      Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.1rc2 (2022-05-25)
      when doing a 3 point level with with 3.4.1 RC2
      G30 P0 X10 Y0 Z-99999 when 3 point leveling turns off Z motors,
      ;3PL
      echo "3PL"
      ;M401 ; deploy Z probe (omit if using bltouch)
      G28
      G30 P0 X10 Y0 Z-99999 		; probe near a leadscrew
      G30 P1 X290 Y0 Z-99999 		; probe near a leadscrew
      G30 P2 X150 Y280 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
      ;M402 ; retract probe (omit if using bltouch)
      G1 X0 Y0 F10000
      alankilianundefined infiniteloopundefined dc42undefined 3 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @moth4017
        @moth4017
        People are going to ask for:
        • A copy of config.g
        • The results of running M98 P"config.g"
        • The results of running M122 before and after the G30 command that causes the Z motors to "turn off"
        • moth4017undefined
          moth4017
          @alankilian
          G90                                            	; send absolute coordinates...
          M83                                            	; ...but relative extruder moves
          M550 P"Valkyrie 3030 V002"                     	; set printer name
          M669 K1     									; core xy
          M552 S1                                        	; enable network
          M586 P0 S1                                     	; enable HTTP
          M586 P1 S0                                     	; disable FTP
          M586 P2 S0                                     	; disable Telnet
          M569 P0.0 S1	D2								; physical drive 0 goes forwards
          M569 P0.1 S1    D2								; physical drive 1 goes forwards
          M569 P0.2 S1                                 	; physical drive 2 goes forwards ( blown needs replacing)
          M569 P0.3 S0                                	; physical drive 3 extruder
          M569 P0.4 S1 	D3								; physical drive 4 goes forwards D3=stealthchop
          M569 P0.5 S0 	D3								; physical drive 5 goes backwards
          M569 P0.6 S1 	D3								; physical drive 6 goes forwards
          M584 X1 Y0 Z0.4:0.5:0.6 E3		           		; set drive mapping FL,FR,RC
          M350 X16 Y16 I1                       			; configure microstepping with interpolation
          M350 Z16 E16 I1  								; configure microstepping with interpolation
          M92 X80.00 Y80.00  Z320.00  E562.00           	; set steps per m
          M566 X800.00 Y800.00 Z100.00 E100.00 P1        	; set maximum instantaneous speed changes (mm/min) jerk
          M203 X24000.00 Y24000.00 Z4000.00 E400.00   	; set maximum speeds (mm/min)
          M201 X2200.00 Y2200.00 Z300.00 E250.00 	     	; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E800 I30                	; set motor currents (mA) and motor idle factor in per cent
          ;M917 Z30
          M84  X Y Z S20									; Set idle timeout sec
          M208 X-20 Y-11 Z0 S1                            ; set axis minima "Travel Area"
          M208 X300 Y300 Z405 S0                         	; set axis maxima "Travel area"
          M574 X1 S4										; configure sensorless endstop, 1 = low end, 2 = high end. S4 multipule motors
          M574 Y2 S4										; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
          M574 Z2 S4										; configure sensorless endstop for high end on Z, 1 = low end, 2 = high end. S4 multipule motors
          M671 X-20:300:150 Y0:0:280 S25					; leadscrews at front left,front right, rear Center s= max correction factor  must be in same order as M584
          M558 P8 C"!io3.in" H10 F1000 T12000 R0 A4 S0.03  	; set Z probe type to unmodulated and the dive height + speeds
          G31 P500 Z0.3										; set Z probe trigger value, offset and trigger height bigger the posative number the closer to the bed
          G31 P500 X27 Y-11              						; set x,y trigger value, offset and trigger height
          M557 X10:290 Y10:290 S90                     		; define mesh grid
          ;Bed
          M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed T °C" 		; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"out0" T0 Q10                      					; create bed heater output on bedheat and map it to sensor 0
          M307 H0 R0.838 K0.331:0.000 D3.08 E1.35 S0.90 B0				; PDI info for 8mm aluminium bed 700w Heater NTC 100K 3950
          M140 H0                                       					; map heated bed to heater 0
          M143 H0 S120                                   					; set temperature limit for heater 0 to 120C
          ;extruder
          M308 S1 P"temp1" Y"pt1000" A"Extruder T °C"						; configure sensor 1 as thermistor on pin e0temp (104gt2)
          M950 H1 C"out1" T1                           					; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 R3.558 K0.357:0.000 D9.14 E1.35 S1.00 B0 V23.8			; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S280                                   					; set temperature limit for heater 1 to 280C
          ;Chamber
          M308 S2 P"temp2" Y"thermistor" T100000 B4267 A"Chamber T °C"	; configure sensor 2 as thermistor on pin temp2
          M950 H2 C"out5" T2												; create chamber heater output on 1.out0 and map it to sensor 2
