    Weird macro behaviour
    Gcode meta commands
    896
    • Exerqtorundefined
      Exerqtor
      I'm setting up bed leveling macro's and i'm starting up with the one that's going to be called when i start a print. But for some reason it jumps from line 40 to line 96 just skipping over everything in between those lines. And i can't figgure out what i've done wrong to make it behave like this.
      Here is the macro(s) for those who got time to sift thru them:
      ; /sys/lib/print/print_level_bed.g
      ; Called as part of print_start.g
      ; Used to make sure the bed is leveled
      ; homing check
      ; Make sure all axes are Homed
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed           ; if axes aren't homed
        G28        ; home all axes
      ; check if bed is leveled
      ; If the bed isn't leveled
      if global.bed_leveled = false
        ; prepare to probe
        ; Prepare to level bed
        M291 R"Bed leveling" P"Please wait..." T0                                    ; leveling bed message
        M561        ; clear any bed transform
        M290 R0 S0        ; reset baby stepping
        M84 E0        ; disable extruder stepper
        ; Lower currents, speed & accel
        M98 P"/sys/lib/current/xy_current_low.g"                                     ; set low XY currents
        M98 P"/sys/lib/current/z_current_low.g"                                      ; Set low Z currents
        M98 P"/sys/lib/speed/speed_probing.g"                                        ; set low speed & accel
        ; Load the klicky probe
        M400        ; wait for moves to finish
        M98 P"/sys/lib/klicky/klicky_status.g"                                       ; refresh klicky status
        M98 P"/sys/lib/klicky/load_klicky.g"                                         ; pick up the klicky probe
        ; Last check to ensure klicky is attached
        if global.klicky_status = "attached"
          echo "Probe ATTACHED"
        elif global.klicky_status = "docked"
          echo "Error probe not attached - aborting"
          M291 T5 R"Bed Leveling Aborted!" P"The bed haven't been leveled - check probe"
          set global.bed_leveled = false                                               ; set global state
          abort
        ; Coarse leveling pass
        M558 K0 H15 F600 A1                                                        ; increase the depth range, gets the bed mostly level immediately
        M98 P"/sys/bed_probe_points.g"                                             ; probe the bed
        ; probing code
        ; Probe the bed
        while true
          ; --- probe near lead screws -
          M558 K0 H3 F240:120 A30                                                  ; reduce depth range, probe slower for better repeatability
          ; check results - exit loop if results are good
          if move.calibration.initial.deviation < 0.02                             ; if probing result is less than 0.02mm
            break        ; stop probing
          ; check pass limit - abort if pass limit reached
          if iterations = 5                                                        ; if probed more than 5 times
            M291 P"Bed Leveling Aborted" R"Pass Limit Reached"                     ; abort probing, something wrong
            abort "Bed Leveling Aborted - Pass Limit Reached"                      ; abort probing, something wrong
        ; finish up
        ; Dock the klicky probe
        M98 P"/sys/lib/klicky/unload_klicky.g"                                     ; dock the klicky probe
        G28 Z        ; probe nozzle one last time
        set global.bed_leveled = true                                              ; set global state
        ;echo "global.bed_leveled. Value : " , global.bed_leveled
        M291 R"Bed leveling" P"Done" T5                                            ; bed leveling done message
      ; response if leveled
      ; Bed already leveled, no need to probe
      M291 S1 R"Bed leveling" P"Bed allready leveled" T1
      ; /sys/lib/klicky/klicky_status.g
      ; Used to check if the klicky probe is attached or not
      ; global.klicky_status
      ; = docked
      ; = attached
      if sensors.probes[0].value[0] = 0
        set global.klicky_status = "attached"
      elif sensors.probes[0].value[0] = 1000
        set global.klicky_status = "docked"
      ( I can include all the other macro's that getts called in "print_level_bed.g" but i can't see any need for them since everything stops working at line 40 / second time klicky_status.g gets called.)
      I'm on RRF/DWC 3.4.1 by the way.
      fcwiltundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @Exerqtor
        @exerqtor said in Weird macro behaviour:
        print_level_bed.g
        klicky_status.g
        Please get in the habit of copy-and-pasting files into the </> tag, one tag per file.
        This will create a scrollable region right in your post so the rest of us don't have to download a file to view it.
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt @Exerqtor
          This post is deleted!
          • Exerqtorundefined
            Exerqtor @fcwilt
            @fcwilt said in Weird macro behaviour:
            Didn't know that was the perfered way in larger files (esp when refering to line numbers), fixed now 👍
            fcwiltundefined deckingmanundefined 2 Replies Last reply Reply Quote 1
            • fcwiltundefined
              fcwilt @Exerqtor
              @exerqtor
              Nothing jumps out at me.
