    Valkyrie & D2WF +Dx5 - Stallguard homing on XYZ(UV)
    My Duet controlled machine
    316
    • pro3dundefined
      pro3d
      Valkyrie stallguard homing on all 5 axes (XY+ZUV) has been working awesome for 6 months now on Duet 2 WiFi + Duex5. I want a D36HC but wonder if it will be as smooth using stallguard as homing with the TMC5160s
      https://youtube.com/shorts/I8Al3ULsmxc
      oliofundefined pro3dundefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @pro3d
        @pro3d Duet2 2660 implement stallguard2, Duet3 5160/2209 implement stallguard4. There are some differences in how they operate (spreadcycle vs. stealthchop), and the Stallguard docs describe this in detail.
        oliofundefined pro3dundefined 3 Replies Last reply Reply Quote 0
        • oliofundefined
          oliof @oliof
          PS: You probably want to update your graphics to use the proper larger than sign ">" ... if you really reach temperatures beyond 450C on the nozzle for example.
          Exerqtorundefined 1 Reply Last reply Reply Quote 0
          • Exerqtorundefined
            Exerqtor @oliof
            @oliof said in Valkyrie & D2WF +Dx5 - Stallguard homing on XYZ(UV):
            Pretty sure he wants it to be "Up to 450C" 🤔
            • pro3dundefined
              pro3d @oliof
              Graphics are correct
              • pro3dundefined
                pro3d @pro3d
                This post is deleted!
                • pro3dundefined
                  pro3d @oliof
                  5160 say stallguard 2: https://www.trinamic.com/products/integrated-circuits/details/tmc5160/
                  • oliofundefined
                    oliof @pro3d
                    @pro3d you're right, I confused this with the 2209s. Apologies.
