    Turning Frankenstein into Cinderella
    539
    • A Former User?
      A Former User
      The Heart of the Matter
      Long story short. I bought an Xvico Pioneer. Got bamboozled by a you-tuber that was selling junk. The printer's board is really quite good as far as I can see. The prints I'm getting out of it are excellent. But here's the thing: ZERO CONNECTIVITY. I came from an Anet A8 that I transformed into a BLM A8.
      Anyways, I wanted to put Marlin (boo, hiss), on the Xvico board. But there's no way as far as I can see. So I bought a BTT E3 Mini. What a mess that was. Then I decided, okay, I'm going to buy the best board I can. Where I define "best" as well documented, well supported. Duet takes the cake on those fronts.
      My goal is to use my Duet 3 mini 5+ on this Xvico / Ender 3 (or CR_something) clone.
      The problems are: Mystery Board, Mystery Motors, right? Without the information I should have (in a perfect world), defining what I've got for the Reprap Config Program's going to be an impossible to herculean task.
      But that's where I need to go.
      Any help would be appreciated, but, I don't want a .bin file, I want to learn what's what.
      Thank you in advance.
      Mark
      droftartsundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @A Former User
        @corlissmedia there's a guide to what you need to find out here:
        https://docs.duet3d.com/User_manual/Overview/Adapting
        There's a guide to using the RepRapFirmware configuration tool:
        https://docs.duet3d.com/en/How_to_guides/Configuring_firmware
        There's a couple of guides to converting an Ender 3 to Mini 5+, though the series isn't quite finished yet (ahem @Phaedrux !), but this covers the configuration:
        https://docs.duet3d.com/How_to_guides/e3p_Mini5+_guide_part2_configuration
        A .bin file is a binary file. This is used to update the firmware on the Duet, for example. The configuration is done in text files, which are also Gcode files; they all end in .g. The RepRapFirmware Configuration Tool outputs a .zip file, which is just a compressed file. Within it are the .g files that make up the configuration. It's a bit of a headspin when coming from Marlin, but this page also explains it: https://docs.duet3d.com/User_manual/RepRapFirmware/RepRapFirmware_overview#firmware-differences-from-other-firmwares
          @corlissmedia said in Turning Frankenstein into Cinderella:
          Mystery Motors
          Specifically about these: if possible measure the resistance of each phase (see https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_connecting#identifying-the-stepper-motor-phases), measure the size (they are probably NEMA 17, but the length of the motor is directly proportional to how much torque it has/how much current it can take), and post a picture of (or write out) any markings or labels on the motor. This should give the forum sleuths some information to make a guess at some good motor settings. Though, realistically, setting the motor current to 1000mA is probably going to be fine on a Ender 3 clone.
          Most other components are going to be pretty bog-standard. Thermistors will probably be typical NTC3950. Belts will be 2mm Gates. Pulleys will be 16 tooth or 20 tooth. But most of these things don't matter too much, as you can adjust it when commissioning the printer, and because it's RRF not Marlin, you don't have to reflash the firmware each time!
          A Former User? 2 Replies Last reply Reply Quote 0
          • A Former User?
            A Former User @droftarts
            @droftarts thanks!
            • A Former User?
              @droftarts that is really helpful!
              • A Former User?
                @droftarts I posted a series of pictures of my printer on Instagram. You can find me there @Corlissmedia2.0
                  @corlissmedia sorry, I don’t ‘do’ instagram! You can post images here, too, which would make it easier for people trying to help you.
                  A Former User? 3 Replies Last reply Reply Quote 0
                  • A Former User?
                    @droftarts understood, so now I have to figure that out. Another learning experience!
                    oliofundefined A Former User? 2 Replies Last reply Reply Quote 0
                    • oliofundefined
                      oliof @A Former User
                      Use the image upload function baked in to upload images to articles.
                      • A Former User?
                        • A Former User?
                          A Former User @oliof
                          @oliof some of the tools are off the screen on my phone.
                          • A Former User?
                            • A Former User?
                              A Former User @A Former User
                                @corlissmedia thanks. Any labels on the motors? If you can still access the original electronics, you may be able to get some information off it. What is the exact manufacturer's name and model name/number? They may have their firmware on GitHub.
                                • A Former User?
                                  @droftarts This is the most information I've found so far: link text
                                  Here's the info on the above page about the board: link text
                                  There's no printed information on the motors, but here's what I can tell you: all of the mounting screws are 30mm apart, the bodies are 42 x42mm square, and 37.5mm deep.
                                  This printer has a single lead screen (left side). That's where the X and filament drive motors are.
                                  The bed's 220 by 220, and the possible vertical rise is 240.
                                  I swapped out their 15amp power supply for a Meanwell 20amp supply when I installed a heated bed on this printer.
                                  This man has a lot to say about the board in this printer: link text
                                  There's a mention of Dlion as the manufacturer of the board.
                                  Here's an interesting color drawing of the board, next to a shot of the board in the printer, what a rat's next! [link text](https://community.ultimaker.com/topic/33347-need-motherboard-for-my-xvico/
                                  If I find any more cogent info, I'll let you know.
                                  Mark