          M307 H2 B0 S1.00												; disable bang-bang mode for the chamber heater and set PWM limit
          M141 H2															; map chamber to heater 2
          M143 H2 S100													; set temperature limit for heater 2 to 280C
          M308 S10 Y"mcu-temp" A"MCU"                           ; defines sensor 10 as MCU temperature sensor
          M308 S11 Y"drivers" A"Duet stepper drivers"           ; defines sensor 11 as stepper driver temperature sensor
          M950 F0 C"out4" Q250								; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1	C"Part Fan"							; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"out3" Q250								; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45	C"Extruder Fan"					; set fan 1 value. Thermostatic control is turned on
          M563 P0 D0 H1 F0									; define tool 0
          G10 P0 X0 Y0 Z0										; set tool 0 axis offsets
          G10 P0 R0 S0										; set initial tool 0 active and standby temperatures to 0C
          T0
          M98 P"/macros/home_max_Z"
          ;External Buttons
          M950 J1 C"!io2.in"			;config input pin	switch NO  connected to io2 and Gnd
          M581 P1 T0 C0				;T0 = emergency stop on trigger; T1 = pause print; T{N} = runs the macro "sys/trigger{N}.g", rising edge S1 falling edge S0
          ;M581 P1 T4 c0				;run a macro trigger4.g
          M582 T0 					; Check External Trigger
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          before G30
          M122
          RepRapFirmware for Duet 3 Mini 5+ version 3.4.1rc2 (2022-05-25 11:42:50) running on Duet 3 Mini5plus WiFi (standalone mode)
          Board ID: 3R9YY-6T9RL-D65J0-40KMN-2UW2Z-RHYT0
          Used output buffers: 2 of 40 (15 max)
          Static ram: 103684
          Dynamic ram: 110856 of which 24 recycled
          Never used RAM 24220, free system stack 154 words
          Tasks: NETWORK(ready,12.1%,216) HEAT(notifyWait,0.0%,346) Move(notifyWait,0.0%,286) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,339) TMC(notifyWait,1.1%,114) MAIN(running,84.7%,426) IDLE(ready,1.3%,29) AIN(delaying,0.8%,264), total 100.0%
          Owned mutexes: HTTP(MAIN)
          Last reset 00:00:17 ago, cause: software
          Last software reset at 2022-05-28 11:51, reason: User, GCodes spinning, available RAM 24004, slot 1
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          MCU revision 3, ADC conversions started 17600, completed 17599, timed out 0, errs 0
          Step timer max interval 752
          MCU temperature: min 23.6, current 24.5, max 25.6
          Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/54/54, gc cycles 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 15, reads 1569, writes 9, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 14, reads 1569, writes 9, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 53, reads 1568, writes 9, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 55, reads 1568, writes 9, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: standstill, SG min 116, read errors 0, write errors 1, ifcnt 255, reads 1564, writes 14, timeouts 0, DMA errors 0, CC errors 0
          Driver 5: standstill, SG min 242, read errors 0, write errors 1, ifcnt 255, reads 1563, writes 14, timeouts 0, DMA errors 0, CC errors 0
          Driver 6: standstill, SG min 20, read errors 0, write errors 1, ifcnt 255, reads 1563, writes 14, timeouts 0, DMA errors 0, CC errors 0
          Date/time: 2022-05-28 11:52:05
          Cache data hit count 32596166
          Slowest loop: 1.75ms; fastest: 0.13ms
          === Storage ===
          Free file entries: 9
          SD card longest read time 1.0ms, write time 0.0ms, max retries 0
          DMs created 83, segments created 3, maxWait 198ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 2, completed 2, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === AuxDDARing ===
          Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is ready with "M122 " in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is doing "G4 S50 " in state(s) 0 0, running macro
          Aux2 is idle in state(s) 0
          Code queue is empty
          === CAN ===
          Messages queued 157, received 0, lost 0, boc 0
          Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 88/0/0
          Tx timeouts 0,0,87,0,0,68 last cancelled message type 4514 dest 127
          === Network ===
          Slowest loop: 17.17ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          - WiFi -
          Network state is active
          WiFi firmware version 1.25
          WiFi MAC address f0:08:d1:02:a1:0b
          WiFi Vcc 3.34, reset reason Power up
          WiFi flash size 2097152, free heap 27088
          WiFi IP address 192.168.0.19
          WiFi signal strength -56dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
          after G30
          G30
          Error: Probe was not triggered during probing move
          because the Z motors have turned off
          • OwenDundefined
            OwenD
            I'm not seeing that behaviour with 3.4RC2 on a Duet2
            What makes you think the Z motors are being turned off?
