    power loss with UPS
    557
    • sinoleundefined
      sinole
      I connected a power loss sensor to my printer and wrote a trigger file for it but trigger pauses the print very slowly and doesn't immediately turn of my bed and hotend so my capacitor runs out of power. does anyone know how to make the trigger to react faster.
      I put this at the end of config.g
      M950 J3 C"nil"
      M950 J3 C"PWRDET" ; input 1 e0 filament sensor
      M581 P3 T3 S0 R1 ; PLR sensor P1 triggers Trigger3.g always (R0) TRIGGER OFF
      and following is the trigger 3
      M140 S0 R0 ; set bed temperature to 0C
      M140 S-1 ; set bed temperature to 0K to turn it off
      M104 S0 T0 ; set extruder temperature to 0C
      M107 ; turn off fan
      M913 X0 Y0 Z0.3 ;turn motors off
      M226 ; Pause the print
      G91 ;Set to Relative Positioning
      M83 ;Set extruder to relative mode
      G1 Z5 E-5 F1000 ;raise Extruder 5mm
      please help me fix this. my apartment have crazy power fluctuation because of over population of this area.
      • fcwiltundefined
        fcwilt @sinole
        @sinole
        Triggers 2 and up don't react until the current move is finished - that may be what you are seeing.
        sinoleundefined 1 Reply Last reply Reply Quote 0
        • sinoleundefined
          sinole @fcwilt
          @fcwilt thanks, so if the move is long it wont trigger on time to save the print.
          deckingmanundefined fcwiltundefined sinoleundefined 3 Replies Last reply Reply Quote 1
          • deckingmanundefined
            deckingman @sinole
            @sinole M226 is the wrong command to use in this situation as it will wait for all moves in the queue to be completed. Use M25 instead which will take a maximum of one move plus 2 seconds.
            In fact, the macro "pause.g" will run after movement stops so all you need to have in your trigger3 file is that one M25 command, then move all the other commands into the pause.g file which will be tidier. You might also want to do the G1 Z move before you reduce the motor currents. Better still, use M84 at the end of pause.g.
            gloomyandyundefined sinoleundefined 2 Replies Last reply Reply Quote 1
            • fcwiltundefined
              fcwilt @sinole
              @sinole said in power loss with UPS:
              There is a command (which I cannot remember) which will breakup long moves so they are done as a series of short moves.
              This will reduce the time before the trigger is acted upon but it still won't be immediate.
              I think the only trigger that is immediate is trigger 0
              • gloomyandyundefined
                gloomyandy @deckingman
                @deckingman If all the trigger file does is M25 it may be better to just use trigger 1, which according to the docs...
                " Trigger number 1 causes the print to be paused as if M25 had been received. "
                deckingmanundefined 1 Reply Last reply Reply Quote 1
                • sinoleundefined
                  sinole @sinole
                  @sinole I have tried M25 as well, It was same.
                  • sinoleundefined
                    sinole @deckingman
                    @deckingman M669 S1 t1?
                      deckingman @gloomyandy
                      @gloomyandy said in power loss with UPS:
                      Good point!
                        deckingman @sinole
                        Hmm - that's a fairly recent addition with limited documentation so I'm unable to comment. Give it a try but use with caution. I wouldn't go for too short a segment length say 10mm as a minimum?
                          jay_s_uk @deckingman
                          @deckingman I run M669 S1 T1 on my CNC no issue
                          • sinoleundefined
                            sinole
                            if I want to write a "if" function how should I address endstop swtich status. like
                            if {endstop.swtich[n] == 1}
                            it want to just do everything in pause.g and not write a trigger that addresses pause. according to gloomyandy that doesn't work great. with the "if" I can make pause.g to also turn of bed and motors when switch is triggered. and in case of normal pause just pauses.
                              deckingman @jay_s_uk
                              @jay_s_uk said in power loss with UPS:
                              Good to know - thanks.
                              • selva_tviundefined selva_tvi referenced this topic