              When it happens to me I starting "sprinkling" my code with echo statements so I can track the progress of the code and see exactly where things go wonky.
              And I have to remind myself to check the DWC Console which may list an error message giving a clue to what went wrong.
              • Exerqtorundefined
                Exerqtor @fcwilt
                @exerqtor
                Yeah i've done that and confirmed that it goes past the klicky_load.g and it also runs the klicky_status.g after klicky_load (since it changes the global to attached when it's done), BUT if i throw a echo after klicky_status.g on line 40 it dont get called out, the next thing that happens is the "bed allready leveled" on line 96 😆 i can't figgure out what the f is going on at this point.
                • fcwiltundefined
                  fcwilt @Exerqtor
                  OK let me take a closer look.
                  JOOC, how many values can the global status variable have?
                  • deckingmanundefined
                    deckingman @Exerqtor
                    @exerqtor Is it possible that sensors.probes[0].value could be something other than 0 or 1000? I'm not seeing anything that could catch that which would mean that the global.klicky_status would not be set to "attached" nor "docked".
                    • Exerqtorundefined
                      Exerqtor @deckingman
                      @deckingman Nope, it's a simple on/off microswitch so it can't output anything else.
                      Changing the global variable two times in a short amout of time shouldn't have anything to say either should it? 🤔 I'll uncomment the status refresh before klicky_load.g tomorrow to see if that changes anything.
                      • fcwiltundefined
                        fcwilt @Exerqtor
                        No that should not have an effect... except I did read about a problem in 3.4.1, with one macro calling another... now what was the work around... I don't remember.
                        Perhaps you can find those posts.
                        • Exerqtorundefined
                          Exerqtor @fcwilt
                          Oh you did? Haven't seen that mentioned yet, i'll try to find it!
                          EDIT: Is this the thread you were refering to @fcwilt?
                          • Del87undefined
                            Del87
                            My observations regarding macros:
                            M83 via console works.
                            Makros file containing one string M83 not working.
                            Dmitry
                            • gloomyandyundefined
                              gloomyandy @Del87
                              @del87 When a macro is run some settings are saved and restored I'm pretty sure that the extruder absolute/relative mode is one of them, so M83 in a macro may appear to do nothing. See: https://docs.duet3d.com/en/User_manual/Tuning/Macros_tasks#running-macros
                              Del87undefined 1 Reply Last reply Reply Quote 2
                              • Del87undefined
                                Del87 @gloomyandy
                                @gloomyandy
                                dunno that, thanks!
                                Dmitry
                                • fcwiltundefined
                                  fcwilt @Exerqtor
                                  Yes - you found it.
                                  • Exerqtorundefined
                                    Exerqtor @fcwilt
                                    @fcwilt
                                    Adding echo "" at the end of the nested macros did the charm, thanks for the heads up on that one!. Lets hope @chrishamm finds a fix for it soon 🤣
                                    fcwiltundefined chrishammundefined 2 Replies Last reply Reply Quote 1
                                    • fcwiltundefined
                                      fcwilt @Exerqtor
                                      @fcwilt
                                      Glad to hear it is now working for you.
                                      • mikeabuilderundefined
                                        mikeabuilder
                                        Glad it's working, but I'll toss in couple of comments.
                                        The comment - Per @deckingman comment, I think it's good coding practice to check probe values with a ">X" vs "=Y".
                                        Another comment - I don't see an initialization for global.klicky_status. If it was not initialized, you should have seen an error in the console or log file. Adding an "else with a message stating klicky status is not defined and an abort would be nice, that way you've covered all options for global.klicky_status. Even better would be a third return value for gloabl.klicky_status in klicky_status.g. on Line 12 add an else set global.klicky_status = "invalid". Then you'd see if the value passed back to the main macro is neither 0 nor 1000.
                                        My speculation is that if the variable was not initialized it might abort the "code block" that contains it, which might be the block starting on line 1and ending on line 90.
                                        Exerqtorundefined 1 Reply Last reply Reply Quote 1
                                        • chrishammundefined
                                          chrishamm administrators @Exerqtor
                                          @exerqtor I've got a fix ready that will be part of the next 3.4.2-b1 version. dc42 has already merged it.
                                          Duet software engineer
                                          • Exerqtorundefined
                                            Exerqtor @mikeabuilder
                                            @mikeabuilder said in Weird macro behaviour:
                                            Noted, then i guess this will taste better:
                                            if sensors.probes[0].value[0] < 1
                                            elif sensors.probes[0].value[0] > 999
                                            echo ""
                                            global.klicky_status get's initialized along with all my other globas thru a macro named "globals.g", "globals.g" on it's side gets called by "init.g" as one of the last steps in my "config.g".