            Is G30 being called in a macro?
            If so, post it.
            moth4017undefined 1 Reply Last reply Reply Quote 0
            • moth4017undefined
              moth4017 @OwenD
              @owend
              ; bed.g
              echo "Bed.g "
              ;M561						; clear any bed transform
              ;G29							; probe the bed and enable compensation
              G28							; home
              G1 H2 Z25 F6000   		; lower Z again
              echo "start 3 point.g "
              G1 H2 Z25 F6000
              G1 H2 Z25 F6000
              G30 P2 X150 Y290 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
              G1 H2 Z25 F6000
              ;The value of the S parameter on the final G30 command in bed.g must equal the number of Z motors.
              • fcwiltundefined
                fcwilt @moth4017
                @moth4017
                Just FYI you don't need all those G1 H2 Z moves.
                • OwenDundefined
                  OwenD
                  I don't see any major issues in your config, but again I would ask how you are determining that the Z motor is being turned off?
                  The only error you've shown is the Z probe not activating.
                  There could be many reasons for that.
                  • moth4017undefined
                    moth4017 @OwenD
                    @owend
                    Hi the Z motors are turning off as the bed falls down ( belt driven)
                    OwenDundefined 1 Reply Last reply Reply Quote 0
                    • OwenDundefined
                      OwenD @moth4017
                      @moth4017
                      Do you have a cancel.g file?
                      If the print was cancelled because of the failed probing then perhaps you should look at cancel.g and/or stop.g for an M84 command.
                      • moth4017undefined
                        moth4017 @OwenD
                        @owend
                        i dind see the "cancel.g" in the console
                        ;cancel.g
                        echo "Cancel.g "
                        and it didnt run the Home max.g file
                        ; home_max_Z
                        M400                                                ; make sure everything has stopped before we make changes
                        G91                                 				; relative positioning
                        M569 P0.4 S1 D3 V10                                 ; set to stelth chop
                        M569 P0.5 S0 D3 V10     							; set to stelth chop
                        M569 P0.6 S1 D3 V10									; set to stelth chop
                        M915 P0.4:0.5:0.6 S0 F0 R1 H200                   	; Configure Z-Axis Stall Detection
                        M574 Z2 S4                                       	; Configure Z-Axis stall detection homing
                        G1 H1 Z-0.2 F3000									; move a  little  for cal of sensorless homing / not stalled
                        M913 Z70	                                  		; Lower motor current by 50%
                        G1 H1 Z350                           				; Home Z-Axis actuators independently
                        G92 Z290											; set a Z height
                        G90													; absolute positioning
                        ;revert back
                        M913 Z100                                    		; Reset motor current
                        M569 P0.4 S1 D2                                    	; reset motors back to spread cycle,
                        M569 P0.5 S0 D2     								; reset motors back to spread cycle,
                        M569 P0.6 S1 D2										; reset motors back to spread cycle,
                        M84													; turn off motors
                        • infiniteloopundefined
                          infiniteloop @moth4017
                          @moth4017 To throw my two pence in: Can the faulty behaviour correlate with sensorless homing, I.e. stall detection? That’s activated for the Z axis, as well as stealth chop mode. - Just an idea, I’m far from being an expert with this …
                            dc42 administrators @moth4017
                            @moth4017 the only reasons I can think of why the Z motors would turn off are:
                            1. They are being commanded to turn off by a M18 or M84 command
                            2. The motor current is being set very low by a M906 or M913 command. For example, if M913 has been used to reduce motor current during homing or probing, and the M913 command to restore motor current to 100% afterwards is incorrect.
                            3. The drivers have detected a short circuit condition. Incorrect use of stealthChop mode can trigger this according to the TMC22009 datasheet.
                            4. The board has reset. On this case, all motors driven directly by the Duet will turn off and the reset reason will be reported if you run M122.
                            • oliofundefined
                              oliof
                              homeall.g may be different to homez.g. Can we see that as well, please?
                              • moth4017undefined
                                moth4017
                                @dc42, @infiniteloop ,@OwenD and all the others that have come up with ideas for this and my other issues re sensorless homing , i decided to go back to square one and rewrite all the macros and configs, i now have a machine that seems to be doing everything it should . so im posting all the files that i have working.
