    error reading -273.1
    461
    • A Former User?
      A Former User
      hello i have this error my bed Sensor 0 type Thermistor using pin bedtemp, reading -273.1, last error: sensor open circuit, T:100000.0 B:3950.0 C:0.00e+0 R:4700.0 L:0 H:0 help
      • A Former User?
        A Former User @A Former User
        @sgk Capture d’écran 2022-06-17 112635.jpg Capture d’écran 2022-06-17 112622.jpg
          jay_s_uk @A Former User
          @sgk that means its not wired correctly or you're using the wrong thermistor input in your config.g
          • A Former User?
            A Former User @jay_s_uk
            @jay_s_uk
            I didn't do anything it works before I just installed a mks mosfet and after I got that I put it back as before without the mosfet and now I have this error
            jay_s_ukundefined A Former User? 2 Replies Last reply Reply Quote 0
              @sgk better check your wiring then as something has come loose
              • A Former User?
                • A Former User?
                  @jay_s_uk
                  the cables are well connected I really do not understand
                  • oliofundefined
                    oliof @A Former User
                    if the wires are fine, you may have connected the thermistor in the wrong place or defined the wrong pins.
                    • A Former User?
                      A Former User @oliof
                      I understand what you're trying to tell me except that I didn't change anything and before it worked perfectly
                      jay_s_ukundefined oliofundefined 2 Replies Last reply Reply Quote 0
                        @sgk well theres no other answer to give you. if you didn't change the config at all then its definitely wiring
                        • A Former User?
                          @jay_s_uk i have this Error: Temperature reading fault on heater 0: sensor open circuit
                            @sgk yes, because your wiring has issues. no connection = open circuit
                            • oliofundefined
                              @sgk If you are unwilling to check what the error points at, we can't help you. Insisting it worked before is not helping.
                              • A Former User?
                                @oliof OK I will check the cabling
                                • A Former User?
                                  @sgk find the problem with the hs bed thermistor probe thank you
                                  A Former User? 1 Reply Last reply Reply Quote 1
                                  • A Former User?
                                    @sgk problem solved it was the thermistor of the bed hs thank you to you👍