                                            end of "config.g"
                                            M950 P0 C"out2"        ; create output Port0 attached to out2 connector for LED lights
                                            M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                             ; set voltage thresholds and actions to run on power loss
                                            M572 D0 S0.0        ; Disable Pressure Advance
                                            M98 P"/sys/lib/init.g"                                                         ; iniate external configs
                                            M501        ; load config-override.g
                                            T0        ; select tool 0
                                            "init.g":
                                            ; /sys/lib/init.g
                                            ; Called in the end of config.g
                                            ; Used to setup more stuff
                                            M98 P"/sys/lib/globals.g"                                                      ; setup global variables
                                            M98 P"/sys/lib/speed/speed_printing.g"                                         ; set normal speed & accel
                                            M98 P"/sys/lib/current/xy_current_high.g"                                      ; set normal xy currents
                                            M98 P"/sys/lib/current/z_current_high.g"                                       ; set normal z currents
                                            M98 P"/sys/lib/fw_retraction.g"                                                ; set firmware retraction settings
                                            "globals.g"
                                            ; /sys/lib/globals.g
                                            ; Called by init.g
                                            ; Used to initialize global variables
                                            ; global declarations and defaults
                                            ; temperature
                                            if !exists(global.bed_temp)
                                              global bed_temp = 0
                                            if !exists(global.hotend_temp)
                                              global hotend_temp = 0
                                            if !exists(global.chamber_temp)
                                              global chamber_temp = 0
                                            ; stepper currents
                                            if !exists(global.xy_current)
                                              global xy_current = move.axes[0].current
                                            if !exists(global.z_current)
                                              global z_current = move.axes[2].current
                                            if !exists(global.e_current)
                                              global e_current = move.extruders[0].current
                                            ; mechanical Z pin
                                            if !exists(global.zpinx)
                                              global zpinx = 194.5
                                            if !exists(global.zpiny)
                                              global zpiny = 355
                                            ; klicky probe
                                            ; the distance from the body of the klicky probe to it's own trigger point
                                            if !exists(global.klickyoffset)
                                              global klickyoffset = 0.23  ; a larger values makes the nozzle closer to the bed after running autoz
                                            ; the absolute X location of the klicky while docked
                                            if !exists(global.klickydockx)
                                              global klickydockx = 18.6
                                            ; the absolute Y location of the klickywhile docked
                                            if !exists(global.klickydocky)
                                              global klickydocky = 357.3
                                            ; the relative disance and direction of the klicky docking move
                                            if !exists(global.klickywipe)
                                              global klickywipe = 30  ; -30 for a left wipe 30 for a right wipe
                                            if !exists(global.klicky_status)
                                              global klicky_status = "none"
                                            ; bed
                                            ; define the bed size (print area from 0 to X and Y max)
                                            if !exists(global.bedx)
                                              global bedx = 350
                                            if !exists(global.bedy)
                                              global bedy = 350
                                            ; misc
                                            if !exists(global.initial_extruder)
                                              global initial_extruder = 0
                                            if !exists(global.bed_leveled)
                                              global bed_leveled = false
                                            if !exists(global.job_completion)
                                              global job_completion = 0
                                            if !exists(global.debug_mode)
                                              global debug_mode = true
                                            ; output current values
                                            ;echo "global.bed_temp defined. Value : " , global.bed_temp
                                            ;echo "global.hotend_temp defined. Value : " , global.hotend_temp
                                            ;echo "global.chamber_temp defined. Value : " , global.chamber_temp
                                            echo "global.klicky_status defined. Value : " , global.klicky_status
                                            echo "global.job_completion defined. Value : " , global.job_completion
                                            echo "global.debug_mode defined. Value : " , global.debug_mode
                                            Agreed on that, an else condition that resulted in "invalid" the result was anything between 1 too 999 would fix that with an abort. But i can't figgure out how to construct that, for instance
                                            else sensors.probes[0].value[0] = {what to but here to check if the value is between 1 and 999?}
                                              echo "Klicky status invalid - aborting"
                                              abort
                                            echo ""
                                            Or just go the easy route with
                                            else
                                              abort
                                            echo ""
                                            Turns out the premature ending was a bug in DWC, so it wasn't my fault this time lol.
                                            @chrishamm said in Weird macro behaviour:
                                            Sweet, hope that beta see the light of day pretty soon!
                                            • OwenDundefined OwenD referenced this topic