                                thes files are for a core XY , belt driven Z with a gearbox ratio 4:1
                                ; Config.g
                                M550 P"Valkyrie 3030 V003"                     	; set printer name
                                M669 K1    										; core xy
                                M566 X800.00 Y800.00 Z20.00 E100.00 P1        	; set maximum instantaneous speed changes (mm/min) jerk
                                M201 X2200.00 Y2200.00 Z50.00 E250.00 	     	; set accelerations (mm/s^2)
                                M906 X1000 Y1000 Z1000 E800 I50                	; set motor currents (mA) and motor idle factor in per cent
                                M84  X Y S20									; Set idle timeout sec
                                M208 S1 X-28 Y5 Z0								; set axis minima "Travel Area"
                                M208 S0 X290 Y295 Z405                          ; set axis maxima "Travel area"
                                M558 P8 C"!io3.in" H10 F2000 T6000 R0 A2 S0.05  	; set Z probe type to unmodulated and the dive height + speeds
                                G31 P500 Z0.5										; set Z probe trigger value, offset and trigger height bigger the posative number the closer to the bed
                                G31 P500 X27 Y-15              						; set x,y trigger value, offset and trigger height
                                M557 X10:290 Y10:285 S100                     		; define mesh grid
                                ;Bed
                                M143 H0 S130                                   					; set temperature limit for heater 0 to max C
                                ;extruder
                                M143 H1 S320                                   					; set temperature limit for heater 1 to max C
                                ;Chamber
                                T0
                                ;External Buttons
                                ; homex.g
                                echo "start"
                                M569 P0.0										; Check status in console
                                M569 P0.1										; Check status in console
                                M569 P0.0 S1 D3 V10                             ; set to stealth chop
                                M569 P0.1 S1 D3 V10								; set to stealth chop
                                M915 P0.0:0.1 S10 F0 R1 H200                    ; Configure Z-Axis Stall Detection
                                echo "stall detection setup"
                                M17 X Y										; Check status in console
                                G1 P140											;pause to allow the drivers to characterise the motor
                                G1 H1 X-0.2 F3000								; move a  little  for cal of sensorless homing / not stalled
                                G1 H1 Y-0.2 F3000    							; move a  little  for cal of sensorless homing / not stalle
                                echo "lower motor current"
                                M913 X70 Y70									; Lower motor current %
                                G4 P150											; wait 150ms
                                M574 X1 Y2 S4									; Configure Z-Axis stall detection homing
                                echo "home x"
                                G1 H1 X-350 F6000
                                G1 H2 X10 Y10
                                G1 H1 X-350 F6000						; Home Z-Axis actuators independently
                                G1 X150 F6000									; move to center of bed
                                ;revert back
                                echo "after revert back"
                                M913 X100  Y100									; Reset motor current %
                                M569 P0.0 S1 D2									; reset motors back to spread cycle,
                                M569 P0.1 S1 D2									; reset motors back to spread cycle,
                                ;homey.g
                                												; Relative positioning
                                echo "Home Y"
                                M569 P0.0										; check status in console
                                M569 P0.1										; check status in console; relative positioning
                                G91
                                M569 P0.0 S1 D3 V10                             ; set to stelth chop
                                M569 P0.1 S1 D3 V10								; set to stelth chop
                                M17 X Y
                                G1 P140
                                G1 H1 X-0.5 F3000                               ; move a  little  for cal of sensorless homing / not stalled
                                G1 H1 Y-0.5 F3000    							; move a  little  for cal of sensorless homing / not stalled
                                G4 P150
                                echo "Home Y"
                                G1 H1 Y350 F6000
                                G1 H2 X-10 Y10
                                G1 H1 Y350 F6000                       	; Home Z-Axis actuators independently
                                G1 Y150 F6000									; move to center of bed
                                ;revert back
                                ; homez.g
                                echo "home Z.g "
                                G1 F6000 X150 Y150									; make sure X Y centreed
                                G91													; Relative positioning
                                echo "Homing Z"
                                G30  		                  						; Home Z-Axis actuators independently
                                G1 Z25 F4000 										;move away a little
                                ; home_max_Z
                                G1 H1 Z350 F3000                       				; Home Z-Axis actuators independently
                                ;revert back
                                ;3PL
                                echo "3PL"
                                G30 P2 X150 Y270 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
                                G1 X0 Y0 F6000
                                • moth4017undefined moth4017 referenced this topic
